Question about Lexmark X125 All-In-One InkJet Printer
Lexmark x342n not sending faxes message: sending page 1, but nothing happens. What should I do?
Fax memory full lexmark x
Memory full, cannot send faxes
The printer fax memory is full. Press the check mark button to clear the message and cancel the fax.
• Reduce the fax resolution and try to send the fax again.
• Reduce the number of pages in the fax and try to send the fax again.
http://www.edvdrucker.de/Downloads/Handbuch/Lexmark/Lexmark-X254-User-Guide.pdf
Jul 09, 2014 | Lexmark X364dn All-In-One Laser Printer
Hello, i have the Lexmark X342N the machine will recieve the fax store it to memory, but it will not print the fax. Toner was low and could be the problem. (replaced toner) How do I print the recieved...
Please try to do the following steps
1 From the control panel, press Fax.
2 Press Menu.
3 Press up or down button repeatedly until REPORTS is selected.
4 Press the check button
5 Press up or down repeatedly until Fax Call log or Fax Job log is selected.
6 Press the check button to submit
For further assistance, please contact Lexmark Technical Support.
Feb 22, 2011 | Lexmark X342n All-In-One Laser Printer
My faxes are not printing. They seem to be connecting but they won't print.
Tips and tricks For the LEXMARK X342N
1) Faxes won't print.
Try this first....
Press <MENU> then <*> <#> on the keypad
Press <UP ARROW> and see "UTILITIES RESET SYSTEM"
Press <CHECK MARK>
and see RESET SYSTEM
Press <DOWN ARROW> and see (FAX NVRAM)
Press
<CHECK MARK> should reset the fax memory.
Try this second....
Press <MENU> then <*> <#> on the keypad and see "SERIAL NUMBER"
Press <CHECK MARK>
Press <DOWN ARROW>
<DOWN ARROW> <DOWN ARROW> and see (ERASE FFS)
Press
<CHECK MARK> should reformat the fax memory.
It will reboot. Occasionally says the FAX NVRAM is bad
when performing the boot-up self-test and corrects the problem.
2) PC LIFE WARNING message
After replacing your photo conductor kit you need to reset the "PC LIFE WARNING" message. With the front toner door open press and hold the red <STOP> until you see the "RESETTING PC COUNTER" message
Mar 15, 2010 | Lexmark X342n All-In-One Laser Printer
I have Multi funtional Lexmark x342n machin. but i don't know,How to send fax from my machin.
have you installed the driver properly then good .in printer a fax printer is also installed when you install the full software of printer driver .for sending fax from any document choose the print option and in printer select the fax printer and send the fax.
but make sure fax printer is installed.
Jan 14, 2010 | Lexmark X342n All-In-One Laser Printer
Lexmark x342n all-in-one printer paper jam
Is any part of the page imaged?
What is happening is that a paper sensor is either hung or jamed so that the sensor is incorectly reporting an error .
I would remove the cartridge and using a flash light search for any scrap of paper that may be in the paper path. If you can't find any, I would next looked for a sensor flag to see if it is jammed out of position.
Of course, you could always call a service tech or even better submit this question to Lexmark Technical Support for more in depth assistance.
May 31, 2009 | Lexmark X342n All-In-One Laser Printer
My Office Printer Lexmark X342n is not accepting any command
Upgrade firmware, sounds like old firmware used. Kinda basic problem with fax usage.
Contact local lexmark for firmware upgrade
That should fix the problem
May 05, 2009 | Lexmark X342n All-In-One Laser Printer
Remote fax error when sending a fax
Does it only happen going to one certain fax destination or every destination? There are some things to try on the Lexmark web site.
Go to www.lexmark.com and click Support->Technical Support. Type in 4270 in the 'Search by Model' box. Type in 'Remote fax error' in the 'Search the Knowledgebase' box. There is a topic called 'Problems Sending a Fax to Specific Fax Machines' that has some good general tips.
Steve
Feb 26, 2009 | Lexmark X4270 All-In-One InkJet Printer
Fax machine having difficulty to send and receive multi -pages
it is possible that the memory is corrupted, Or the ECM (Error Correction Mode) is not enabled,
What happens when None go through, is there a jam? or does it just drop the call.
Maybe setting the machine to print a Confirmation page will help to isolate the problem?
could also be the Phone line, is this a direct line?
What happens when you move the machine to another phone line.
Do this happen when you try to print?
Here are the basic specs of the machine?
The Transmission rate 3 pages per minute,
64MB of memory
(I have seen faxes bog the memory because of compression and dpi, I dont think this is the problem here)
Available Compression MH, MR, MMR,
DPI Modes :200X100 dpi, 200X200 dpi, 300X300 dpi
This is the User Manual for this machine..
http://www.lexmark.com/publications/pdfs/x34x/eng/ug.pdf
Aug 12, 2008 | Lexmark X342n All-In-One Laser Printer
Lexmark X342n MFC cannot print faxes
Contact Lexmark and get updated firmware - had this problem on an X342n unit yesterday and applying an update (now shows firmware LC.MD.P114 ), faxes started receiving properly.
Nov 14, 2007 | Office Equipment & Supplies
Lexmark X125 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
