Question about Panasonic Cameras
My Panasonic VSK0651 charger isn't charging my battery
My VSK0651 appears not to be charging my battery for my Panasonic camcorder. The break out power cable from the charger does work so I know the correct voltages are being generated by the charger itself, but the battery does not work after a long time on the charger. The charger pins where bent after a trip away, and now I've striaghtened them the battery does charge, There are four pins on teh charge labelled +, -, T and D.
Does anyone know what the T and D pins do?
I'm guessing that the charger does not sense correctly that a battery is present, or the battery can not signal it's charge level.Any experience/help would be greatly appreciated.
  • 624 Answers
SOURCE: Camera won't charge
It could be the batteries but my bet is the charger is bad. If you have access to another charger try using it instead. I just had a similar problem a month ago where my charger pretended to work but never really put much of a charge on the batteries.
Posted on Jul 24, 2007
SOURCE: battery not charging
well i called the casio hotline that was on my camera box and they told me if i sent the bad battery to them, they would send me a good one back. he said that they had had some problems with the lithium batteries. have you tried calling? he didn't even ask about a warranty...
Posted on Sep 05, 2007
SOURCE: Motorola E815 - Battery Charger
The E815 has a very poor design on the charger port. The cleaning that Solution #1 referred to is that Verizon cleans the contacts of both the phone and the charger using rubbing alcohol on a toothbrush to clean both the phone contacts and the charger contacts. I have to do this once a week or so to keep my phone charging. The rubbing alcohol dries quickly and will not harm the phone. Motorola has changed the charging ports on the newer phones because they recognize that they have a problem with this design. I have also turned in my phone to Verizon (twice) for a replacement. If you replace the phone be careful to record ALL your contacts because when Verizon transfers your contacts from the old to the new phone the speed dial numbers all get messed up because they start their numbering differently than you had it. I am still repairing my speed dial numbers. Hope this helps.
Posted on Sep 07, 2007
SOURCE: not able to charge battery
This happened to me also. In the manual it says the flashing light means that the battery/charger needs to be cleaned, or if that doesn't work, it is dead. My husband called customer service and they actually sent us a new battery which we recieved within a few days. The number is 1 800 706 2534.
Posted on Feb 03, 2008
SOURCE: what voltage required to power a sony subwoofer
Hey,
I just got one of these units, the SONY SS-WG990.
The RCA cable is direct conection to the speaker.
It requires external AMP.
The other cable is just for the system switch and LED.
If you just have this unit, all you need is an AMP to
feed it.
Posted on Sep 20, 2008
I have a PV-IQ404 Panasonic Palmcorder that the power pack has been lost from. Can this be replaced?
By power pack do you mean the actual battery or the charger unit that plugs into the wall to charge or power your Palmcorder? Either way, bot are available on Ebay as universal units and you should make sure the charger or battery pack is for or a 6 volt capacity. Many chargers for these Palmcorders are labeled as VHS-C / 8MM, that should work with your camera. Universal battery packs are made reversable, meaning that you can flip the battery to accomodate several other camcorder models. I've replaced my batteries and charger for my Panasonic Palmcorder from Ebay.
Dec 06, 2014 | Energizer Panasonic Pv-iq404a Camcorder...
CAN I CHARGE MY PANASONIC MINI DV CAMCORDER AND OTHER WAY THAN THE CHARGER ITS SELF
I don't get your question, but there are different ways you can charge it. You can charge the battery alone against the wall, leave it in the camcorder and charge it via computer, wall, or car.
Sep 06, 2011 | Panasonic NV-GS120 Mini DV Digital...
How i can finalize my vob file that i filmed in panasonic camera vdr d100
Need to provide power from ac charger of camera so disc finalize option will appear to finalize disc.
Powering camcorder with battery wont give you Finalize option so use ac charger to get Finalize menu.
Thanks.
Dec 25, 2010 | Panasonic VDR-D250 DVD Camcorder
Hi My Panasonic vsk0651 battery charger is not working, can it be repaired or would it need replacing. Can you advuise where I can take it near Eastern Creek or Menai in Sydney Australia. Thanks
Just replace it. There's nothing user-serviceable inside and if you get a professional repair it will cost more than a replacement. If your power lead has a fuse then check that, but fuses usually only blow for a good reason.
You can buy an equivalent model from Amazon Australia for just AU$8.87 (plus shipping).
Good luck and please take a moment to rate my answer.
Sep 13, 2010 | Panasonic Cameras
Charging Panasonic NV-DS38
Yes that is correct.
You have to use a separate charger as the "DC in" socket is on the camera body underneath the battery.
Jul 21, 2009 | Panasonic NV-DS38 Mini DV Digital...
Panasonic ds27 camcorder charge
It could need a new battery.  The battery can't hold a charge in it anymore.
Sep 18, 2008 | Panasonic NV-DS27B Mini DV Digital...
Instruction manual
Your specific manual is here.
You can find Sanyo UK owner's manuals here
Sep 13, 2008 | Microwave Ovens
Cameras Logo
882 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
