Question about EliteGroup ECS P4M800-M Socket 478/P4M800/FSB800/A&V&L/M-ATX Motherboard (MOTEC18)
No monitor output, no booting screen appears, no sound in the motherboard
I cannot get to the booting screen because well i guess my motherboard has already an error. As if there is no signal flowing to the monitor. Im sure that the monitor is working very well.
I have troubleshoot it myself to see where the error come from, which part of the PC. I have disconnected all the add on cards including the memory and the processor leaving only the monitor connected to the onboard plug. The same problem appear. The hard disk led is always on and not blinling as i turn on the power. The powersupply is working ( I guess) because the cpu fan and the processor fan(when it is still connected) is working. When I also turn it on, there is no sound in the motherboard.
From this I concluded that the motherboard has error. Is my coclusion right. Do I really have to replace that already.
Hoping for your reply. thanks.
  • 1 more comment
  • Reynante Manriquez
    Reynante Manriquez Dec 12, 2007
    So its either the processor or the mobo has the problem. I do not have enough time to transfer it to other computer processor. But, thanks for your advice.
    But, Im thinking now that the problem is the mobo. This is because there is no sound when i turn it on as it should have been even there is no processor or peripherals connected, and another one is that the DVD drive wont open if its connected in the motherboard and if I disconnect it - it will open. Is this symptoms show somehow that my assumption are correct or are there possibilities that the motherboard wont sound at all if there is no processor connected on it.
    Thank you again.
  • Anonymous Apr 01, 2009
    i have same problems as reyman describe
  • marvs_0227 Apr 01, 2009
    i have same problem as reyman describe in this link
    http://www.fixya.com/support/t291873-no_...
    Genius:
  • 1,226 Answers
Try your processor to the other computer that is working with the same CPU socket to prove that is working. If the processor work to the other computer it slightly proved that the mboard is dead, but sometimes processor hang-up on the mboard try to install back processor to suspected MB, there is a 20% guarantee solving the problems.Otherwise if the processor not working on the other computer something wrong with your processors. may this help.
Posted on Dec 10, 2007
Toshiba a305 Screen Blank on Power up.
Yes, the first step would be to use an external monitor. You may have to use the FN key with a function key to tell it to use the external monitor. If the external monitor works, try shining a bright flashlight on the display. If you can see images, then the display itself is probably OK and either the back light or inverter are bad.
If the external does not work and shining a light on the display does not show images, then it could be graphics card or main board.
Does the laptop make any noises? e.g. Can you hear fans, hard drive, does the CD light come on during boot up. If yes, to all the above, then the mainboard seems to be OK and it could be graphics or display. If unsure, you can remove the RAM chips and it should beep upon startup to say there is no memory and this is a good indication that the mainboard is functioning somewhat.
Good luck and post your results for further help and to let me know if you have figured it out.
Aug 21, 2012 | Toshiba Computers & Internet
Compaq Presario CQ50-110US 15-inch Laptop dropped will boot but no video
Your laptop may have a combination of problems. Since the laptop was dropped, it is possible that your may a motherboard that no longer outputs video through the video controller, or the screen may have been damaged internally. Try hooking up an external monitor through the vga output of your laptop, usually located on the side or back of the laptop. If the external monitor works, then most likely it is your screen that's bad, if the external monitor doesn't works, then most likely it is your motherboard that's bad.
Let me know if this helps.
Feb 12, 2012 | HP Compaq Presario CQ50-110US Laptop
My laptop Gateway ml6720 has a black screen Ive replaced the battery and power adapter no change. The fan comes on and it sounds like it boots up but no screen.
Sounds like either the screen or the video adapter has gone bad.
Do this: Connect the computer to an external monitor (there is a SVGA plug on the side of the computer. Be sure when you turn it on that you press teh Fn-special function key combo that switches the video output to the external monitor. If the external monitor works, then it's your computer's screen. Possibly the inverter. If the external monitor shows nothing, then it's the video card (which may be built into your motherboard).
Oct 05, 2011 | Gateway Computers & Internet
My dell inspiron b130 boots up but monitor is black
After your laptop boots up into windows, hold down the Fn key and as your doing that press the F8 button that should switch the output from the vga connetor to the LCD screen on the laptop.
If you still don't get video then you'll have to reseat the LCD cable from the back of the LCD screen to where it connects to the motheboard.
If you still don't get video then its either going to be a bad LCD or a bad motherboard.
Aug 09, 2009 | Dell Inspiron B130 Notebook
Toshiba M45-S331 Won't Boot and Broken LCD
Solution Replace the Monitor screen which cost around 60$
Apr 02, 2009 | Toshiba Satellite M45-S331 Notebook
MSI 7041 Motherboard problem?
RAM would be my next guess. If the board is bad, so could the RAM be as well. Try swapping some known good RAM and see what happens. Or, at the least (if you have more than one stick), remove all but one and try again. Repeat until all sticks have been tried by themselves - you could just have one RAM stick causing the problem.
However, usually even if you have one bad stick, your system will still post, just show less memory. On the off-chance that all sticks are bad, then you might have similar symptoms.
Sounds like a bad mobo to me :(
Scott
Oct 05, 2008 | Intel Motherboard
Acer Aspire 5585 Laptop LCD Problem
Have you tried booting into "Enable VGA" mode via the "Windows Advance Option" screen? By press F8 before Windows XP loading screen comes up. In this mode the Video Card drivers are disabled. So if your screen appears normal and not white in this Mode then it is your video card drivers which are causing the issue.
Aug 19, 2008 | Acer Aspire 5610-4648 Notebook
No booting
did u chk the power cable to monitor ?
replace the power cable wd tht of the tower or cpu if cpu glows then ur monitor neds to be repired
May 22, 2008 | Intel Motherboard
Dell m992 screen problems
If you notice, when you see the windows start screen, its usually "big and dopey". Thats because the video drivers aren't being used yet. If it is blanking out right after you see that screen (with the scrolling bar), my guess is it's a corrupt / bad video driver.
Was any other hardware added recently?
Jan 10, 2008 | Dell M992 19" CRT Monitor
EliteGroup ECS P4M800-M Socket 478/P4M800/FSB800/A&V&L/M-ATX Motherboard (MOTEC18) Logo
207 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
