Question about Maytag Dryers
Maytag Dryer element melted after replacing thermal fuse.
I have a Maytag Dryer model HYE3658AYW. Recently it just quit altogether, would not function, no light, nothing. After troubleshooting I determined it was the thermal fuse (I disconnected the leads and shorted them with an alligator clip lead and the dryer started right up). So I replaced that and the hi-limit thermostat. It started right up but within 10 seconds or so the heating element melted right where the wires come out of the ceramic block - the dryer kept running but obviously no heat. So... is it possible I put the wires back on the fuse or thermostat wrong ? Does the fact it kept running after the element melted indicate I did put the wires back on correctly ? Or was I possibly not gentle enough with the heating element and it gave up the ghost (back to the parts house) ? Not sure which way to go here - I fear if something is wired wrong I may just melt a new heating element. Please advise.
  • Scott Howard Sep 10, 2009
    During test with fuse circuit bypassed, if heating element was shorted seems like that element would have blown/melted then but it didn't. Aren't those elements a bit on the fragile side ? Is it possible I bumped it around moving it in and out while replacing the fuse ? Do the 2 wires going into the fuse and the thermostat matter which contact they are plugged into (still wondering of that's where the problem is) ?
    "did the element actually melt i.e. molten metal?"
    No, not exactly, the wires that go into the ceramic post did melt I suppose, since there is now a gap where they used to be, I have burned pieces of wire down in the bottom as a result.
    I was none too gentle with the element getting it out the first time, could that be what introduced the weak and therefore Hot spot as you said ?
    By "Re-String" you mean a reman part ?
    So the ceramic post won't be part of the replacement unit ?
    Not sure I understand this statement:
    "...make sure your
    neutral connection is very solid and secure that breaks and it wont
    heat correctly or at all"
    I understand getting a good connection... you mean if I don't it will possibly do again what already happened - ie, break/melt/vanish, etc
    President:
  • Maytag Master
  • 1,922 Answers
Did the element actually melt i.e. molten metal? it sounds like it had a "hot-Spot" in that area, also you could have had a high resistance connection there and that could be your source of "melt down", there is NO way you could wire it wrong it either will work or it won't, when you put in your new element make sure if its a "Re-String" element that you wire the nichrome coils in that you DO NOT get any SHARP bends anywhere especially at your connections at the ceramic posts because this can result in a "Hot-Spot" connection, and also make sure your neutral connection is very solid and secure that breaks and it wont heat correctly or at all, there should be a wiring diagram somewhere on the machine anyway.
Posted on Sep 10, 2009
  • daniel  hendrickson
    daniel hendrickson Sep 10, 2009
    A "Re-String " kit is two coils of nichrome wire made for your particular size-make dryer i.e. 3,000watt
    4500watt or 5,000watts, the posts and ceramics normally come with the kit and you restring it by hand, its usually a round pan type w/many small insulators to feed wires thru,the others are rectangular box type elements, as for the neutral line, its the one that is connected between the two nichrome coils, its for your return current balance it is normally in between the two hot wires on the assembly and is usually white in color per the (N.E.C.) nat electrical code the other two hot wires 120volts each(240)volts can be almost any other colors i.e. general electric is purple and orange per companies discression for the hot conductors, call appliance pros or visit their web-site w/your model,make,etc. they will have and know what all you need for repairs and ship time and price is great
  • Maytag Master
  • 19,396 Answers
The heating element may have been "plugged" to ground. That will meen that heating element staid always on because of a contact to ground, either on element contacts, or at a different point in wiring harness.
This caused the thermal fuse to blow.
The dryer kept working with element blown because the contact was keeping the circuit close.
Replace element, and if needed also element wiring harness. Inspect wiring harness from element to temp sensor, and to timer control.
