The water dosent stop automatically - Washing Machines
    Problem Solver:
  • 15 Answers
The water level control switch is bad or are you putting the clothes in after the water is in.
Posted on Sep 10, 2009
    President:
  • 1,776 Answers
Check for a faulty water level switch. It's a diaphragm-like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the tube and when it reaches a certain level, it activates the switch to shut off the water and signals the timer to start the appropriate cycle. Check for any obstructions in or damage to the plastic tube. The switch can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad switch. Sorry for your trouble and I hope this helped. Best wishes.
Water is not stop automatic
Do you mean: The water continues to run into the drum? If so you need an appliance engineer to check out the incoming water solenoid valve.
Nov 06, 2014 | Washing Machines
Cant get my janome excel mw 3018 to do an automatic buttonhole
I would suggest taking the machine back to where you bought it & letting them show you how to make a buttonhole or getting another
machine
Aug 21, 2012 | Janome Sewing Machines
My 98 dodge stratus sometimes sticks when i stop sudden or when i stop sudden and after i change from reverse to drive. it dosent do it all the time. what could be the problem i have auto stick and...
Other than low transmission fluid level, a qualified mechanic
will have to scan the engine computer for fault coded to see
what the problem is.
Dec 10, 2010 | 1998 Dodge Stratus
Whirlpool type 111 model LSQ9200LQ3 washer not
I have a whirpool model:lsq9200lq3, and recently it has stopped working. when ever you turn it on, its fine and the water fills up normally and right before it gets to the spinning cycle the machine makes a grinding noise like if something is stopping the motor from spinning, and it dosent spin inside the washer. if anybody has any suggestion It would be great thank you.
Jan 30, 2010 | Whirlpool Washing Machines
Machine full of water and towels. Spinning at same rate then stop
Check pump filter located at rear of washer, remove rear cover, locate and remove large black hose, remove and clean filter.
Please rate my solution.
Thanks.
Jul 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
I got a legend platinum poll cleaner this week and it dosent come up to the shallow end.my slope isnt very steep and the cleaner seems to have plenty of power because it climbs the walls fine.ive tried...
The first thing I would check is the swivels in the hose line. Make sure all of them spin, it not then replace that swivel. You may also want to check the length of the hose, if it was not adjusted to the proper length, this could be the issue also.
Another place to check is other reurn lines. If your pool has more than one return line, check to see if that line is shooting water across the top of the pool, if so, you may want to adjust the flow downward at on angle. The returning water may be stopping the hose and the unit from going to the shallow end.
Jun 27, 2009 | Pentair White/Gray Legend Platinum...
My washer machine is filling up with water but will not stop
hi..the problem may be due to two reasons.
one is your washing machine will not be fully
automatic,it may be semi-automatic.In that case
the water will not stop automatically after reaching
its capacity.other problem may be there will be some
short in the wire in an fully automatic machine which
could have lead to this problem.
check it out.
thank u.. rate me..
Feb 05, 2009 | Frigidaire FWS833A Top Load Washer
Washer dosent work at all!
check to see if the drive belt broke (under the machine)
Jan 26, 2009 | Kenmore 22422 Top Load Washer
Machine dosent seem to drain model #lat8840b maytag
my machine had a pair of kids underware stopping the water from entering the draij pump,you may have clothes inbetween the drum and outer wall stopping the normal rotation
Aug 25, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
