Question about Neff B1476 Pyrolytic Stainless Steel Electric Single Oven
Pyrolytic cleaning won't start. Neff B15P42.0 GB
My Neff won't start it's pyrolytic cycle when selected. The oven beeps when i turn the temperature dial to start the pyrolytic cycle. The oven is empty.
You have to remove the shelf supports (left and right) as well as the shelves. The manual tells you about the shelves but not the supports. I only found out as someone wrote the answer on another website
Posted on Aug 28, 2010
Can anyone tell me if my Neff B1451 is a 13a oven or not.
if its a single not double oven and is not a pyrolytic cleaning system it will work on a 13 amp supply.
Jan 02, 2017 | Neff Ovens
Tip
If the door is locked shut after self cleaning
- Let the over cool down - unplug at the mains and leave it unplugged for a good minute or so - reset the clock The door may well open now. It happened to me today !
on Aug 13, 2007 | Neff B1476 Pyrolytic Stainless Steel...
How do I clean the electrolux oven? It won't start after i take the racks out
As you did not specify the exact model I assume that this is a self-cleaning oven, in other words with pyrolytic cleaning. It has a microswitch which is activated by removing the racks and just because that you can not run the pyrolytic cleaning otherwise racks would be destroyed. Do not forget that the temperature during pyrolytic cleaning is app. 500 degrees Celsius. For that reasons the oven door is locked when temperature increasing to app. 300 degrees and unlocked when the temperature decreasing to the app. 200 degrees. It is clear that when you remove the racks only program that you can run is pyrolytic cleaning.
Dado
Oct 10, 2014 | Electrolux ICON Designer E30SO75ESS Oven
When the pyrolytic function is switched on the oven starts the process then after about ten minutes the code f1 appears on the digital control panel and stops
Hello katefreeman1 - Typically error code F1 indicates that the range has detected an issue with the runaway temperature (overheating). A certified technician will need to check the RTD sensor probe and/or EOC and replace if necessary. Try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart range. Usually this will clear most false error codes. If it proves to be ineffective, contact a professional to move forward accurately.
Jan 22, 2013 | Electrolux EOC6690X Pyrolytic Electric...
Neff B4562
Engineer is a solution.
The other solution is;
Switch 3 times between rotisserie and pyrolysis or bread baking setting and pyrolysis.
As acknowledgement the displays are actuated.
At each change of operating modes switch immediately stops the current test step and the next step of the test enabled. The oven light should according to the mode ON or OFF; that is, at pyrolysis OFF otherwise ON.
Jul 01, 2012 | Ovens
Mile Pyrolytic Oven got a PY flashing
Mine is doing this too. Did you find a solution?
Apr 05, 2012 | Miele Ovens
Oven door is locked
its pyrolytic. if it hasnt finished embering the insides of your cooker (And usually meal) then the pyrolytic lock has failed (usually due to the pyrolytic 500* heat)
Feb 21, 2010 | Maytag Ovens
Neff B4562 Pyrolytic Cleaning Not Working
You need to remove the rack side supports too. Its not clear in the book as it just says shelves and racks but everything needs to come out the oven.
May 01, 2009 | Neff B1476 Pyrolytic Stainless Steel...
Pyrolytic cleaning fault
fixed very simply just turned off oven at mains turned back on and it worked perfectly!!!!!!!!
Aug 18, 2008 | AEG B5741-4 Electric Single Oven
Neff B1476 Pyrolytic Stainless Steel Electric Single Oven Logo
910 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
