Question about Microsoft Windows XP Professional
How to fix remote connection? - Microsoft Windows XP Professional
  • Karl Wright
    Karl Wright May 11, 2010
    What is the actual problem and has this worked Ok before? Also what have you done since it last worked?
    Scholar:
  • 150 Answers
The main cause behind this problems is some problem in the registry entries at the following path:
HKLM\System\CurrentControlSet\Services\TermServices\Parameters
Follow the procedure below to fix it. 1. Open Start >> Run and type regedit and press enter.
2. Navigate to the following path:
3. Now delete registry keys named Certificate, X500 Certificate and X509 Certificate ID values. (These keys will get auto generated after system restart with system default values, which is actually needed)
4. Exit Registry editor and restart your computer.
5. Try to establish a remote desktop connection by typing mstsc at Run Prompt.
Regards,
Anirban Mazumdar
http://www.ikarmatech.com
Posted on Sep 10, 2009
  • 284 Answers
It depends on the problem you are having.
Most often remote connection problems are caused by firewalls
Are you trying to connect across the internet or are your two machines on the same LAN.
Are you only running windows firwall or do you have a third party firewall installed.
I suggest you run off the firewalls first and try to connect on the LAN and then add things back in one at a time until you solve the problem.
There may be more than one thing blocking you.
I hope this helps
I have a Rheem tanklees water heater, model RTG-74XN-2. The remote shows the following error code. C4 then the number 76 then C4 then 76. What does this code mean??
Contact Paloma/Rheem 866-720-2076. Super nice! I just called regarding mine. Having same problem Rheem Paloma sending parts out tomorrow overnite. Try turn it on/ off by moving tiny switch under the unit that tells you the temperature. Run your fingers along the bottom to find it. That is a temporary fix. Below is a website with all the error codes, so you know what is wrong. Good luck and blessings!
http://www.palomastore.com/paloma_error_codes.html
76
Communication Fault with Remote Control Check remote control wiring for loose or damaged connections. Bypass remote control cable by connection remote directly to remote control terminals on PCB (replace cable if found to be faulty). Replace remote control. Replace PCB
76
76
76
Nov 06, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Remote freezes
Hi. If your remote is freezing, you should try updating the firmware from safe mode.
1. Take out the battery, press and hold the "OFF" button, and re-insert it. The remote will display "Safe Mode".
6. Connect your remote and log in to your account.
7. Click "Downloads" at the top and select "Firmware". The firmware on the remote will update.
8. Click "Replace Remote" to conduct a connectivity check.
9. Update the remote.
That should fix it!
Mar 23, 2010 | Logitech Harmony 1100 LCD Touchscreen...
Harmony One USB Connection Problem on Vista PC
HI. So there are a couple of things you will have to ensure for the connectivity to be successful.
1. You are not connected to the internet via a router
2. You are not on a wireless network
3. Any firewalls on your computer are disabled
4. Your USB cable and port are good, and the remote is not connected to a USB hub but right into the compter.
Now, please do the following:
1. Uninstall the software
2. Download it again at http://logitech.com/myharmony
3. Install
4. In your computer's add/remove programs, uninstall the Logitech Desktop Messenger
5. Take out the battery, press and hold the "OFF" button, and re-insert it. The remote will display "Safe Mode"
That should get the remote working. :)
Mar 07, 2010 | Logitech Harmony One Advanced Universal...
My harmony 550 displays safe mode . how do i fix it?
Hi . Here's how to fix it and get your remote out of safe mode:
1. Connect your remote to the computer.
2. Launch the Harmony Remote Software, and log in.
3. Click "Downloads" at the top and click "Firmware"
4. The remote will go through the firmware update.
5. Select "Yes", and click NEXT to update the remote.
Voila! Hope this can help
Feb 03, 2010 | Logitech Harmony 550 Remote Control
Hi there i have a logitech harmony 520 remote and my son spilt some soda on it. now the lcd display is blank all the time even when a button is pressed, but when i connect it to my pc via usb it flashes...
Please apply the following troubleshooting steps to get the LCD screen issue resolved:
1- Remove the battery from the Harmony Remote for 10 seconds and insert it back in, and test the remote to see if the screen is displayed properly. If this does not fix the issue, please proceed with the following steps.
2- Make sure you have the latest Logitech Harmony Software (version 7.6.0) installed on your computer.
3- Connect your Harmony Remote to the computer. Run the Logitech Harmony Remote software on the computer and Login to your account.
4- Click on the "Downloads" button at the top and select "Firmware"
5- Remote will go through the firmware update, which will put the Harmony Remote back to Factory Default with the most updated firmware. Then software will ask you to select "Yes" to update the remote and click on "Next" to do a remote update, which will take the information on your account with your Devices and Activities and bring them into the Harmony Remote.
6- If this Firmware Update process does not fix the LCD screen issue, try doing a Firmware Update in "Safe Mode". To do this; remove the battery from the remote, press and hold the "Off" button on the top of the Harmony Remote and insert the battery back in to the Harmony Remote. Screen will display "Safe Mode" and then please follow the steps 3 through 5 again.
If this doesnt fix the problem i suggest you contact logitech. when contacting them, do not tell them your son spit soda on it:
Logitech's Warranty is:
Nontransferable to other users and limited to the original purchaser
Valid from the first date of connect to the Logitech Harmony Remote software for a period of time determined by region
Cases not covered under warranty:
Damages caused by:
Accident
Abuse
Misapplication
Unauthorized repair
Modification or disassembly
Improper operation or maintenance
Connection to improper voltage supply
Jan 17, 2010 | Logitech Harmony 520 LCD Remote Control
2nd wii remote wont connect
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Dec 28, 2008 | Nintendo Wii Console
Wii hand held remote
Aug 22, 2008 | Nintendo Wii Console
No connection remote and
Replace batteries, making sure they are the right way round,
Press red button near the batteries in the remote,
press the red button behind the flip open panel on the front of the wii console.
This should synchronise the two, if not, then try with another remote.
Jan 19, 2008 | Nintendo Wii Console
Microsoft Windows XP Professional Logo
73 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
