Question about HP PSC 1610 All-In-One InkJet Printer
COPY NOT WORKING. PROBLEM SAING COPY 1/1 PAPER GOING IN THE STOP
I just received a Xerox 5334 copier. We moved it to our house, powered it up, and ran a test copy (just a sidebar thought...it spit out one copy and a blank paper). I left it on to go retrieve the work I...
Code U4-1 is Over heat or under heat, even if you solve this problem you mentioned that you have a copy from the machine which is Blank, the reason is that the print cartridge is dead, it is not holding charge, and even if you find a new one in a box sealed, I am 99.9 present sure that it is not going to work either, it is an old expired cartridge, basically do not waist your time and money, I serviced these machines and I know.
Mar 23, 2017 | Xerox Office Equipment & Supplies
Instructions for scanning on epson cx4300/cx5500/dx4400
Scanning the Document
Place the original on the glass.
1) Open the document cover and place your original face-down on the glass, in the upper left corner. Move your original about 1/10 inch away from the top and left edges so all of it will be copied. 2) Close the cover gently so you don't move the original . Caution : Never open the document beyond where it stops and do not place heavy objects on top of the CX4600. If you need to copy or scan a thick or large document, you can remove the document cover. Just open it and pull it straight up. If you need to press the document flat while you copy or scan it, do not press too hard and be careful not to move it. Caution : Do not use excessive force on the document cover, and do not twist it diagonally. You may damage the document cover. When you are done, replace the document cover by inserting the tabs back into the slots. Copying a document. 1) Load paper. 2) Press copy button until you see the desired number of copiesin the Copy window You can select up to 9 copies at a time. 3) Press the paper type button to select PLain Paper. The light indicates which type is selected. 4) Press the paper size button to select Letter. 5) If you want your copies automatically reduced or enlarged to fit the loaded paper size, press the Fit to Page button. 6) To make color copy, press the Start Color button To make black and white copy, press Start B&W button. The ON light flashes and after a moment the CX4600 starts printing. If you need to stop copying at any time, just press the Stop button. Do no pull out paper that is printing, it will eject automatically to the output tray. Hope this helps. Please rate my response. Thanks Have a good day.
Nov 25, 2009 | Epson Stylus CX4600 All-In-One InkJet...
How to do copies,ie what buttons do i press
Making a Single Copy
Place the original face down in the ADF.
2 Press Copy/Help twice.
To cancel, press Stop.
Do NOT pull on the paper while copying is in progress.
Copy Options: Single or Multiple Copies,
Reduce/Enlarge, Sort/Stack
You can choose additional copy options. First, you can select the number of copies. Next, you can
choose whether multiple copies will be STACKED (all copies of page 1, then all copies of page 2, etc.)
or SORTED (collated). Finally, you can choose an enlargement or reduction ratio. To automatically
reduce the copy to the paper size you have set for the paper tray, select AUTO. To reduce the copy by
a fixed percentage, choose 93%, 87%, 75% or 50%. Or, to enlarge the copy, select 150%, 125% or
120%. To copy a document at its original size, select 100%.
1 Place the original face down in the ADF.
2 Press Copy/Help.
3 Enter the number of copies you want (1-99).
For example: Press 9 for nine copies.
To start copying now, press Copy/Help.
If you would like to select additional copy options, like
SORT, ENLARGE or REDUCE, press Menu/Set.
Oct 02, 2009 | Brother FAX-T74 Plain Paper Thermal...
Xerox 3001 Copier. I installed new toner and the
Paper must cover the center to hit the sensor. If paper still goes through without stopping, the paper drive clutch is faulty.
Aug 25, 2009 | Xerox 3001 Copier
Copier stops after 35 copies when using finisher
This is due to the output tray you sre using only having a small capapcity sensor what you should do is set it to come out from the finisher unit to the lower tray as this holds more sheets you can check this by looking at the output tray and when it asks you to remove paper see if the top pages are resting on the paper sensor in the tray. good luck A
Jun 02, 2009 | Canon imageRUNNER 400S Copier
Mfc 8460n paper jam
Check to see if this happens when you use the drop down manual feed tray. If your printer works fine using the manual feed tray the problem is with your paper tray. Check to make sure it is set to letter size. I've found that sometimes the 'teeth' holding the paper stop on the paper tray wear out and when the printer goes to pick up paper, it pushes the paper stop out of position causing the printer to think it's using a different, much longer size paper thus preventing it from feeding all the way through. You'll probably need a new paper tray if this is the case.
Jan 06, 2009 | Brother MFC-8460N All-In-One Printer
Problem printing on matte photo paper
no thats why it is not working the right way you have to use the semi gloss paper thats what it requiers
Jan 03, 2009 | Brother MFC-3240C All-In-One InkJet...
Paper jam
salu béa commen sa va
Sep 14, 2008 | Canon PIXMA MX310 All-In-One Printer
Printer and Making Copies does not work!
Will the machine run a paper path test?
This sounds like it could be a sensor indicating a paper jam, if this is the case, it won't run anything through the paper path (not even a blank page).
Nov 26, 2007 | Sharp UX-B20 Plain Paper Inkjet Fax
HP PSC 1610 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
