Question about Epson LQ 2170 Matrix Printer
Printer give test page but stops when printing from a program
When you send a print from a program,the printer starts printing but stops half way,prints only after pressing the pause button.
Inky
  • 691 Answers
SOURCE: Epsom RX 425 Just prints half a page
If you are 101% sure that you have the paper size set correctly on the panel and that you have the orientation and zoom set as they should be then the answer is... you can't fix it.
If the machine is set correctly but fails to print the whole page then the main board in the machine is faulty and the only fix is either a new board or a new printer.
If your machine is in warranty then get Epson to replace it for you. If the warranty is out, then it probably is not economical to repair the machine, but you could get a quote from a local dealer just to check.
Sorry if it's bad news for you.
Posted on Feb 20, 2008
  • 68 Answers
SOURCE: not printing even the test page,full ink ??
Take no notice of previous solutions, Epson printers have fixed print heads and replacing a cartridge does not solve the problem nor would the ink cartridge itself be clogged, it is the permanent print head in your printer.
Most clogging cases are caused by lack of use or occassional use.
First check you've removed the "tear off" strips, these allow air into the top of the cartridge and without this, ink can't flow out of the bottom of the cartridge.
If these have already been removed, proceed to "Prime" the heads.
To prime, you need to open up the [Maintenance] screen on your printer properties box, click on the [Head Clean] button and when cleaning is finished you'll be asked to print a Nozzle Check Pattern. You must cancel this by clicking [Finish]. Carry out a further 3 head cleans cancelling each nozzle check until the 4 cleans are complete, then allow it to print the nozzle check pattern. You should now see a significant improvement in the amount of clear nozzles if not a perfect print.
If the print isn't perfect carry out another "Prime" as above.
Any further Epson cartridge or printer problems, go to our help pages linked from the Epson page on our website. Here's the link straight to the Epson page: http://www.the-inkstore.co.uk/frame/pages/epson.htm
I hope this helps lots of you!
Regards
Nigel
The INK Store
Posted on Jan 17, 2009
SOURCE: EPSON STYLUS CX5500;-Document prints from file
send for me manual epson stylus cx5500
Posted on Apr 11, 2009
anantakumarj
  • 330 Answers
SOURCE: lq2180 when print few lines, the printer pause
its may be heaving problem with the control panel clean replace the buttons or replace the control panel and check it ................
Posted on Dec 22, 2009
  • 63 Answers
SOURCE: the printer only prints half a page then moves to next page and a
Before printing, the printer checks the paper size. If the paper edge guide is positioned incorrectly, the paper may be fed at an angle. If this happens, the bottom of the paper is therefore at an angle and not perpendicular with the paper feed rollers. This can result in the paper sensor not recognising the real page width as it can only detect a certain amount of the bottom of the paper sheet which is nearest to it.
If only part of the width of the paper is detected, the printer considers that the paper width is less than it actually is. To avoid printing on internal parts of the printer such as paper feed rollers, the printer automatically cuts the image to fit the detected paper width As this phenomenon depends on the paper feeding condition, it can be random.
Reload the paper and make sure it is loaded correctly. All the way to the right and the paper guide correctly adjusted.
Posted on Feb 10, 2010
Testimonial: "Thank you so much, I no longer have a problem. It seems such a simple solution now I know the answer! I thought it was something major."
Manteinance program run automatically every time i try to print something
Its not maintenance programme, its print head alignment page.Once print heads are aligned successfully, you wont get this page.
Reason: One or more print head nozzles are not firing/blocked/dried up the align page will not prints properly to read result printer unable to align P.heads. You can observe the print quality, based on that replace/clean the particular print head(s) and check. Verify that each line it will read & marked as a "right tick". If its marks like "X" ensure that align page not successful.
If you are confused better replace all(four) print heads, to get out of this issue peacefully.But ensure that before replacing the print heads,all cartridge ink level should be more then 50%.
Nov 28, 2012 | HP DesignJet 110 Plus NR InkJet Printer
Printing too light
For understand the issue, little bit technical knowledge required: Take half test page, check how much dark image formed on paper, check on cartridge drum how much dark image created?..(half test page: while printing half of the page switch off the printer, take cartridge out as well as take half printed page)If half page print quality is good on paper: Fuser faulty(teflon sleeve)If half test page print not good & image on drum is OK: Fault with Transfer roller or its bios voltage contacts..If there is proper image on paper & image drum: Problem with laser scanner assembly..find the problem, then remedy is easy..
Feb 02, 2012 | HP LaserJet 3030 All-In-One Printer
HP 1160 e cuts off side of page. How do I fix this?
Printing or paper?.. If printing check 1. check with another cartridge 2. check half test page(half test page while printing half page stop printer remove cartridge & paper see the image created on cartridge drum or not ,if not clean the Laser scanner assm, check on paper proper image or not if not clean the transfer roller.(looked like sponge roller located just under the cartridge location). beyond this trouble shoot, advised to send it to service center..
Sep 13, 2011 | HP LaserJet 1160 Printer
My hp4p has a 2"
check half page test..give print command when it printing half page stop the printer open the door remove the cartridge take out paper see is this quality what you are observed. if yes its needs to clean the laser scanner assm.. if half test page is good then check the fuser assm, might be toner partials deposited on Teflon sleeve..its avail replace teflon sleeve or fuser..
Sep 06, 2011 | HP LaserJet 4 plus Printer
Samsung clp-315 printer stops printing after half page
You'll probably have to replace the exit sensor (lots of people have this problem). Go to YouTube and watch this video: 5fJHykzkfww
You can get the part on eBay for about $10 and it's a fairly simple 15 minute fix.
Sep 22, 2009 | Samsung CLP 315 Laser Printer
Print half of full page
If the printer starts to print and stop in the middle check the eletricity of your place, this may have a variation. If the printer prints a half page and give you the paper, with no jam, check the cartridges and then the main board.
Aug 13, 2009 | Lexmark X5470 All-In-One InkJet Printer
Hp 2600n will not accept print jobs. Color cartridges show empty. black shows half full. Printing of a test page produces a great test page quality
I have two problems. Either it won't accept a print job or when it is printing it stops when it is going through the job intermittently. Like for an hour it won't continue then all of a sudden it prints one page then a half hour later another page etc. It is so frustrating.
Feb 03, 2009 | HP Color LaserJet 2600n Printer
Printer prints partial page and then stops
We have had the same problem. I have found that if I close all windows not being used on the computer, then try to print the document again the entire document prints. This happens on an older computer we have that doesn't have alot of RAM.
Dec 04, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Not working dtc550
Since the printer prints the test page from the driver, most likely the problem is with your Cardfive software. To test this, try printing a card on the printer from Microsoft Word or Notepad. Just remember to set your page size or you will get multiple cards printed. The Fargo printer is just a windows printer and may receive output from any windows software.
Aug 02, 2008 | Fargo DTC550 Thermal Card Printer
Epson LQ 2170 Matrix Printer Logo
44 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
