Question about Garden
How do i turn the revs down on a petrol flymo L47?
Why wont my Flymo qs 46sd rev ?
does it have a throttle cable fitted?? you really dont need an idle as as soon as you release the opc or dead mans handle it will cut out anyway. engine should be reving at 3000-3100 rpm. if this mower has a briggs and stratton engine fitted, remove the air filter and check the spring and linkege is still attached to the air vane govenor
May 20, 2014 | Garden
Flymo 46s won't start. Starts to fire when turned
Possible blocked air filter, try as a test running the engine with filter removed, if ok replace with new filter.
May 02, 2012 | Briggs & Stratton Garden
Petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Jul 03, 2011 | McCulloch Heavy Machinery
Flymo petrol mower starts but won't tick over.....keeps cutting out
Probably needs the carburetter cleaned out. Smell a lot of petrol? could be flooding out. Starts up but dies. No smell of excess petrol? Fuel line clogged at tank inlet, rust? Other crud? Gas gets to carb, engine starts then runs out of fuel. I dont know the flymo carb, but generally...
Start by removing the bowl under the carb, 2-3 screws. Youll need to remove the air filter box first. You should find a float tank which operates a needle valve. This can be released by popping out a pin pivot. DO NOT LOSE THE NEEDLE VALVE which will come out with it. A pointed stem which closes the fuel as the float rises. If you see a lot or just a little crud around here, that can be the problem. Clean it out with carb cleaner spraying up into the where the needle seats, also spray into every opening you see. Carefully replace the needle and float. The needle generally snaps into or is locked into the float loosely, then pin the float back in place while guiding the stem back into its hole. Replace the bowl and try to start it.
Good luck
Jun 05, 2011 | Garden
My flymo briggs & stratton quick silver 46d
Your carb needs to be taken apart and cleaned
Jun 19, 2010 | Briggs & Stratton Garden
My flymo petrol grass cutter will not start after 6 months in the shed its dry but i have left petrol in it and it has oil in it up to the full level
Man! A mower that flies?
You probably have gummed up the carb because it was stored too long without a fuel stabilizer..
Apr 12, 2010 | Garden
My flymo gl47 does not get up to max revs,any ideas? Flymo starts but is running slow.
you can adjust the rpm on the carb underneath the fuel tank
Mar 06, 2010 | Garden
No priming bulb on flymo petrol mower
hello
if JLO engine (normally silver colour) the primer is on top of the carb you press it down
if tecumseh (brown colour) the primer is on the bottom of the carb and you press it up
hope this helps
Mar 15, 2009 | Garden
I am looking at rebuilding a petrol flymo ( Model L300)
hello
go to a web site called diplodocs.com and type in flymo L300
it as the parts list on there
hope this helps
Mar 11, 2009 | Garden
Garden Logo
105 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
