Question about Sony Ericsson K750i Cellular Phone
Short circut low battery vary fast
  • 77 Answers
Buy a new one
Posted on Sep 10, 2009
    President:
  • 1,124 Answers
If the battery is close to a year old - or - if it was not charged properly on the FIRST charge - the battery might need to be replaced,, and should clear the issue..
I hope this helps ;o)
Several modules are always powered. What is the typical current drain on the battery when the key is OFF?
Vary low should never make no start conduition.
Sounds like you have a muility meter to ask for voltages .
Try this disconnect the negitive from the battery .Set the meter on the 20 volt DC scale .Go red lead to posivite and black to engine block or any known solid ground .If you read voltage something is shorting
If the voltage 2 -3 volts it could be switches lights ect .If its 5 volts or over then its something that draws a lot of power like a bad motor .
At any rate if you read voltage pos to gr with gr disconnect from bat their is a short .
You can try pulling fuses 1 at a time to see when it stops .This will tell you what circuit the problem is on and sometimes the starting motor will short interinaly this will kill the bat fast
Apr 16, 2015 | 2003 Chevrolet Avalanche
My main fuse on 900 vulcan 2011 keeps blowing just when I try to put it in. Does anybody have any ideas? this bike has very ow miles and is kept in guarage.
Low battery will not blow a fuse. If it blows right away when you turn on the ignition you have a main electrical short. Disconnect the regulator to the battery connector at the regulator to see if you have a shorted regulator. After the main fuse blows you should not have a battery drain so figure out also why your battery is discharged. Is your batttery no good. This would not blow a fuse in any case. Was the battery out recently, or disconnected. Make sure it is installed correctly and none of the wires are connected incorrectly. THEN you will have to start tracing the wiring from the main fuse to find the short circut.
Sep 12, 2014 | 2011 kawasaki Vulcan 900 Classic LT
What is code 35 and 76 for 1993 grand cherokee
35 is p1491 which is Radiator fan control relay circut (bad relay).... An open or shorted condition detected in the low speed radiator fan relay control circut
I dont have 76 i have 77 is p1683 which is Speed control power relay or s/c 12v driver ckt...... Malfunction detected with power feed to speed control servo solenoids. MAYBE another bad relay
Mar 25, 2013 | Jeep Grand Cherokee Cars & Trucks
Milwaukee v18 battery runs down real fast
a battery in the battery pack is open circut Re: Jeff
Apr 06, 2012 | Drills
Samsung camera saying low battery when batteries fully charged
well there is a problem of power supply in your camera or some kind of short circut u need physical assistance.
Jul 25, 2009 | Cameras
When turned on trips circut breaker
If it happened fast then it is more than likely shorted fan motor, compressor or wire. Need to check for short to ground with Volt Ohm meter.
Jun 30, 2009 | Heating & Cooling
No dial tone when the talk button is pushed
the circut inside is acting up and will need repair, this can happen whenthe batterys are low in the phones and the base does not detect them , also the detect circut coud be bad , and or the automatic pick up circut for the answering machine
Oct 15, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
Laptop not charging
It happened because of the short circut - when there is short circut as a safety measure it disconnect and avoid further damage - trip off
In your case power adapter and battery are good but check the power socket of the laptop - if they are also ok then its a motherboard issue. - open it and check up for circut short.
Aug 11, 2008 | Dell Latitude D600 Notebook
Liebert UPS fan work fast even when off
this system is opperated by fieldeffect transistors it may be obviouse that 1 or 2 component especially the FET may be sort circuting
Jan 19, 2008 | Liebert (PS2200RT2230) UPS System
Sony Ericsson K750i Cellular Phone Logo
108 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
