Question about Cameras
When I turn my camera on it Just says camera temprature too high what does that mean?
  • 10,515 Answers
You should try to press the shutter button before the error message comes. This will force the camera to make a picture and operate properly afterwards.
I believe it could be a connection issue.
If problem persist, contact Kodak.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 10, 2009
1993 toyota pick up temperature gauge problem
Or the thermostat might be faulty which raises the temprature at which the thermostat starts to open. Giving a high reading on the gauge. if it gets too hot you might be at risk of blowing a pype or head gasket. If so replace thermostat. Check for a loose wire to the temp sensor as well. See if the radiator fan turns on when temp rises. If not check a fuse or the radiator fan temprature switch might be faulty.
Oct 19, 2014 | 1993 Toyota Pickup
High temprature
Mid way is ok, but u need check thermostat, cheap to replace, also check rad is not blocked with insects, oil ok? Water cap tight? Turn on heat full in car see the temp drop, water pump can be on way out
Apr 05, 2013 | 2006 Nissan Armada
Nashuatec 3732 td gives code 42
that mean thermestor is defective must be changed that due to high temprature thus it's corrupted
Feb 24, 2011 | Ricoh FT5832 Copier
Temprature control
I suggest turn it to lower temperature, so that water won't drip down. You can get rid of the hardness by keeping those things out of the unit for about half an hour before using, so that it may lose some coldness and become soft.
Jul 05, 2010 | Fisher and Paykel Active Smart® E522BR...
Installing a Konica Bizhub C450 fusing unit ... need installation booklet
My machine had an error  3752 which means high temprature and pressure on fusing I turned it off for about 2 days now that i turn it on still its showing 3752 error pleas help me what this mean and what should i do?
May 12, 2010 | Konica Minolta bizhub C250 All-In-One...
Air conditioner will not cool
check the thermostat is set on cool set temprature at low 18 if still not ok check the compressor is on with the condenser fan if are operating means there is a loss of charge if not operating and the compressor temperature is high replace the capacitor and restart.
Sep 03, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Camera wont start
For this problem do the ff:
  • this is a Health and Safety issue which kodak advice the users to call the tech to help them with this
  • the tech number is 1800 235 6325 op12 op2
Hope this help
Thanks
Byron
Sep 01, 2009 | Kodak Easyshare M893 Digital Camera
Fuji FinePix E550 Digital Camera stopped working after fresh batteries inserted
due to very low temprature some malfunction may have occured. keep it in normal temprature for few hours and then try switching it ON. even if this not solves take it to some service centre.
Dec 07, 2007 | Fuji FinePix E550 Digital Camera
Battery Wont charge
I have the DMC-TZ1. The charger is labelled "Panasonic DE-A25 battery charger". It has 3 contacts where the battery fits in. With no battery in place, the voltage between the top and middle pins is 2.61 V. The voltage between the middle and bottom pins is 2.19 V. Check those voltages. If they are very different from mine, I rather think the charger is not working. You can buy the batteries for very low prices on ebay from Hong Kong and other asian sources, but I've been told by someone who tried them that they do not work. Perhaps you have run into one of those. If you can find someone else with the same battery, a quick swap will tell you if your camera is okay. I got my camera on ebay and it works perfectly.
Jan 03, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Cameras Logo
20 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
