My washing machine belt is off how could i put it back on? thanks
  • 10,515 Answers
As you never mentioned the Make and Model, so let me offer a Generic Solution that would help you :-
  1. Move the washer out from the wall so you can remove the back. You may need another person to help move it because it is full of clothes and water. It would be easier to take the wet clothes out and put them in a pail or nearby laundry sink and then try to bail or pump the water out. It will be a messy operation, but easier in the long run.
  2. Step 2 Remove the back of the washer. Use screw drivers, nut drivers or hex head wrenches to remove the screws or fasteners on the back casing of the washer. Don't forget to unplug the washer from the electrical socket first. If it is a gas dryer, remove the hose from the gas line and temporarily cap off the line at the wall. Be very careful with gas lines and be sure they are capped off securely.
  3. Step 3 Find the belt. Belts are usually easy to find. They look much like fan belts in cars or belts in vacuum cleaners. A damaged one will be easy to spot. It will be broken altogether or so loose from wear that it does not grab the pulley and turn the washer drum.
  4. Step 4 Loosen the bolt on the motor bracket. Use a crescent wrench for this job. In a pinch a pair of pliers may do. Move the motor to put slack in the belt. Even if the belt is broken, you will still need to move the motor to install the new belt.
  5. Step 5 Remove the old belt. Stretch a new one into place on the pulleys.
  6. Step 6 Put tension on the new belt by using a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. Leave about 1/2-inch of slack when you press it in the center. If it is too loose, it will slip on the pulleys. If it is too tight, it wears quickly and may start to smoke or burn.
  7. Step 7 While you are in there tighten the pulleys by checking and tightening set screws all around the pulley hub. You may forestall another problem in the future by taking care of pulleys now while it is convenient.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 10, 2009
How do i change a belt on the motor its a top load it looks like the front comes off put I can't find the right wrench
Hello, to change the belt follow the following steps:
1. You have to take back off,,always unplug first..
2. Just remove the back and take the screws out all the way around back,,
3. Put belt on motor .
Thanks
Jun 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Loud grinding noise when spinning. So I layed the machine down on its front to work on it. I loosened the belt, and then removed the lint catcher pump. I cleaned the pump by flushing and reverse flushing...
Just so you know, in the first place, (NEVER PLACE A WASHING MACHINE IN ANY POSITION BUT UPRIGHT. That's just asking for a leaking gearcase (transmission)! Your best bet is to call a technician. It sounds more like stress on the drivetrain from the water weight! The only way to tell would be to pull the case off to observe the tub as the water fills to see if the tub is indeed pusing downward!
Dec 16, 2009 | Maytag Performa PAV2200
How to put a belt on
remove lid and bottom cover 2expose moter pully lean washer towards u pass belt down and put over motor pully then start putting on drum pully can b very tight good luck
May 03, 2009 | Washing Machines
Replacing belt
Put The Belt On The Motor First Then Put What You Can Get Of The Belt On The Other Pulley And Turn It. It Will Give You The Anchorage Needed To Put The Belt Back In Position. If This Doesn't Help Let Me Know And I Will Further Assist You.
Sincerely,
Michael Scott
Feb 10, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Washin Machine Spinning Problem
The main tub bearing is stuffed, thus the noise. The spindle becomes loose and the belt rides off. Bearings can be replaced.
Hope that helps.
Sep 07, 2008 | Hoover AL130 Front Load Washer
How to put the belt on,
there is no way of tensioning the belt so it is a very tight fit
put belt round motor pulley first then start belt on large pulley and turn large pulley by hand and it should go on
Jun 24, 2008 | Washing Machines
How to replace the belt on a Samsung J845 front loader washing machine
Its on the back of machine and after you remove the back cover plate youll see that its very easy to install the new one.You shouldnt have to use any tools to put on the new belt.Just loop it around the motor pulley and around the large tub pulley that you see right in front of you.It may even appear to be too tight while your winding it on the pulleys but its not .
May 20, 2008 | Washing Machines
Samsung b1445s washing machine
hELLO
HAD THE SAME PROBLEM LAST WEEKEND! THE BELT HAS TO BE SO TIGHT TO GET THE WORK DONE
PUT THE BELT ON THE BUTTOM SMALL WHEEL OF THE MOTOR THEN YOU VERY SLOWLY PUT IT ON THE BIG WHEEL BY TURNING SIMOULTANISLY THE BIG WHEEL CLOCKWISE, IT SHOULD I YOU ARE CAREFULL POP_UP AFTER A SEMI TURN,THAN SLOWLY TURN WITH YOUR HANDS THE WEEL 2 OR 3 TIMES AROUND SO THE BELT CAN FIND ITS PLACE;
hOPE YOU GET IT DONE
GREETS FROM bELGIUM
MY MAIL SMIEGEL@TELENET.BE
Apr 08, 2008 | Washing Machines
How to get back off to put belt on samsung b1445s washing machine
See if the motor has adjustment , ie a slotted fixing hole, slacken the fixing bolts slightly and motor may move up and down to give adjustment, put the belt on and then put some tension on the belt once fitted by moving the motor down and tightening the motor bolts at the same time.
Or if no adjustment put the belt on the motor spindle first and then the drum by turning the drum as the belt is eased onto it.
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
