Question about Nokia 5220 XpressMusic Cellular Phone
My fon volume is not working whenever i play mp3 music and whenever someone is calling the ringtone wont ring.
How can I make my speakerphone work again?
call someone or tun on music on phone menu select loud
Feb 27, 2016 | Cell Phones
How do I get the ring tone on my phone to work?
These smartphones controls all sounds with the volume rocker, the only problem is that it controls only what is currently being use. Just go to any ringtone and tap it in order to play it. While it's playing, use the volume rocker up to raise the sound.
Dec 13, 2014 | Samsung Cell Phones
Why does my zte savvy not ring when I have a call coming in
You can adjust the ringtone volume by pressing the Volume Up/Down Keys at the top of the left side of your phone.
This will only work if the phone is not playing media (music, etc...).
I hope this helps.
May 07, 2014 | Cell Phones
Dear sirs. I hope you can help. I just got the droid HTC EVO. i somehow installed a music video that plays and displays whenever I get a phonecall with this terrible clip of some musician. I desperately...
here are two ways to setup a ringtone for incoming calls.
  1. From the Home screen tap Settings > Sound & display > Phone ringtone. Tap the ring tone you want to use on the list, and then tap OK.
  2. You can also use a music file as a ringtone. To set up a music file as your ringtone, please use the micro USB cable to connect the phone to a USB port on your computer. The Connect to PC dialog box displays and prompts you to choose Disk drive > Done. Your phone's SD card is mounted as a drive on your computer. You can now copy music files to the SD card.
After you have finished copying, open the notifications panel (by touching and then dragging the status bar down) on your device; then in the Notifications panel, touch Charge only.
Then tap All programs > Music > tap the music you want to set as a ringtone (the music will start playing) > press Menu > Set as ringtone. You can set the music file as a Phone ringtone or Contact ringtone or you can select Trim the ringtone.
Jan 16, 2011 | HTC EVO 4G Smartphone
How to set mp3 song from memory card as your caller tune
I think that there have been some mistake.....Caller Tune means the ring-tone which is hearing by someone who is calling you.So you cannot set the caller tune yourself, it is provided by the Sim service provider.Here However, Ring-Tone means the tone which you are hearing when someone is calling you.We can easily set this tone by using....Menu......>Profile...........>Ringing tone setting....Set the tone what you wish............................
Aug 10, 2010 | Nokia N73 Cellular Phone
My headset is grounded
pushing the jack hard may result in some connections pushed way off, and there is no contact to the speaker. Please see the nearest technician.
Jun 12, 2009 | Cell Phones
I have sound ringtones but can't apply as ringtones on my razr
The ring-tones that are saved to your memory card, if mp3 file, will only play within your music player. You cannot assign any ringtones on your memory card. You must either download a ringtone of your choice from Sprint.com (which costs per ringtone), use your "voice memo" to record your desired music and assign it as your ringtone, or download any ringtone of your choice from certain webhosts that other the service for free such as: myxer.com, mobiles24.com, phonezoo.com, zedge.com.
Hope this helps! Thanks.
Mar 13, 2009 | Motorola Mobility RAZR V3
Ringtones
You need to go into groups and for each group select a ringtone for that group . Then the other ringtone you selected on settings will ring when a person who you do not have in a group will be used .
Hope i helped xD
x
Oct 14, 2008 | LG KG800 Cellular Phone
I cant have my own mp3 songs for my ringtone on my LG Chocolate. it keeps playing the Ring 1 ringtone.
You can: MP3 Player * Download and listen to music with the built-in MP3 player.
* Don’t settle for boring polyphonic ringtones, select an MP3 as your ringtone. (Also supports AAC, AAC+, AAC++ and WMA formats)
* External MP3 button for easy access to your music.
* Graphic equalizer with 6 sound effects to choose from (General, Classic, Jazz, Pop, Rock and Bass).
You should try to find a music or download some mp3 music and when playing click on set as ringtone.
Jul 28, 2008 | LG Cell Phones
Ringtone will not work
Even though I've reset the master volume, etc. the ringtones will not work, I can't play them and the phone will not ring. In tools, sounds setting, call sounds, call ringtone: help
Jan 03, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Nokia 5220 XpressMusic Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
