Question about Pool & Spa
Pilot on Hayward pool heater will not stay lit after release...New millivolt generator was installed...No change...New gas valve was installed...Changed to 24V w/ new thermo couple and transformer...No change...Could problem be with control curcuit?
  • 6 more comments
  • reelaffair Sep 10, 2009
    Problem: Pilot will not stay lit after release...Generator was replaced w/ new on millivolt system...Pilot would still not stay lit...Changed out gas valve with new 24 volt system including new thermocouple and new transformer...tested for voltage (26 volts)...Pilot still goes out after release...Need to find solution to keep pilot on after release...Flame is blue, on thermocouple and full when held down...As soon as release - pilot goes out...Is problem electrical?
    If it was a ventilation problem wouldn't there be a problem w/ the initial flame?...Flame when first lit looks perfect...After lighting and holding down for approx. 60 sec flame goes out...Same problem on both millivolt system w/ new generator (power pile) and new 24 volt system w/ new thermocouple and new transformer...All connections are tight and clean...
    There is no environmental factors contributing to the situation...In both instances pilot does not stay lit after release...Again, installed new generator on existing millivolt gas valve...Pilot did not stay lit after release...Installed all new 24 volt gas valve, thermocouple (24 volt) and transformer (24 volt)...Pilot did not stay lit...Both gas valves are White Rogers, 3/4 inch on a Hayward pool heater...Both instances pilot does not stay lit...Both generator and thermocouple test OK...Pilot lights as should...after approx. 60 seconds, when release - pilot goes out immediately...
    There is no control board...Remember this is a millivolt system retrofitted w/ a 24 volt system...Gas supply is more than sufficient and is constant...Each time pilot switch is depressed, pilot will light - once released, pilot goes out in both applications...Main burner never receives signal to ignite...
    Thermocouple is matched to gas valve...I guess I could jumper across gas valve connections to eliminate switches, fusible link (if applicable), temp control...
    There is no control module...There is no silver box...Purpose for millivolt system is remote location away from electric... This application is driven either by 750,000 millivolt (first application) or by 24 volt (second application) where as I brought 110 to power the transformer
    Thanks for your help...Unfortunately, I have to put this problem aside until tomorrow...I will once again resume troubleshooting in the AM...System was left w/ the 24 volt application...I have a tester...Will contact you early on Friday...Thanks again
  • reelaffair Sep 11, 2009
    There is no control board...Original system used a millivolt generator (power pile)...No external elec. was necessary...After installing new generator, pilot still would not stay on when switch was released...New 24 volt system was installed w/ new gas valve, thermocouple and transformer...External elec. was brought in to power up transformer...Pilot lights fine...blue flame...high...steady...When release switch (after approx. 60 seconds)...Pilot immediately goes out...
    Top Expert:
  • 76,630 Answers
The thermocouple that senses the pilot is lit would have been my 1st guess here, but u have replaced it and all the other common components that would cause this including the gas valve, the next step would be to replace the electronic control board if that is where the thermocouple signal is sent to keep the pilot lit and allow the gas valve to turn on, this is only logical to this tech..
Posted on Sep 11, 2009
    Guru:
  • 1,326 Answers
If you have replaced the gas valbe and thermocouple the only other option is your CC board. Normally its the gas valve or thermocouple and very rare is it the board. Make sure your gas line has no leaks and is supplying a steady supply of gas...
Posted on Sep 10, 2009
    President:
  • 1,714 Answers
The control circuit is not working correctly. If the thermocouple that you replaced is sitting directly in pilot flame the control takes the signal and produces the output for gas valve to light. Inspect control board for visual damage and check all connections going to board. Replace control board.
(make sure that replacement thermocouple is the exact same one as old one, very important. Different numbered therm has different output)
  • 3 more comments
  • Craig Butler
    Craig Butler Sep 10, 2009
    Do not jumper out control components. That's how people get hurt. Replace control board.
  • Craig Butler
    There is a control module, that's it, change it.
  • Craig Butler
    Does't this unit have a silver box about 4" by 3 " with the wires for control and gas valve?
  • Craig Butler
    Do you have a meter that we could test a few things with, I have a few checks I'd like you to do?
  • Craig Butler
    Thermocouple has to provide the millivolts to pull in gas valve. That's it, we need to look at that. I need you to check the millivolts comimg from the therm while the pilot is lit...can you do this?
    President:
  • 1,188 Answers
This type of problem is most commonly caused by environmental factors: High wind gusts, excessive rain or a sprinkler head forcing water into the cabinet.
Other reasons could be low gas supply, failing pilot generator, a bad gas valve, slight blockage in the pilot assembly.
You have replaced the millivolt generator and gas valve so this should not be the reason now.
Are you sure that the environmental factors are not causing this?
Please provide more detail: either it not light up or just the flame goes off immediately after lighting.
  • Adnan Bhatti
    Adnan Bhatti Sep 10, 2009
    The millivolt generator and other pilot lighting systems are not the problem if they can ignite the pilot.
    The problem is that the gas supply cuts off after some time.
    Wait and check if it lights again after some time. If it is cycling on and off the please report.
    If it stays off then there is a problem with the control board: it turns off the gas supply.
  • Adnan Bhatti
    Wait and check if it lights again after some time. If it is cycling on and off then please report.
    Genius:
  • 1,341 Answers
You may have a problem with ventilation here..also if the previous themo couple was different then u need to get an exact model for it..but by the sound of it, seems that air flow could be restricted.
