Question about Panasonic Microwave Ovens
My panasonic nna770s combi microwave cuts out after 3 seconds during this time the turntable doesn't turn, any ideas?
  • Panasonic Master
  • 9,098 Answers
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If you;'re not in the US or Canada, see the support or service links at www.panasonic.net.
Posted on Sep 11, 2009
I have a 18mth old Panasonic dimensions 4 invertor microwave oven that turns on for 3 or 4 seconds and stops altogether,any ideas?
What does the clock say after it stops? Is the time still correct, or is it wrong? Or maybe you mean only the turntable stops spinning, in which case the problem may just be that it needs a new belt! Try RepairClinic.com if that is the case!
May 16, 2017 | Panasonic Microwave Ovens
My turntable on Panasonic NNA883W combi oven has stopped working is it easy to fix it just freely turns with no resistance
Usually underneath the plate is a square or triangular spigot which should fit into the plate recess these are usually plastic but some are ceramic in combi ovens and are prone to breaking.if you can't lift out the spigot from inside oven to inspect...then you may need to gain access the the bottom of microwave.always disconnect appliances from power supply before removal of internal/external parts.
Feb 28, 2015 | Panasonic Microwave Ovens
Sharp R-405H microwave turntable doesn't rotate and makes strange noise
Replace the turntable motor, it is defective and will only get worse.
Mar 17, 2012 | Sharp R-405H 1100 Watts Microwave Oven
Turntable wheel under glass tray broken
If the microwave comes with a roller ring to rotate the glass turntable then I would recommend that it needs to be used when the microwave is operating, as the turntable rotates the food so it can be heated evenly.
I would recommend checking with your local Panasonic repairer he may have access to a new roller or even a second hand one to tide you over.
Mar 20, 2009 | Panasonic Microwave Ovens
I have a panasonic NNA883w combi microwave oven. The microwave part has stopped working. The unit dows not turn switches off after three seconds without warming anything. The oven and grill elements still...
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these inverter-based models.
Sep 25, 2008 | Panasonic Microwave Ovens
Panasonic Microwave Problem
Even though these are different symptoms, the same part may be causing both.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
Sep 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
In most cases, this is a problem with the inverter or a bad magnetron.
I would recommend that you contact your nearest Panasonic-authorized servicer.
You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Oct 24, 2007 | Microwave Ovens
3 second cooking time
It's possible a sensor or thermistor got unplugged during your work and didn't get plugged back in. Otherwise, I would suspect the microprocessor got "glitched". If so, *maybe* unplugging the oven from the power line for a few minutes will reset it. Or maybe the unit has a reset button or another reset procedure (I doubt that, but check the manual). Sadly, another common cause for this is that the code in the microprocessor gets irretrievably corrupted. In such cases, we can replace micro if it is available. It it's no longer available, that would make the whole microwave a goner. Looks like both the micro (LSI display) and the whole control board for this model are available from Panasonic parts: http://www.pasc.panasonic.com/epartr
Sep 27, 2006 | Panasonic NN-S954WF Microwave Oven
Microwave Ovens Logo
633 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
