Question about Cell Phones
Problem getting sd card to work
I have put the sd card in the slot and put it in the right way. but when i turn my phone on i cant seem to find how to store things on the card.. please help
    Problem Solver:
  • 12 Answers
First Format your SD card and Try it.
If this doesnot work, Check with your phone dealer that the SD card memory capacity can be used. Some phone only accept memory card upto 1GB.
Posted on Sep 11, 2009
Micro SD slot in my Kyocera Hydro isn't reading Micro SD card
test the sd card on your pc first to see if it works before you put it into your cell.
Apr 16, 2013 | Kyocera X-tc Cell Phone
ZTE Merit Z990G how to install sd card
turn off phone, remove back cover. to the left of the sim card is a metal bracket with a slot in middle of it. take fingernail put in slot and push towards camera lens slightly, will release its catch then can flip it up and install mirco sd. sd card has a lock point on one side of it, sticks out from the side if the card, it will point to your right, will see where it fits in card holder, put bracket back down and lock back in place to hold card in. Put back on it and your done.
Jun 27, 2012 | Cell Phones
Cant find directions. Frame uses sd card. how do i get pics to card. I think i have the right cable at least it fis
You load the pictures on to a computer that has a SD card slot and down load the pictures to the SD card and then put the SD card in your Frame where they can be displayed.
Dec 29, 2010 | Cameras
Cant transfer photos from phone to computer
Does your phone has an installation CD?If it doesn't it will not work.So get an installation CD i.e Samsung PC suit before you can transfer photos..take care.
Feb 11, 2010 | Cell Phones
SD card does not seem to fit in the SD card slot
Is the SD card a mini type or a standard SD card?
The standard SD card is 24mm wide X 32mm long.
If it is a mini SD card you need to purchase a mini SD to standard SD adapter, then you will be able to insert it in your Compaq.
Aug 13, 2009 | HP Compaq nc6230 Notebook
I hav htc t-mobile wing i have inserted micro sd card in the sd card slot of it but in the storage card memory it says "total storage card memory : not installed" i have also tried other cards (witch...
Take out the SD card.Turn off the phone and take out the battery. Now insert the new SD card and then insert the battery. Turn it on and then new card should get detected.
Aug 08, 2009 | T-Mobile Wing™ Smartphone
Cant find music on micro sd (while in gzone) card that has music on it
dear,
did u check your sd card in card reader through pc..or by putting it to another phone..
check it plz... if it works in any condition then its mean your phone card slot has problem and if it doesnt work at all then its mean the card has damaged..
regard,
hope it will fix the issue
Jun 02, 2009 | Casio G'zOne Boulder Cell Phone
GPS CAN NOT FIND MAP DATA FILES
I had a similar problem with a nextar X4-T, which has it's maps on an SD card. If your GPS uses an SD card for it's maps, you can try this:
You will need a computer with an SD slot, and running Windows Xp. I tried the following method on a computer running Windows Vista, and it did not work. I tried again on an older Xp machine, and it worked first time.
  1. Put the SD (Map) card in the computer's SD slot.
  2. Open Windows "explore". (RIGHT click on "Start", then select "explore"
  3. Locate your disk on the file menu.
  4. RIGHT click on the map disk
  5. A menu pops up.
  6. At the bottom of the menu, select "properties"
  7. Another menu pops up, with several tabs along the top.
  8. Select the tab that says "tools".
  9. In the "error-checking" section, select "Check Now"
  10. Another menu pops up.
  11. Select the box that says 'Automatically fix file system errors".
  12. Click "Start"
The program will only take a few seconds to run. If it works, you will see the file directories of the SD card display on the "Explore' screen. You can then put the SD card back in the GPS, and see if it works.
Good luck.
Apr 17, 2009 | Nextar X3-03 Car GPS Receiver
Micro sd and 6133 cant be found anywhere in my phone.
As I understand the problem, seems that the phone was unable to detect the MicroSD card, right?
There could be a problem with the memory card or with the card slot on your phone. To isolate the problem, try the steps below:
1. Insert the MicroSD card in to different cell phones to see if other phone will detect it.
2. Try using another MicroSD card into your phone to test if the card slot is working correctly or not.
Apr 08, 2009 | Nokia 6133 Cellular Phone
Where do you put the Micro SD card in a Motorola V3 Phone.
It depends on your carrier or phone model.
Verizon Wireless still uses the CDMA network. CDMA gets the phone user ID from a programmed chip hardwired to the phone instead of a SIM card.
Because of this, there is room underneath the battery cover, south of the battery on the right side of the compartment for a mini-SD card.
Other carriers such as T-Mobile, Cingular/AT&T DO use SIM cards to store user ID, so there is not room for a memory card.
I do know that the MotoRazr2 V9 from AT&T DOES accept Micro-SD cards.
But if you have a GSM carrier such as T-Mobile or AT&T, the Razr V3 does not have a card slot.
Mar 03, 2008 | Motorola Mobility RAZR V3
Cell Phones Logo
57 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
