Question about Ryobi Garden
How do you change the fuel filter on a ryobi backpack blower Model RY08570?
  • 388 Answers
Disconnect the fuel Line from the carburetor and, using needle nose pliers, grab the fuel line in the tank just behind the filter and pull the line and filter out of the tank. BE CAREFUL YOU DO NOT PULL THE LINE ALL THE WAY OUT OF THE THE TANK!! Pull the filter off and replace with the new one and put the new filter back in the tank, then reconnect the other end of the fuel line to the carburetor. Hope this helps!
Posted on Sep 15, 2009
I get shocked at the hand grip the longer engine runs & as rpms increase, also get shocked when shutting blower off. Thanks
I believe that you are experiencing static electricity build up. As air passes through the blower, it creates a static charge. These normally bleed off over time.
When the air is dry, the electrons can hang around on your body for a long time, charging you up to thousands of volts. That can last until you touch something that can conduct them away, like a doorknob or your significant other.
You are not the first to experience this phenomenon.
Apr 16, 2015 | Ryobi Ry08570 Backpack Blower Engine...
I need to replace the fuel lines of a blower, where can i find the lines
You might just forgo this and buy a complete tank! They come with new lines, filter and gas cap! They cost about 10-15 bucks and are a quick swap. Part #37 on the main diagram fro ereplacementparts! $12.20.
http://www.ereplacementparts.com/ryobi-ry08570-backpack-blower-parts-c-7931_15636_15640.html
Oct 06, 2014 | Garden
What is the carb model # for zr05870, Its a Walbro carb?
From the pictures in the parts breakdown, this appears to be one of the newer model rotary-type carburetors. It is listed as part number 308028001. There is no mention of this machine in the Walbro carburetor application guide however. After viewing the picture and with the prefix of the carburetor known, you should be able to locate it on the Walbro website. I have the link to your machine's parts breakdown and to the Different Walbro models. Please view:
http://wem.walbro.com/distributors/servicemanuals/
Jun 28, 2011 | Ryobi Backpack Blower 25.4cc
Ryobi Backpack Blower Elbow
the home depot stores sell ryobi so i think they might have it if not they sure can get it for you, or you can always go to the ryobi website and try purchasing it that way.
Jan 23, 2010 | Ryobi Backpack Blower 25.4cc
Ryobi backpack blower will run all day with choke up but as soon as I pull the trigger it starts bogging down
Thats a lean condition. Check fuel lines and fuel filter. If the fuel ilnes are discolored or stiff or really super mushy, If the fuel filter has become detatched from the fuel line then the fuel lines need to be replaced.
If the carb can be adjusted you can try to adjust but its likely that the carb should be rebuilt with new diaghrams and gaskets.
Adjust by turning the low speed screw out ( counterclockwise) 1/2 a turn. The low speed screw is always the one closest to the motor and usually marked on the carb body with an 'L'. When you richen a motor up the idle will drop so you will probably have to turn the idle screw in 1/2 a turn. 1 and 1/2 turns out from light bottom is standard starting point ( 2 turns for poulan products). If you get more than 3 and 1/2 turns out on the low speed screw or if turning the screw has little or no effect then the carb should be rebuilt.
Dec 12, 2009 | Ryobi Backpack Blower 25.4cc
MODEL RYO9600 LEAF PULLSTART BLOWER MISSING FLEX HOSE TO WAND
Go to this link for the Ryobi parts. You can get one for less than $5.
http://www.ereplacementparts.com/ryobihm-ry09600-backpack-blower-parts-c-7931_15636_130605.html
Oct 17, 2009 | Ryobi Garden
Ryobi blower will not start unless primed by
If it is under 2 years old, I would take it to a warranty repair center. The carburetor have been giving some problems so they have needed to be replaced because they are sub standard quality.
Sep 28, 2009 | Ryobi Backpack Blower 25.4cc
Ryobi gas blower model #ry08570 need gas and oil mix
try 40 to 1 ratio it should say on the blower if not check the ratio on the bottle of 2cycle oil it will tell you how much oil to add to a gallon of gas
Jan 09, 2009 | Poulan Weed Eater Electric Blower/Vacuum...
Garden Logo
374 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
