Question about Epson Stylus C66 Inkjet Printer
I Have an EPSON STYLUS C66. Paper will not feed: the printer behaves as if the paper has fed correctly.
SOURCE: Epson Stylus Photo R220
I need the software & drivers please 4 epson styuls photo R220 some one send it to wickedwelchtattoos@att.net thank you.
Posted on Sep 30, 2008
gwbm
  • 353 Answers
SOURCE: Epson Stylus C66 inkjet Printer does not print !
Have you tried a cleaning cycle? If not, try one. Now run a nozzle check using the status monitor (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, report back.
Posted on Feb 01, 2009
Atticus30
  • 66 Answers
SOURCE: My epson Stylus cx 3900 won't feed paper anymore.
Your might need new roller pads...depending how long you have the printer or how much it...They are maintenance kits.
Posted on Mar 12, 2009
aicaxz
  • 511 Answers
SOURCE: epson c90 paper feed problem
Is the message general error? The problem is tchip. When turn on chip is recognized by printer, but when start to print, printer "read" some information from the chip. Here is the error. Some pin at the chip for redaing the existence of chip, other pin for reading the information. Check connector between chip and carriage.
Posted on May 30, 2009
  • 7 Answers
SOURCE: epson stylus C66 printer installation cd
You can download the installation software from the epson website. If you have a paypal account contact mncomputerhelp@rocketmail.com and they can take care of it for 20 bucks.
Posted on Aug 09, 2009
Epson c66 not feeding paper
Main reasons for a paper feed problem like the one you describe are:
-. One of the sensor actuators (normally It will be a little plastic lever on the path of the paper) is either broken or blocked. It could happend if you attempt to remove a paper in the opposite direction of the normal paper movement path. Check if you can see something like that near the point where the paper stops.
-. The second option will be dirt on the feed rollers. If you can remove them easily the you can try to clean them using water and soap. In that case what is happening is that the paper reaches the first sensor but the printer doesn't knows the paper is stuck until It detects that the paper arrives later than expected to the last sensor (a timing issue). As the printer keeps printing this is the most probable cause to your problem.
I don't know that model of printer in particular but I hope this serves you as a guide to pinpoint the issue.
Jul 07, 2012 | Epson Stylus C66 InkJet Photo Printer
Paper wont feed through myepson c66 printer..please help..is it the way i'm loading it ?
Some times the paper is the problem. it may damp or old replace it. else the rubber finger that grabbs the paper may need to be replaced.
Aug 29, 2011 | Epson Stylus C66 Inkjet Printer
Both the ink and paper feed button are flashing (Epsom c66 printer)
check for a paper jam or an ink cartridge jam which was not properly aligned. usually thse are reasons. also check your ink levels and never touch the part of the ink cartridge connected to the printer. just keep pressing cancel or X, cancel the documents, then load another paper then press on start copy. this should work.
Jul 08, 2009 | Epson Stylus C66 Inkjet Printer
Epson c90 paper feed problem
Apr 17, 2009 | Epson Stylus C86 InkJet Printer
Printer paper will not feed into the printer
Your printer has a photo switch at paper feed section, this switch is triggered when there is paper and vise versa when there is none, check to see if there is/are some torn pieces of paper blocking or clogging the plastic lever from triggering the switch. A torchlight and a plastic pair of tweezers will help a lot.
Jan 05, 2009 | Epson Stylus Photo 895 InkJet Printer
Nov 12, 2008 | Epson Stylus C66 Inkjet Printer
I've got a epson photo stylus c66
There must be something wrong with the paper roller of your printer.
Oct 19, 2008 | Epson Stylus C66 Inkjet Printer
Epson c66
My clarification request is really a solution.
Sep 25, 2008 | Epson Stylus C66 Photo InkJet Printer
Epson Stylus C66 Inkjet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
