Programes on draw have rubbed away need to see settings
  • 15,935 Answers
It appears your timer selector dial has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
When i turn it makes a rubbing noise
Have you put on a set of tires which is larger than the originals?
Aug 07, 2014 | 2006 Jeep Commander
What do I do if the toilet continues to draw water and the water level on the fluidmaster 400 is properly set?
First is the water overflowing the overflow tube? This would indicate that the ballcock or flow master needs a seal or that it is rubbing the side of the tank (if it is rubbing the side of the tank twist it slightly). If the water level is always below the top of the tube but the flow master keeps on filling in bursts then you need to replace the flapper. Flappers will decompose slowly and black residue will come off to the touch. Wear gloves because this black will be on your hands for days. The flapper gets a slight ripple or curve that allows water to get by.
Nov 29, 2013 | Fluidmaster INC #B1F09 9" Faucet Connector
How can i draw my assignment on papers
You'll need a drawing program like "Paint" or any program that has a drawing feature. Use the program or application to draw and then print the document.
Oct 31, 2010 | Samsung ML-2510 Laser Printer
I have a 3.34 amp drain while the grand marquis is turned off.. resulting in brand new dead batteries.... need to know how to find the drain. please and thank you.
the easiest way to start is to pull each fuse one at a time and see if the draw goes away. if it doesn't than reinstall that fuse and pull the next. Repeat this process until the draw goes away. Once you know what fuse stops the draw you can figure out what that fuse powers up and move on to systematically disconnecting each one of those components until the draw goes away.
Before I do anything with a draw I like to check things like under hood lights, glove box lights, and trunk lights to make sure they are turning of when they are supposed to.
When you figure out what fuse stops the draw post a reply and I'll be more than happy to assist you on the components that fuse protects.
Sep 30, 2010 | 1984 Mercury Grand Marquis
Tablet does not work with Manga Studio Debut 4
I had the exact same problem. To fix it right click the manga studio icon go to properties-compatibility. Set everything under settings to on, apply-OK, then go on manga studio, it should mess up your screen resolution, don't worry about that. Close the program, your screen resolution should go back to normal, go back on to the properties-compatibility screen and set everything under settings to off. Now when you go on to manga studio it should work fine.
Jun 11, 2010 | Smith Micro Manga Studio Debut 4 for PC
2002 pathfinder killing the battery for no reason. Sometimes overnight others it takes a couple days. Replaced batt. and alt. but problem still exsists. Ive already checked each circut by pulling fuses for...
to check for a parasitic battery drain, you will need a multimeter. set it on the 300 mA setting then remove the negative battery cable on the vehicle. put the multimeter's negative lead on the battery post and the positive lead on the vehicle's negative cable. the meter will tell you how many amps are being drawn. usually, there's a temporary spike (a second or two) for the vehicle's security system, relays, etc. after that, you should only see a draw of approximately 30-40 mA, which is the digital clock, memory settings on the radio, etc. if you're seeing a larger draw, you can begin removing main fuses in the fuse box under the hood to see where the draw is coming from. it's also possible that you may have a bad diode in the alternator, which would cause the alternator to draw current away from the battery when the engine is not running.
Jan 28, 2010 | 1995 Nissan Pathfinder
Graph won't go away
There is an instruction to clear graph
When in Graph mode Press [F6:Draw] and [1:ClrDraw].
Hope it helps.
Feb 09, 2009 | Texas Instruments TI-89 Calculator
Corel Draw X3
The color manager was set to off. I I changed The setting to CYMK and the color works
Nov 05, 2008 | Corel DRAWings® X3 Standard Upgrade...
Water still in drum after programs finished.
This is caused by the water level switch not working correctly. This is most commonly caused by the internal filter being blocked, you need to remove the filter and clean out all the buttons coins and lables ETC , see the note on how to do this from other user
Jan 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
