Question about Maytag Refrigerators
I have a refridge maytag model mff2557hes i replaced the comp board now it lights up but cannot change temps i have no comp i have no fan how can i reset board
    President:
  • 1,653 Answers
The board should have a small reset switch on it which you will need to press and hold for 10 seconds while the power is on. If not turn off the mains power and disconnect the board from all devices and power for at least 60 minutes then reconnect it and all should be OK. If not then it sounds as though you may be unfortunate enough to have a faulty board. It does happen!
Posted on Sep 10, 2009
I have maytag mff2557hes fridge that seems to run more often than not. Freezer and fridge cool fine but it seems to run all the time. Is this normal?
Pull the unit out from the wall and check the coils at the compressor for lint and dirt buildup. The coils and fan should be free of any debris to operate correctly.
Nov 03, 2012 | Maytag MFF2557HES Stainless Steel French...
Model # MFF2557HES Top refrigator section stoped cooling freezer is working
You may have Ice buildup in the freezer. You freezer has a fan in the bak that sends the cool air to the fridge. Your fridge dial determines how muh cold air comes from the freezer. Try defrosting the freezer. You may have to pull the back panel off of the inside of the freezer to get the ice thawed. The ice build up is likely causing the air to not get to the fridge. Hope it works.
Aug 16, 2012 | Maytag MFD2560HES Bottom Freezer French...
Maytag Refrigerator MFF2557HES - won't stop running, everything frozen... despite adjustment to temp setting What to do, please and thank you?
Possible that the thermostat or the control unit is faulty as it fails to cut off the compressor.In some cases the frost or ice formation can reduce the connection or wire contact of the thermostat and so the function will not work. You need to remove the freezer rear covers to confirm if the wires are intact and also if the thermostat is working along with the auto defrost timer.
Sep 19, 2011 | Maytag MFF2557HES Stainless Steel French...
The bottom freezer works but the refrigerator will not get cold. model# MFF2557HES
Sounds like airflow fan needs to be replaced. Most fridges use a small fan that blows air from the freezer to the refridge. If that fan fails you get working freezer and non cool fridge.
May 06, 2011 | Maytag MFF2557HES Stainless Steel French...
HOw do you know if your compressor is going out on a maytag model#MFF2557hes
Sorry to read about your problem. you can have many different problems.
1. Bad temp control
2. Failing compressor
3. Defective start cap
4. Defective overload protector
5. Defective control board
But in your case, your freon maybe low
I suggest you call a service company. as they have the equipment to check for low freon.
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Jan 04, 2011 | Maytag MFF2557HES Stainless Steel French...
Refridge would cycle on, fan would come on relay would click but no compressor. relay kept clicking no compressor. I changed relay and capacitor on compressor plugged in all went well. after a few hours...
you were lucky . compressor must run with fan or it will get too hot . if comp is running to hot it will not come on and the fan will . . do you have the cardboard back on frig . this helps direct air to cool comp .. reck the wire connections . and last you may have to take a power ( amp ) reading . the compressor may be bad .. mm.. ps do not run on ext cord and make sure the power at wall plug is good power ...
Oct 07, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Everything in my Maytag model MBB1952HEW refrigerator freezes. It is running pretty much non stop now
You will need to replace the control board, which controls the temperature in both compartments, refrigerator and freezer.
Aug 12, 2008 | Maytag MFF2557HES Stainless Steel French...
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Re; control board
behind the display control youll find two slots for inserting a screwdriver and releasing tabs that are holding the control up, no screws just 2 press to release tabs, might be a little awkward to feel might have to twist your head in a little sideways to see them. there is or at least should be a tech sheet mounted to the underneath of the cabinet, just behind the kick plate on rightside
Mar 04, 2008 | Maytag MFF2557HES Stainless Steel French...
Refrigerators Logo
59 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