Matag dryer not heating
Here is a link to maytag dryer repairs http://apcoappliancerepair.wordpress.com/?s=maytag+dryer . The most common problem is the thermal fuse. My question is. Does the heating element start to light. If not...... and you have changed the ignitor and thermal fuse. Then check the flame sensor to see if there is continuity threw it. Power to the gas coils and ignitor runs threw the flame sensor. CLICK HERE to see a flame sensor on a GE dryer. They are the same on most units but Maytag will be on the opposite side of burner chamber.
Apr 30, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Not sure what model is other than maytag atlantis but my gas dryer has quit heating therefore does not dry...any suggestions?
check voltage to dryer, should be 220-240. check element, thermal fuse. could be in the timer but rare.
Jun 26, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
My maytag electric dryer wont heat up
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Apr 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
My Maytag Performa dryer just quit. About 7 years old. Better to get it fixed, or replace it?
you need to check the set of thermal fuses.you need to lift the lid on the dryer and look in the back on the left you find the heating element.there is a large thermal fuse right on top of it,then on the side of the can there is another one that is usually the one that goes bad.the part number is la-1053 you replace all three of them.but first thing you need to check for continuity on them. if they are good then check the continuity on the heating element.replace if needed
Feb 27, 2010 | Maytag Performa PAV2200
Location of Thermal Fuse
The thermal fuse is located near the heating element. The part number for the replacement kit is LA-1053. You can view an illustrated parts break down of your dryer at searspartsdirect.com. Just type in your model number and locate item 5 under the "Heater" section. Pay close attention to the instructions in the thermal fuse replacment kit. One thermostat is for a GAS dryer, one is for an ELECTRIC dryer. Read the instructions and make sure you use the correct one. If you have any questions, please let me know. I hope this helps you.
Jan 06, 2010 | Maytag PYE2300AY Electric Dryer
Maytag dryer is not heat up. I think the heating
Hello, There are a couple of variations of the heating element, depending on the series number of your dryer.
Here's a link to the parts list and line drawing so you can verify the proper element you need.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=SDE4606AYW&productCategoryId=0151200&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00005&componentDescription=REAR%20BLKHD,%20AIR%20DUCT,%20ROLLER&HTR%20(ELE)&documentId=M0510059&blt=06
If you have a Series 14 dryer, the element part number is #37001134, otherwise, there are a couple of other elements that your particular dryer might use, so check the model number and product tag so you can get the right parts.
You might want to check the element first, to make sure it is defective, before you order replacement parts, as it might be a faulty thermal fuse, which is much less expensive to replace than the heating element.
If you have a multimeter, you can check the fuse to see if it's failed. Be sure to turn the power off and unplug the dryer before removing the back access panel and checking the thermal fuse (see drawing in link above)
With the meter set to measure resisitance (Ohms) you can put a test lead on each side of the thermal fuse and if you get a reading showing no continuitity, then the thermal fuse is blown and needs to be replaced.
You can also check the heating element using the same method, again, make sure the dryer is unplugged before testing the continuity of the heating element, if you don't get a continuity reading, then the heating element is bad too.
I hope you find this Very Helpful and best regards!
Nov 13, 2009 | Maytag SDE4606A Electric Dryer
Maytag dryer overheating
have u replace heating sensor
Oct 22, 2009 | Maytag PYE2200 Dryer
Dryer wont dry, element comes on and off, model HYE3658AYW
Could be the thermal fuse. look online for your model and it should tell you where it is located. once you find it olh it out and see if it is open, if so it's a simple and cheap fix.
Aug 12, 2009 | Maytag Dryers
Maytag Atlantis electric dryer Model
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 08, 2009 | Dryers
Maytag Performa PYE2200AYW Dryer Heats intermittently
i had the same problem with my dryer and i installed the wrong thermal fuse for gas dryer which calls for a pink thermal fuse in which i installed and it works fine also check the lint in the front of your dryer. also my dryer which is the same make as yours seems will run on the fluff cycle until i replaced the right thermal fuse. my dryer run exceptionally hot and eventally shut down and it only run on the fluff cycle for any length of time.
Aug 03, 2009 | Maytag Dryers
Dryers Logo
88 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
