Question about ASUS A7N8X-VM Motherboard
CPU Fan Error
Motherboard : Asus a7n8x-vm 400
When I start the system, it is showing CPU fan error. Please help us to resolve the problem.
  • 3,153 Answers
It will do this when it senses that the fan is not working properly or that maybe a setting fo the fan is incorrect
First off. If you changedanything using any motherboard utility then change it back or reset defaults.
Second. Open the computer case and check that the fan and poer supply are not full of gunk after you have unplugged the computer.
if so then get a can of compressed air meant for cleaning computers and take it outside to blow all the gunk out whilst wearing glasses.
Dont poke the nozzle inside anything.
When you have done that check that the cooling fan for the cpu is secure to the cpu itself (dont remove unles it is loose)
Also check that the fan spins freely.
If it doesnt or feels loose then replace the cooler
Check your manual for the exact instructions but you should remove the cooler completely
DO NOT REMOVE THE CPU
Now with nothing more than isopropynol and cotton bud sticks or another alcohol based cleaner remove the old thermal grease / sticker from the top of the CPU (make sure it is clean)
At this point it is up to you but you could consider a newer better cooler
You could take your old cooler to a good computer shop show them it and just ask for a better one
If you are using your original cooler then here we go
Do the same with the underside of the cooler.
While the cooler is off it may be worth giving it a good 8low job
Now apply some new thermal grease (most computer shops have it)
Be careful about how much you put on
Here are some basic instructions
Once you have re-assembled your cooler and re-connected it check everything is OK and power up the computer.
If everything went to plan you should now be back in business.
Another consideration is that many cases have places in them for extra fans and usually extra connections on the motherboard too.
They are quick and easy to fit.
Quite often I will fit TWO in what is called a push/pull configuration. One pulls cool air in while the other pushes hot air out
Posted on Sep 10, 2009
  • 77 Answers
You will remove the cpu fan and cleaning the fan after insert.otherwise insert the new sutable fan.
CPU Over Temperature Error
Hello
This error mostly comes with the failure of processor fan, overheating of processor shuts down the system due to processor's protection. You need to check the fans and replacement is recommended.
Hope this helps
Jan 31, 2011 | ASUS P5PE-VM Motherboard
I NEED DRIVERS FOR A7N8X-VM/400
All the drivers for your Asus A7N8X-VM/400 can be found on Asus Global link. Click the link below to open the site;
http://www.asus.com/product.aspx?P_ID=OYMrFEShYfp6m1dg
Have more problems post your question here.
Thank you for using Fixya!
Mike
Jun 24, 2009 | AMD ASUS A7N8X-VM/400 Motherboard
Cpu fan error
Make sure the cpu fan is plugged in and to the cpu fan connector on the motherboard.
Apr 04, 2009 | Computers & Internet
SM Bus controller
Go to this Asus web site: http://support.asus.com/download/download.aspx?SLanguage=en-us
On the right side of the page fill in under, "Please Select the Product". Choose these.
Motherboard
SocketA(462)
A7N8X-VM/400
Click: SEARCH
Clcik: Utilities Find your operating system. Download.
Might be a good idea to download everything else since you do not seem to have your Mb CD.
If this helps you, please vote!
Jan 09, 2008 | AMD ASUS A7N8X-VM/400 nForce2 IGP...
Cup fan erro
Firt remove the covering of the cabinet then locate a battery take it out rub it for few seconds.Place it back the way it was.Now if you have another cpu fan port on the mother board then plug your cpufans cable to it.Now restart your computer start pressing F2 ie bios settings.Now check the time and date. restart it again. See if it fixes the problem.
Please rate me> Karatela ;-)
Dec 07, 2007 | ASUS A8N-VM Motherboard
Open Questions:
I know I have a driver issue but how can I solve it???? I just installed a new motherboard asus a7n8x vm 400 I installed windows XP Sp1 but when I got done I could not get a internet connection so I upgraded to Windows 7 and still got the same problem but with a new issue. The first Issue I was having was the computer would not log online. Under the Network and sharing center I?m getting an unidentified network message keeping my system from obtaining a valid IP address. For some reason it?s stuck on public network and will not let me change it to home. I tried all of the basic trouble shooting first by turning on network discovery then I checked my network cable; reset my modem and router, and rebooted my computer. After cycling everything and still no internet connection I tried to manual assign a IP address. next I tried to go online using a different computer to find a updated driver and transfer them via flash drive with no luck just the windows is using the best driver message. I tried installing Driver Detective put when I try to launch the program it shuts down because it don?t have a internet connection. The second problem I?m having is a unknown device in device manager. When I check the device properties under general and location it say that its on my PCI standard ISA bridge. I do have a vt6421a IDE/SATA raid card in stalled in 1 of the 3 slots but when I uninstalled the device and shut down the computer and physically removed the card and rebooted the same thing popped back up. Updating the driver didn?t work I tried to go to the manufactures websites to get all driver updates with no luck. So what do you recommend?
Feb 28, 2017 | ASUS A7N8X-VM Motherboard
ASUS A7N8X-VM Motherboard Logo
140 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
