My headphone port is not working in my acer aspire5710z laptop. when pin is inserted in the port, still then the inbuilt speakers are playing, not the headphones or external speakers.
  • 19,396 Answers
Do the following:
Turn off the laptop, unplug power cord and remove the battery.
Put back laptop together, and restart the laptop with headphone jack in. Restart the laptop with headphone in twice.
Third time , while laptop is on, unplug the headphones and restart laptop again.
This will usually fix the headphone problem on Acer laptops.
Posted on Sep 10, 2009
Cant get to play music without headphoes
Most modern computers come with internal speakers already installed, especially laptop computers.
These speakers may be sufficient if you are performing typical computer tasks, but when you play computer games, listen to music or watch movies on your computer, you may want louder and more vibrant sound.
You can achieve this by installing external speakers or headphones. These can be connected to your computer through the speaker or USB ports included on your computer.
Plug in the speakers or headphones.
If the speakers or headphones use a stereo plug, insert the plug into the speaker/headphone port normally located on the side or front of your computer.
This port is often color-coded green. If the equipment is connected using USB, locate a free USB port.
Some external speakers will also need to be plugged into a power outlet in the wall or your surge protector.
This may be all you need to do to get the speakers or headphones to work. If they do not, continue to the next step.
Open the audio settings on your computer.
From the Windows Start menu, open the Control Panel. Here you will find audio and sound settings.
Click the heading to see your sound and audio options.
Choose "Manage audio devices" in Windows 7.
Find your Playback device.
In the Playback tab, you can select your speakers and set them as the default for your system.
If you do not see your speakers or headphones, they have not been installed properly. Disconnect and reconnect them to see if it corrects the problem.
Configure your settings.
Select your device from the list and click "Configure" to test your settings.
You can adjust the volume by using the volume slider on your computer's task bar or using external controls on the speakers or headphones.
Install speakers
http://www.liutilities.com/how-to/install-speakers-to-a-computer/
Aug 05, 2013 | Acer Computers & Internet
Does DELL Inspiron 6400 has a inbuilt microphone? If it does how to make it work?
I am sorry to say but, the 6400/E1505 does not have an internal mic. You need External. Sorry. Specs only show a MIC connection. I/O Ports IEEE 1394 4-USB 2.0 (Universal Serial Bus) compliant 4-pin connectors Flash Memory Slot - Secure Digital (SD) and SD/IO compliant 5-in-1 Combo Card connector - reads MS, MS Pro, SD/SDIO, MMC, xD CD type I/II, & IBM Microdrive through ExpressCard adapter Video: 15-pin monitor connector S-Video: 7-pin mini-DIN connector Audio jacks: Stereo headphones/speakers mini-connector (same as line-out), microphone mini-connector
Dec 09, 2010 | Dell Inspiron 6400 Notebook
I have Laptop ACER Model No Aspire 5610.previously Sound was functioning Properly.Now only after inserting the headphone pin i can hear the sound .if i take out the pin & or if i call from my laptop...
The Speaker of your laptop has a problem. You need to check the connection or it could be the speaker was dusty due to not functioning. Try to clean the speaker of your laptop but if the problem are not solve you need to replace the speaker for that laptop.
May 29, 2010 | Acer Aspire 5610-4648 Notebook
Getting sound from both inbuilt and out speakers spontaneously.
When doing this, you need to adjust your settings in the control panel for the audio. Usually it's defaulted to block sound when you plug in headphones. Make sure you are plugging them into the correct audio output, but it shouldn't play sound from both the headphones as well as the built in speakers.
Aug 21, 2009 | Compaq Notebook 100 Notebook
My Speakers and Microphone on my Dell inspiron 15 Dont work
maybe you have a piece of your head phone jack stuck in the port, does the sound still come through the headphones if you re insert them? or have you tried control panel sounds to see if your default speakers have changed ?
Jul 12, 2009 | Dell Inspiron 1521 Notebook
My laptop sounds from both the speaker when i connect headphone.
First go to control panel, sounds and audio devices
go to the audio tab and make sure that your usb device is selected for audio playback
then, unconnect the headphones and restart your computer
after restarting, connect the headphones and Speakers , it should work
May 04, 2009 | Computers & Internet
Acer aspire 6530 Tuba
I had similar problem and it seemed to be the headphone jack. Inserted my headphone jack a couple of timesand it started working again.
Mar 31, 2009 | Acer Aspire 6530-5143 Notebook PC
Can't mute inbuilt speakers
That is not a software problem.
The headphones/external speakers jack socket has a switch to exclude from audio the internal speakers, when a jack plug is connected.
This is a very simple device and is not software controlled.
The fact that it has gone faulty at the same time you reinstalled the system is a coincidence.
If it does not mute when you insert headphones, all you can do is trying to play with the jack plug , inserting and pulling it out. If this does not unlock the switch, the alternative is having the jack socket replaced by a technician. This is generally an expensive repair, asthe socked is soldered on motherboard.
A cheap alternative to a proper repair is using an external USB to Audio Adapter and mute the internal audicard when using headphones.
Oct 19, 2008 | Computers & Internet
Acer Aspire 5102WLMI speakers
Make sure you have the correct headphones for your computer stereo not mono the inner connector on the computer socket and the headset connector must align exactly if the speakrs still play while the headset is plugged in you have the wrong type of headphones connected try logitech brand Headphones designed for computer listening
do you not have plug specifically designed for a headset on your computer?
Jan 13, 2008 | Acer Aspire 5102WLMi Notebook
Computers & Internet Logo
1,041 people viewed this question
David Payne
David Payne
