Question about HP DeskJet 3650 InkJet Printer
DESKJET 3650 GIVING MECHNICAL ERROR ON ATTEMPT TO PRINT. THE GREEN LIGHT KEEPS ON BLINKING YET PAPER IS NOT PULLED FOR PRINTING
    President:
  • HP Master
  • 1,447 Answers
You go to aservice center and service it
Posted on Sep 10, 2009
  • Sazeed Computer
    Sazeed Computer Sep 12, 2009
    your printer is cartridge alignment problem i mean cartridge is not adjust or go to home position so it always busy
    thanks
    Tareq
Green light blinks continuously, printer will not print. Has always worked well until now. Cartridges are in place, printer has paper, is connected to power and to computer. Is there a reset?
One or both print head are defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.If this not help your printer need service.
Oct 29, 2009 | HP DeskJet 3650 InkJet Printer
Sep 29, 2009 | HP DeskJet 3650 InkJet Printer
Printer mechnical error
Resolving a blinking light When an error occurs, the power light will blink continuously and an error message will appear on the computer screen. Read the onscreen error message explaining the problem and follow its solution. If no error message appears, go to the Maintenance section in the Printer Assistant and click any of the four main buttons. This will prompt the software to check the status of the printer and the error message should then appear. The following table lists possible causes and what to do to correct the problem. Symptom Possible cause What to do to correct the problem Power light is blinking Printer cover is open Close the cover. Printer is out of paper Insert appropriate media in the In tray. Printer has difficulty picking up label media
  • Change the printers print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
There is a paper jam Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the Power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
There is a problem with a print cartridge Follow each of these steps until the problem is resolved:
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Power light is blinking and/or there are missing lines or banding issues on the printout The print cartridge has partial loss of electrical interface with the carriage connections
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Sep 10, 2009 | HP DeskJet 3650 InkJet Printer
One of my members has an HP Deskjet 3650 and it
See this article to resolve the blinking lights. Then see this article and possibly this one to clear the print queue. You may have to cancel an active print job to remove it, or reboot the computer. Here is the home support page for that model printer, should anyone have further questions or need more information.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 25, 2009 | HP DeskJet 3650 InkJet Printer
Blinking Light with no cartridge problems
I believe this is normal with HP deskjets. I have a different model but HP deskjet 3740, which also gives a blinking light when there is a pending print job and or printer has run out of paper. I usually get rid of this problem by putting some paper and most importantly removing and re-plugging the printer power cord (which does a basic power reset on the printer and causes a refresh of pending print jobs). I hope this works for you too.
Jan 27, 2009 | HP DeskJet D1460 InkJet Printer
Printer will not print
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | HP DeskJet 3650 InkJet Printer
My hp deskjet 3650 printer can no longer print for me
reinstall the printer... delete it out of printers and faxes and then load it fresh
Nov 21, 2008 | HP DeskJet 3650 InkJet Printer
Printer deskjet 3650
change your cartridge.
but i think your printer got more problems.
Mar 27, 2008 | HP DeskJet 3650 InkJet Printer
HP DeskJet 3650 InkJet Printer Logo
211 people viewed this question
Seeker5211
Seeker5211