  • 601 Answers
Usually this problem oocurs due to the damageof thermocouple.But you say that you replace thermocouple. Check the efficiency of thermocouple by measuring the voltage on the wires coming back from the pilot. When you have the red switch depressed, check the voltage (should be about 200mV). If there's no voltage, then the fault is with thermocouple.
If not make sure pilot is clean, not a lazy flame, little or no yellow. If it does stay lit, the problem is probably in the "thermostat" circuit. The usual culprit is the pressure switch. If the pump isn't putting out enough
pressure, the heater won't fire. This is usually caused by the filter
needing back washing. You can jump the pressure switch momentarily
and if the heater fires, the problem is the switch. Either the filter needs
backwashing or a bad switch. Check for continuity with the pump running.
If the switch closes, the filter needs cleaning.
Hope this helps
Thanks
Smith.
Why will my hayward h 250 millivolt pool heater pilot light not stay lit
Looks like your pilot generator may have some corrosion on it. Follow the stainless steel tubing on the gas valve as it goes down to the burner area. At the end of this is the pilot assembly. If you can remove this so your able to work on it you will se a short metal rod that the pilot flame touches when lit. This generates current that keeps the gas flowing to the pilot to keep it lit. Take some sand paper and give it a light sand to remove any corrosion on it. Reassemble at put it together. You may also need to clean the pilot tube(stainless tube from valve). Small spiderwebs can reduce the flow to the pilot and cause this problem also
Jun 25, 2014 | Hayward 250kbtu Ng Pool Heater - Inground
Pilot wont stay lit when i release push down button on gas valve
Are you certain you are connecting the generator to the correct terminals? Is the pilot head partially blocked not allowing the flame to reach the generator even though the pilot is lit? Can you read the millivolts on the generator leads? Is the reading 400mV or higher? I assume it will be with a new generator but if it is not then the flame is not across the generator as it should be. If it is, be certain you are connecting the two leads properly and in the correct order. The generator has polarity so it needs to be connected to the valve properly. The tag up inside the heater should give you the correct locations for the white and red wires on the valve.
May 29, 2010 | Hayward 150000 BTU Millivolt Natural Gas...
I HAVE A DESA LP VENTLESS FIREPLACE AND THE PILOT WILL NOT STAY LIT
the heater makes use of a millivolt generator which generates a small dc voltage (500-750mv) that is applied to the pilot valve of your main gas valve. when you light your pilot, the flame bathes the generator with a flame. after a delay you release the pilot button. if the generator is working, the pilot valve will stay lit. if the generator is not working the flame will go out as soon as you release the pilot button. change the generator.
Oct 13, 2009 | Desa International Heating & Cooling
Do not know how to start pilot light
There should be instructions on the inside of the heater access door. Make sure you are comfortable working with gas heaters. Make sure the shutoff valve supplying gas to the heater is on. Turn the gas valve to "pilot", press and hold it while attempting to light the pilot. Once the pilot is lit, continue holding the gas valve knob down for about 30 seconds. The pilot should stay lit once you release the knob. If the pilot stay lit, turn the gas valve to "on". Replace the heater access door and make sure you have proper water flow and attempt to light the heater. If it will not light, or the pilot will not stay on, you will probably have to replace the pilot generator. It provides voltage to run the heater and after time it wears out and produces less and less voltage. A millivolt heater runs on less than one volt so any power loss can be a problem. If you are able, test the pilot generator with a multimeter to see if you are getting at least 500mv when the pilot is on. If not, you should replace the pilot generator or even the entire pilot assembly. Hope this helps...
Sep 27, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
Hayward mod h1501 light pilot it stays lit turn temp up and it run,s but when we turn it down and shut it off the pilot go,s out and we have to lite it every time we use it,s out. a new gas valve in will...
Check the burner tube closest to the pilot side of the burner tray. Is it burning a nice blue like all the rest? If it is not, clean out the jet on the manifold in front of the tube.
If it is ok, can you get a millivolt reading off the generator (thermocouple)? If so, get the reading with just the pilot on it, then with the burner load. Finally, watch that reading as the burners run for a while to be sure it climbs.
The only other thing I can think of would be to get manometer readings to verify gas pressures before and after the valve.
Jul 30, 2009 | Hayward H Series Millivolt 250,000 Btu...
Gas pool heater pilot will not stay lit
Depending on the make and model of your heater, the first thing I would check for is gas pressure. If it is sufficient, check the pilot assembly for corrosion and/or a damaged pilot tube. Sometimes replacing the entire pilot assembly is a sure fix and also replaces the pilot generator that degrades over time. A new pilot assembly takes care of a couple of problems by improving gas flow and millivolts generated. Also, the orifice inside the pilot assembly could be corroded or clogged.
Jun 15, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pilot did not stay lit,replace gas valve , pilot stays lit,but now it won't fire up. Jumped the TH terminals and it shut off the pilot light.thermostat is set highier than the water temp.Jump all ths...
Your problem is the pilot generator where the flame is by the burners. This needs to be repalced. That is what is causing the pilot to go out and not start. It is a flame sensor and also tells the gas valve when to release more or less gas.
May 28, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H250 (millivolt) pilot won't stay lit
make sure the flame hits the thermo couple if so then replace it lows has them in the water heater section thermo couple gets hot makes millivolt signal then opens gas valve
May 08, 2009 | Hayward H Series Millivolt 250,000 Btu...
Pool & Spa Logo
305 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
