Question about HP Office Equipment & Supplies
I am getting a status report 0050 Tx failure notice. What does this mean please
3 Suggested Answers
FixinFax
  • 3085 Answers
SOURCE: Fax doesn't go thru, on the TX Failure report
No Good, receiving machine never answered.
Posted on Jul 04, 2009
FixinFax
  • 3085 Answers
SOURCE: Getting Error TX Report: Result 'NG' - what does this mean???
It means No Good or Not Good, fax was never received for a number of reasons.
Posted on Oct 07, 2009
INK SYSTEM FAILURE HP 0XC18A0101
Ink System Failure refers to a hardware issue with the printer, however a series of troubleshooting can be tried as a last resort before you get a replacement of your printer.
Try the following:
1. Press and hold the “*” key and then press the “#” key and release both keys.
Now check if there is any message on the printer display, it should display something like "Enter Special Key Combo"
2. Now press and release in sequence the “1”, “2” and “3” buttons.
Now check if there is any message on the printer display, it should display something like "Support"
3. Press and release the right arrow button until the display says “System Configuration Menu”.
4.Press and release the “OK” button.
Now the display should say “Hardware failure status”. If not there already, scroll the arrow Key over to “Hardware failure status”,
5.Press and release the “OK” button.
Now the display should say “Hardware failure status: Clear. Press OK to clear”.
6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
7. Now Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Turn the printer OFF using the power button and unplug the power cable from back of the printer and wall outlet.
9. Wait for 30 seconds and then replug the power cable
10. Turn ON the printer and let it initialize itself. Then try printing a self test from the printer front panel by pressing the SETUP-->Print Report--->Self Test Report.
This should get it working again.
Jun 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
Code 0xc05d1281 inkt problem
Hi there ok
The "Ink System Failure" error is causes by air in the ink feed tubes.
I hope this helps, If so please rate our solution.
Please perform the following steps in order:
1. Press and hold the “*” key.
2. Press the “#” key and release both keys.
3. Display should say “Enter Special Key Combo”
4. Press and release in sequence the “1”, “2” and “3” buttons.
5. Screen should say "support" R0631M"
6. Press and release the right arrow button until the display says “System Configuration Menu”.
7. Press and release the “OK” button.
8. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
9. Press and release the “OK” button.
10. Display should say “Hardware failure status: Clear. Press OK to clear”.
11. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
12. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
13. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
14. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
15. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
16. Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
Feb 07, 2010 | HP Photosmart C6280 Printer
Oct 07, 2009 | Canon FaxPhone L75 Plain Paper Laser
Hard Disk Problem
That failure is predicted by the SMART reporting system. Its a status chip on the drive that reports to apps that can read the smart data from the hard drive. Its not always accurate but it usually is.
Time backup your data on that drive ASAP and then buy a new drive.
Sep 07, 2009 | Toshiba MK1637GSX 160 GB IDE Hard Drive
Wont stop printing TX report!
moz-screenshot.jpgmoz-screenshot-1.jpgmoz-screenshot-2.jpgmoz-screenshot-3.jpgHere are some of the instructions you'll need, but you can also find more assistance by accessing the online Canon support site and searching the exact error message you get. (click here)
ssue:
ERROR LCD: INCORRECT PAPERSIZE
Solution: Reset the unit-IC D/PC 1000 Series
Reset the unit
  1. Slide the platen to the left.
  2. Slide the platen back to the right until it locks in place.
Here are instructions for changing the setting of the tx report:
Issue: How do I change the TX report
Solution: Changing the TX Report-IC D/PC 1000 Series
  1. Press <Additional Functions>.
  2. Use <la.gif> or <ra.gif > to select [FAX SETTINGS], then press <Set>.
  3. Use <la.gif > or <ra.gif > to select [REPORT SETTINGS], then press <Set> twice.
  4. Use <la.gif > or <ra.gif > to select the option you want.
Name Description TX REPORT 111OUTPUT NO
111PRINT ERROR ONLY
111REPORT WITH TX IMAGE
111111ON
111111OFF
111OUTPUT YES
Enables/disables automatic printing of a transmission report. No report is printed.
Prints a report only when a transmission error occurs.
If you select PRINT ERROR ONLY or OUTPUT YES, enables/disables printing of the first page of the fax under the report.
Prints a first page only when a transmission error occurs.
The first page is not printed.
Prints a report every time you send a document.
(The factory default setting is in bold face.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 20, 2009 | Canon imageCLASS D880 All-In-One Laser...
Fax Report Question
i believe it means rx receive and tx transmitt
in rs 232 communication (serial communication modem fax etc) line 2 is tx (transmitt and 3 is receive rx hope that helps
Dec 30, 2008 | Brother IntelliFAX 2800 Laser Fax
I want to have the MX310 to answer on 4 rings
Change the ring count 1. Press the <Menu> button repeatedly until [FAX SETTINGS] is displayed.
2. Use the [ left.gif] or [ right.gif] to select [RX SETTINGS] then press <OK>.
3. Use the [ left.gif] or [ right.gif] to select [ RING COUNT] then press <OK>.
4. Use the [ left.gif] or [ right.gif] to select the desired number of rings. Press <OK> then press <Stop/Reset>.
To print the Activity Report, Coded Speed Dial List, User's Data List or Memory List: 1 . Press <FAX>, then press <Menu>.
2 . Use leftright.gif to select [PRNT REPORT/LIST], then press <OK>.
3. Use leftright.gif to select the desired report, then press <OK>. The report or list is printed.
Try to download the manual
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15603#DownloadDetailAct
I hope it helps!!!
The TX Report and RX Report print upon transmission or reception offaxes depending upon the settings made in [FAX SETTINGS->TXSETTINGS->TX REPORT] and [FAX SETTINGS->RX SETTINGS->RXREPORT], respectively
Dec 08, 2008 | Canon PIXMA MX310 All-In-One Printer
Turn off confirmation page
log into the web administration page as administrator
choose fax/scan tab
report settings
Tx Report
choose turn on/off/if tx fail
I chose both single and multiple destinations
if tx fails
Tested scan to email and fax to bad addresses and page printed as confirmation of failure
No pages printed for successful Tx
Note - you can still manually request confirmation at printer menu
Fax/scan
fax menu
tx report
on
enter
start fax or scan to email
Nov 05, 2008 | Minolta bizhub 200 All-In-One Printer
Report of fax
Hey renzo737 - Follow these steps to have your machine print a report after you send each fax:
1)Hit the Fax button, then the Menu button.
2)Press the < and > buttons to scroll until you reach
TX Settings. Hit OK.
3)Use the < and > buttons to scroll until you reach TX REPORT.
Then hit ok.
4)First you want ATTACH TX IMAGE and then you want
PRNT FOR EACH TX.(it may also say as TX REPORT)
On your machine under TX report it may just say PRINT ERROR ONLY, which means only print if there's an error, or the PRNT FOR EACH TX. You'll find it easily. You want the print for each tx option. This will print a report and give confirmation that your fax went through after each fax. If you have any problems understandind this or need more help just give a shout.
If this solves your problem PLEASE rate this as fixed. Like I said if you need more help just add a comment and I'll be happy to assist you further. Thanks and have a good one.
Jeff
Jun 30, 2008 | Canon PIXMA MX310 All-In-One Printer
3,100 people viewed this question
Seeker5211
Seeker5211
