Question about Garden
I need to replace the cord. It broke when i tried
I need to replace the start cord on my Troy-bilt trimmer TB20SC It broke when i tried to start it.
StickyBeets
SOURCE: put string on tb425cs troy bilt trimmer
there are two ways to install the string..the cool way is without pulling the inner reel off the trimmer..just leave it in place..cut (2) approx.two arms length (thats spreading your arms out like airplane wings) of .095 string..now, align the arrow of the inner reel (it turns counter clock-wise..the arrow points outward) with the arrow on the outer spool (pointing inward)..holding the spool and reel together so the inner reel doesnt move, push one of the cut strings through the eyehole in the side of the outer spool, and it should come up to the right, through a slot next to a small round hole the diameter of the string..if it doesnt, it just missed the exit (as i call it)..pull out and try again..let about an inch come thru..now take that end of the string and push the line into the little round hole until it stops, which should be about a little more than 1/8 of an inch..hold it in while pulling the excess line outside the spool to keep it in place..now do the same with the other string for the other side..once you have both lines in place, turn the inner reel counter clock-wise to draw in both lines through the eyeholes of the outer spool..you may or may not get all of the line to wind in..not a problem..you will still have enough to do what you need to do..just cut off the rest..one problem you may or may not have that i do most of the tyme is that it gets hard to turn the inner reel..one solution is to bump the top of the 'bump knob' with your fist, then pull both strings at the same tyme, then continue to turn..this method is quicker and easier than the second way of having the inner reel out and trying to wind both lines at the same tyme and trying to place the reel back in the spool..hope this works for you...
Posted on May 19, 2009
  • 10865 Answers
SOURCE: Troy Bilt Trimmer 75SS stalls at full throttle. new gas
Hello. Let me assist you. Since your trimmer runs but stalls at ful throttle it is telling you that there is a fuel problem. Not enough gas is getting through the carbeurator to satisfy the engines needs on full throttle. Most likely the carbeurator is gummed up. A common problem. Let's see if we can un gum it by getting a can or carbeurtor cleaner. Go to any auto parts store and talk to the clerk about your need.
Posted on May 20, 2009
  • 127 Answers
SOURCE: replacing pull cord on 4 cycle gas trimmer, troy bilt
these usually are threaded counter clockwise need a pair of channel locks to hold the flywheel then with the other hand crack nut open
Posted on Jun 30, 2009
SOURCE: Need info on putting line on troy bilt 4-cycle
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
Posted on Apr 05, 2010
rycgl
  • 1545 Answers
SOURCE: troy bilt tb70ss replaced fuel lines trimmer turns
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. The larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Posted on Nov 21, 2010
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy bilt pull cord wont retract
Recoil spring is broken or slipped out of retention slot. Coil needs to be retentioned or replaced. Unless you have done this before I recommend taking to pro. This is easy job if you have the jig but almost impossible if you don't.
Jun 29, 2014 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My troy bilt trimmer tb20sc rope is hard to pull. It all of a sudden stopped working. Took it all apart. Pull on rope off of trimmer,it still works fine. Took off spark plug, piston is moving up and down....
Jard you need to check that the bottom head is clean and there are no obstructions. Then check that the coil is in tight and the nuts are not loose. Finally have you been using the correct fuel mix? Clean the fly wheel with some lubricant spray and sand paper and re assemble.
Aug 31, 2013 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Troy bilt weed eater
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to ss.beepat@hotmail.com
May 06, 2013 | Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas...
My 4-cycle troy-bilt string trimmer: string is locked up. I can not pull the string
Your String needs to be re-wound. You are almost out of string or your string has Jammed under the Motor and placing a DRAG on the Trimmer
Apr 08, 2013 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My troy bilt tb70ss trimmer sounds like something is stripped the motor will wind out but the head wont move its only 1 1/2 years old
will need to check if any debris is wrapped around head jamming the head --or -flex shaft is jammed or damaged separate shaft from motor and will see in shaft the flex shaft that turns the head try turning head by hand and observe flex shaft if binding or broke need to lube or replace
Jun 28, 2010 | Troy Bilt Tb70ss Gas Trimmer
Troy Bilt string trimmer starts but dies when I try to give it gas to trim.
Try mixing up some fresh gas mixture if it is over 30 days old it is considered bad gas. Or the carburetor may need to be rebuilt.
Sep 30, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Pull cord
try this site it may help its called pats small engines
Jun 07, 2009 | Troy Bilt Tb70ss Gas Trimmer
I have a Troy Bilt TBP6040 XP 4 cycle weed eater with the spring assist starting. The pull cord broke and I am trying to replace it but I can't seem to get the cord to go all the way back in. I need help....
I just had this same issue. I found out that you have to take the cord out of the handle then put the spool in. You then rotate the spool back in and align the spool with the spring and fish out the cord which will put a small amout of tension on it. You keep the tension on it and put the handle back on.
Rgds,
Mark J
Apr 16, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
