Question about E-Machines eMachines Desktop PC
I have a 19inch LCD monitor and the main menu resolution screen keeps blinking and wont go off. Have tried to disable it, different settings but it still does it. Can you help please
  • 3,153 Answers
Try setting your computer itself to a lower resolution first say
1024 x 768
It may be that you are pushing the resolution to high for the monitor to handle
Posted on Sep 10, 2009
I set the resolution far too high by mistake on my Gateway FPD1960 TFT LCD monitor. Not the screen shows "Frequency out of range". The side controls on the monitor do not respond. Please help,if you can.
Hi
Firstly try turning everything off and disconnecting from the mains. Leave for a few minutes and then turn them back on again. This should set the monitor back to default setting, and also the computer.
If this doesn't work, try connecting the computer to a different monitor and using the "display properties" to set the display card to a resolution that you know the Gateway monitor will accept eg probably 1024 x 768. Then reconnect the computer to the Gateway monitor. This should work as the computer usually sets the monitor resolution.
If this doesn't work the only other option I can think of is to use the buttons on the monitor to get into the onscreen menu, which should be resolution independent and using the menu to change the resolution.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 07, 2015 | Gateway Computers & Internet
I updated my video driver and now on 17 inch monitor display is coming instead of full monitor display how can i make the screen back to full 19inch display
Go to the Control Panel and click on Display, the the Settings tab. then change the screen resolution to 1024 X 768 or higher resolution.
The higher the resolution the smaller the Icons will be but you will be able to display more information on the screen.
Jun 09, 2010 | LG L192WS LCD Monitor
My syncmaster 710n is not working. I get the box where it ses what resolution si the right one, but the syncmaster 710v works normaly. Does that means my 710n can`t be repared anymore? Thanks
Not completely sure what you're saying. Here's what I got out of your problem:
You have a Syncmaster 710n that displays a box saying the best resolution is _____ x _____, but your Syncmaster 710v doesn't show that message.
The main question I have to ask you is whether or not you see the screen or display behind the message on the Syncmaster 710n.
In either case, I doubt that this is a hardware problem. I also highly doubt that your monitor cannot be repaired. Try the following:
1) If you see the display/screen is showing behind the message box, this is almost definitely a setting issue. You need to press the menu button on your monitor and look for an option that says something like "display resolution message" or "ideal resolution message", or something else like that. Then you need to change the setting for that option, for example if "Yes" is selected, then you need to change it to "No" or if "Enable" is selected you need to change it to "Disable".
If you have the manual for the monitor, it should make it easier to know what setting to change. If not then go here:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=05020100&prd_mdl_cd=&prd_mdl_name=710N&prd_ia_sub_class_cd=P
and download the Manual that you need.
2) If nothing is being displayed behind the message, try to change the display settings of your computer. While using a different monitor, try the following: If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution to something compatible with your monitor (like the one it suggests you to change it to). If in Vista/7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Good luck. Let us know how it goes.
Feb 16, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
I cant fit the whole image on the screen. The options to adjust only allow me to adjust the width...it wont let me show both the top of my windows open AND the start button.
Your resolution may be set to high on the computer. Or you have a standard screen resolution set and since the monitor is a wide screen, it is cutting it off.
Try a different resolution 1440x900 is what the va1930wm uses.
If using a laptop with a standard type screen on it, you may have to set the laptop to just light the monitor to allow this setting to take.
Since this monitor is a wide screen, it may have options in the menu to stretch or zoom on an image if the resolution is not set to a wide screen format.
Dec 03, 2009 | ViewSonic VA1930WM LCD Monitor
How to disable the resolution notice on VG930m
Use your monitor buttons to look for Resolution Notice and turn it off.
To disable the notice on ViewSonic 23" LCD Monitor , use the buttons on the
front of the montior to do the following:
* Press #1 button
* Use down arrow to highlight Setup Menu and press #2 button
* Use down arrow to highlight Resolution notice and press #2 button
* Select Disable and exit!!
To disable the notice on NEC LCD 1765 monitor
* Press button #5 on the monitor
* Scroll up and down the menu list with Montior Button #4 and then select
with Monitor Button #5. Go to "Advanced menu" set the Resolution notice to
OFF.
Nov 02, 2009 | ViewSonic Computers & Internet
Monitor Resolutions Menu Pop ups
Please disable this notification from settings menu of monitor. you should find it under settings or notification menu which can be accessed via switches on monitor.
Jun 14, 2009 | E-Machines eMachines Desktop PC
Monitor wont stay on- blue light is on. but screen keeps going blank.
Have you tried the monitor on another computer? If so, and it works, the issue is with your graphics settings on your computer. LCD and plasma based monitors often come with a protection circuit that disables the monitor if the synch or refresh rate are beyond it's capabilities. this is to protect your monitor from damage.
Do not exceed your monitor's max resolution.
Resolution is determined the following way:
Width x Height @ Refresh Rate
For your model:
  • Max Resolution 1440 x 900 @ 75Hz
More detailed information about your monitor can be found HERE. If your monitor is still under warranty, and you find it to be faulty, you may be able to send it to the manufacturer for repairs.
May 30, 2009 | Acer X193W LCD Monitor
Hp pavilion f1503 momitor
Hold the MENU button for 10 seconds to lock or unlock the OSD
Aug 05, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor resolution
when you increase considerable resolution windows will ask you do you want to keep these settings? you select yes then that will be saved
Feb 15, 2008 | ViewSonic VX2235WM Monitor
Hooking up a second ACER monitor as an extended desktop
I have 2 acer AL2016W's and have the same problem. The earlier ones with the VGA only are the problem from what I can see, they just don't play nicely with the video card for some reason.
First, on your main monitor, click "Show displays in menu bar" on your monitor control panel. This will let you set the resolution for each monitor from the main one, click on the little monitor icon on the top right screen to do this.
If that doesn't work try this:
Connect one acer as the main monitor and one crappy vga crt monitor as the second.
Set mirrored desktop in the system preferences so that the crappy CRT is displaying the exact same resolution as the acer. (1680x1050 59.9Hz)
Disable mirrored desktop. You should now have an acer and a crappy CRT both running 1680x1050 in extended desktop mode.
Shut down, reconnect the acer in place of the crappy CRT.
This should "trick" your video card into having the right resolution, otherwise you'll just get the stupid "input not supported" screen, with no ability to auto configure or use any of the built in controls.
Nov 20, 2007 | Acer AL2016W 20" LCD Monitor
E-Machines eMachines Desktop PC Logo
51 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
