Question about Pitco Frialator 35CS Deep Fryer
Lazy lighting Our deep fryer is slow lighting the main buners. The pilot light is fine but the buners sometimes takes 60 seconds to come on.They come on normal no explsion.
    Problem Solver:
  • 7 Answers
Check incoming gas pressure, you may also need to clean out gas orafices. make sure you have the right orafices installed(nat or LP)
Posted on Sep 18, 2009
How do i get the pilot light to remain lit on my new SLG100 Anets deep fryer
Did you hold the pilot light button down long enough? It takes between 20 seconds - 1 minute to properly heat the thermistor before you can turn the switch to "On".
Mar 04, 2016 | Anets SLG100 SilverLine 100 lb Commercial...
Deep fryer pilot light switches off automatically
First make sure that the thermocouple tube is directly in the pilot light flame. If it is, then the thermocouple is defective.
May 04, 2014 | Frymaster Dean SR42G Deep Fryer
I light the pilot everything is fine then when i go to turn thermostat on pilot light goes small and burners dont light and when i turn back to pilot the gas ignites and goes out
Sometimes certain models turn off if you touch the thermostat before it lites...
We've seen this happen many times, so you would need to light the fryer first, wait until it's stable before turning your thermostat to desired temperature.
Sep 02, 2011 | Pitco Frialator 35CS Deep Fryer
How do you re-light pilot light
Turn the knob on the gas valve to the pilot position. Sometimes you have to slightly depress the knob to turn it..don't use a pair of pliers. In the pilot position.. push the knob in and light the pilot..keeping the knob pushed in for 30 seconds. Let go and the pilot should stay on. Turn the knob to the on position and set the thermostat.
Tom
Aug 02, 2010 | Imperial IFS40 Deep Fryer
Pitco frialator (propane)
Better check the incoming gas pressure first, it should match the requirement as stated on the nameplate. Low gas pressure will make the pilot flame small until it could not heat up the thermopile which will shut both main burner and pilot flame.
Apr 11, 2010 | Pitco Frialator SG18S Deep Fryer
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
I cant find the way on how to light uo the friar.
If you have a pitco 35 fryer, all you need to do is have gas connected and turned on, rotate the know on the gas valve to the pilot position, depress the knob, while holding the knob down light the pilot, normally located in between the burner tubes in the middle of the front of the fryer, hold the knob for 60 seconds, when you release the pilot should remain on. If it does rotate the pilot know to the "on" position, from this point the thermostat should control the fryer. If your pilot does not stat lit, press the red button on the hi-limit to reset it, it could be tripped and this would cause the pilot to not hold. Hope this is helpful.
Mar 18, 2009 | Pitco Frialator 35CD Deep Fryer
Imperial fryer IFS-40
I had a very simular problem. My fryer would do exactly as you described, but sometimes the pilot light would stay on until the burners tried to re-ignite and then it would go out.
I finally had to call the gas company. They took the pilot light apart and cleaned it. The fryer works perfect now.
Hope this helps!
Ken
Oct 18, 2008 | Imperial IFS40 Deep Fryer
Imperial fryer
If your pilot lights up but the main burner doesn't light up then you have a bad pilot sensor or gas valve
Sep 16, 2008 | Imperial IFS50 Deep Fryer
Imperial Deep Fryer won't light
The pilot should not lower on main valve opening, this is a dangerous situation and should be handled by a pro.
Aug 08, 2008 | Imperial Kitchen Appliances - Others
Pitco Frialator 35CS Deep Fryer Logo
83 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
