Question about HP DeskJet 3650 InkJet Printer
Printer mechnical error
It is giving me a printer mechanical error when I attempt to print and the green light keeps blinking.
    President:
  • 1,653 Answers
Resolving a blinking light When an error occurs, the power light will blink continuously and an error message will appear on the computer screen. Read the onscreen error message explaining the problem and follow its solution. If no error message appears, go to the Maintenance section in the Printer Assistant and click any of the four main buttons. This will prompt the software to check the status of the printer and the error message should then appear. The following table lists possible causes and what to do to correct the problem. Symptom Possible cause What to do to correct the problem Power light is blinking Printer cover is open Close the cover. Printer is out of paper Insert appropriate media in the In tray. Printer has difficulty picking up label media
  • Change the printers print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
There is a paper jam Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the Power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
There is a problem with a print cartridge Follow each of these steps until the problem is resolved:
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Power light is blinking and/or there are missing lines or banding issues on the printout The print cartridge has partial loss of electrical interface with the carriage connections
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Posted on Sep 10, 2009
The green light keeps on blinking and it does not print at all
It is problem in mechanical.May be any paper stuck or any sensor displace.So you need service your printer.Keep your mind green lid blinking mean printer busy.also check printer black cartridge.
Apr 11, 2010 | HP Deskjet D2360 InkJet Printer
LED light keeps blinking
That is a service error code, but you need to count how many blinks between the longer green blink, and that tells the error code...
Oct 13, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Keeps blinking. I've shut it off, and cancelled all print jobs - even unplugged it. Keeps blinking. Says there is an operator error
Try this:
1. Turn off printer (use button, don't unplug)
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
If this not help may the print head is defective.
Oct 07, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i860 printer not working
The error code says that your printhead is bad and needs to be replaced. QY6-0049-000 around $40.00
Jun 30, 2009 | Office Equipment & Supplies
Konica Minolta 2400W Magicolor. Error light blinking
Ready indicator Error indicator Condition Action
Green Orange
Blinking Blinking Communication Check The Printer
error cable
____________________________
Print over-run Turn off the printer.
After a few seconds
turn on the printer
change to a lower
resolution.
________________________________________________________
This may help if not...let me know........Whytfang
Mar 25, 2009 | Konica Minolta magicolor 2400 Laser...
Operator Error Canon i850 printer
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Dec 09, 2008 | Canon BubbleJet i560 InkJet Printer
Both red lights on my printer are blinking
Blinking wit general error message : head carriage error. It cause by head cannot move to parking position or chip at ink tank not good connected. Try to use another chip. Just turn off printer for a moment for clearing epprom.
Nov 09, 2008 | Epson Stylus C83 InkJet Printer
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
HP DeskJet 3650 InkJet Printer Logo
415 people viewed this question
Seeker5211
Seeker5211
