Question about Whirlpool Duet GHW9150P Front Load Washer
Water pump problem
I can't find any user or resource for whirlpool washer 8.5 kg top load wwd 22 washer... help
    President:
  • 1,653 Answers
Is the exit pipe blocked? Have you made sure that the filter is not blocked? Can you hear the pump working or does it sound strange or silent?
If these are OK then you may have a genuine water pump problem then call a service engineer. If you are competent to do so and have the tools make sure the power is turned off and the inlet water feed is closed off, then remove the water pump yourself and check that it works and is clear of any obstructions. Also check that the feed pipe to the pump from the drum is not blocked.
Posted on Sep 10, 2009
2 Suggested Answers
  • 105 Answers
SOURCE: My 7.5 kg top load Whirlpool Washer will rinse and
Best off to call a reputable service company such as Sears.
Posted on Feb 06, 2010
Hello, what is the capacity of Kenmore washer 110.28803890 in kilograms? Thanks
As a rule of thumb, 12 pounds of laundry is appropriate for a standard capacity top load washer, 15-18 pounds for a front-load washer, and 20-22 pounds for an extra large capacity front load washer. 1 lb.is .4536 kg so 15*.4536 is 6. kg. 18*.4536 is 8.17 kg.
Mar 13, 2018 | Kenmore Washing Machines
Dear sir, We want to buy 02 nos of whirlpool make 8.5 kg washer 02 nos and one nos of dryer. We need the same for our factry on contineous operation so we want the best...
Hi and welcome to FixYa, I am Kelly.
I understand you want a whirlpool washer. What are you washing? It does make a difference on what would be recommended. The other question is does it have to be a front load machine or is a top loading washer ok?
Right off the top of my head for an 8.5 kg washer I would recommend the top loading MAT Series by Maytag (owned by Whirpool) These manual timer machines can take a beating and over loading only causes belt wear that is inexpensive and easy to replace. The only drawback is that the top loading machines use more water per cycle than a front loading machine. My thought is this... water is cheap... smaller front loading commercial machines used in continuous manner end up costing you more in repairs than you would pay for the water.
Product info: http://www.maytagcommerciallaundry.com/on_premiseslaundry/top_load_washers/commercial_energy_advantage__8482__top_load_washer_mat15mnaww.pro?scr=category
Once you see the linked pages select "on premises lanudry"
What I will tell you about commercial laundry machines is this. Keep the controls simple such as the MAT series. Maintenance parts are available on line and your down time will be minimal. The Maytags have the best warranty also.
As for the dryer Gas or electric? I am going to assume electric since you said "Factory"
For this I would recommend the MDE17 series Dryers, The dryers are 4 roller drum type dryers so the weight is carried equally front and rear of the drum so that the drum seals have a very long life.
I have been a Maytag repairman since 1970 and started in a family owned business. These recommendations are from years of experience. You may pay more up front on the initial purchase but over the years the continued in service time and minimal maintenance required make these units extremely cost effective. If I were to start my own business with 8.5 Kg per cycle washing requirements The MAT Washers and MDE Dryers Maytags are exactly what I would use.
Remember Maytag was purchased by Whirlpool years ago.
All Maytag parts can be obtained through Whirlpool.
I do wish you the best, Thanks for choosing FixYa,
Kelly
Dec 12, 2010 | Whirlpool Washing Machines
Hi i want to know that a waight of 6 kg washing maching is a small one for cloths or it is ok . should i go for more than 6 kg. for 4-5 persons family. thanks.i just choose a whirlpool compact model of...
Your question is not easy to answer. An average washing machine is 8 kg. The smaller 6 kg will use less water and detergent, but you will be limited to 4 or 5 pair of jeans at one time...unless your children are small. A front loading machine may be a better choice for you. It can do very large loads, 12 kg, and still use less water and detergent than most top loaders, but be prepared to pay three times the price of a top loader.
Sep 20, 2010 | Whirlpool Washing Machines
My whirlpool duet front load washing machine stops in mid cycle
F21 = LONG DRAIN ERROR
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
Procedure:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Pump is not starting to pump water out of whirlpool ultimate 2
I suggest you purchase a lid switch from a local supplier of parts or call a local servie tech if it's just the lid switch it should not take a tech long to change it.
Dec 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool top loader 9 kg - I can't see any serial no.
There are no lint filters on this machine. The lint is pumped out with the water. There may be a restriction in the drain line starting where it connects to the tub or the small drain holes in the inner tub may be clogged.
Jan 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool AWM6120 Front Load Washer
Cleaning depends on use. 8 years is a bit over the top! When your water does not drain, check the outlet filter first, then the pipe from below the tub to the filter. Your washer wont spin 'cause the pump/filter is blocked.
Jul 24, 2006 | Whirlpool AWM6120 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
