Question about Pioneer (DVR110D) DVD RW Dual Layer Burner
Cant burn to DVD-R from windows DVD maker
I have a sony vaio laptop with built in cd drive. When I go to burn my DVD from the windows dvd maker I get an error telling me
'A DVD burner was not found. make sure a DVD burner is connected and installed, and then try again.'
I have managed to burn a DVD using this program in the past with no problems and have to get this project finished ASAP.
NEEP HELP !!!
  • kristyabaker Sep 10, 2009
    Thanks for your help however I have done all the way up to step 15. When I click 'Burn' I get the error that there is the DVD burner was not found. Any more advice ?
    Scholar:
  • 29 Answers
Just got this off the web and mind sharing it to you...
If you're using Windows Vista then this should be it...However, this may or may not work.
Try to turn off the vista's burning feature.
It's not yours or anyones burners....just an update in vista which buggered the policies up
Go to your run command and type (start.....Run.....)
type gpedit.msc
Go to User configuration/Administrative templates/Windows components/Windows explorer
On the right pane, double click on "Remove CD burning features" tick the enabled button, then OK.
Reboot or logoff/logon to apply.
If your vista version does not have the gpedit function, do the following.
Open regedit, go to:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
In the right pane, if it does not already exist, create a new 32-bit DWORD value. Name the new value as NoCDBurning, and assign the value data to 1.
Hope this helps!
Posted on Sep 10, 2009
    Scholar:
  • 66 Answers
  1. Make sure that you have at least five gigabytes of free space on your hard drive. To check this, go to “Start” and select “My Computer.” Look to your “C:” drive and make sure that you see at least 5 GB free or something similar.
  2. Step 2 Insert a blank DVD into your DVD drive.
  3. Step 3 If you have “Autoplay” enabled, a popup screen should appear asking you what action you wish to take. If so, select “Burn a DVD Video Disc using Windows DVD Maker.” If not, go to Start and then “Search” and type in “Windows DVD Maker.” After it appears in the list, select it by clicking on it. The Windows DVD Maker screen should appear. If you want, you can “uncheck” the box that says “Don’t Show this Page Again.” If you do that, this screen will appear the next time you burn a DVD.
  4. Step 4 Click on the button that says “Choose Photos and Videos.” On the next page, you are to select the files that you wish to burn. You can click the “Add Items” button at the top and then search through various folders on your computer to find the file that you want or you can open the folder that has the file(s) you want, “left-click” the mouse and hold it down over the item and then drag the item into the blank list in the Windows DVD Maker screen. Either way is acceptable.
  5. Step 5 Go to the bottom of the DVD screen and click inside of the box that is marked “Disc Title.” You can replace the date with whatever name you want to give your soon-to-be DVD. If you do not want to go too in-depth with this software at this time, skip down to step 8.
  6. Step 6 For the most part, you can leave the “Options” button alone. However, if you choose to click on it, you need to understand what the settings mean. For instance:
    • “Start with DVD Menu” means that, whenever the DVD is inserted into a player, the home screen will appear and you will have the option of selecting Play or which scene you wish to view.
    • “Play Video and End with DVD Menu” means that the movie will start the moment the DVD is inserted into the player and return to the home screen when the movie ends.
    • “Play Video in a Continuous Loop” means that the movie will keep playing as long as the DVD is in the player.
    • “DVD Aspect Ratio” refers to the screen the movie will play in. 4:3 is the standard video screen for the United States, while 16:9 is the international standard.
    • “Video Format” determines which kind of DVD player you disc can play on. “NTSC” refers to American DVD players. “PAL” refers to DVD players made abroad.
    • “DVD Burner Speed” refers to how quickly your DVD burning project will take to be completed.
    • “Temporary File Location” is the reason you need at least 5 GB free. When you burn a DVD, your computer makes a temporary copy of your new disc and stores it on your main hard drive. If you don’t have at least five free, the DVD burning process will be significantly slowed.
    Simply click cancel if you decide to make no changes under Options.
  7. Step 7 Your DVD software will automatically burn DVDs to your “E:” drive. However, if you have a separate DVD burner, you can select “DVD Burner” and choose your device instead.
  8. Step 8 Scroll to the bottom and click “Next.” The “Ready to Burn Disc” screen should appear. On this screen, you have the option of choosing the look of your DVDs home screen. If this is not important to you, you can skip down to step 13.
  9. Step 9 “Preview” allows you to see what how you DVD will behave in a player once it is completed. “Menu Text” allows you to choose the Font that you want your DVDs title— as well as the “Play,” “Scenes” and “Notes” buttons—to have. When you click that button, you will see various tabs on the next screen. From there, you can change the name of any of the buttons. For example, if you would prefer the Play button to be labeled “Happy Dragon Fun Time,” this is where you would type that in. The “Notes” button is unique. If you delete the word Notes and keep the Notes box empty, the button will disappear entirely on your new DVD. I recommend changing the word Notes to Synopsis and adding a summary of your movie to the large, empty Notes box.
  10. Step 10 Click “Change Text” to complete the changes you made or “Don’t Change” to reject them.
  11. Step 11 “Customize Menu” allows you to change the particulars of your DVD. You can change the overall shape of the buttons at the “Screen Button Styles” tab or add Back- and Foreground videos to the home screen from anywhere on your hard drive. You can even add an audio file of your choice. Click “Change Style” to complete the changes you made or Don’t Change to reject them.
  12. Step 12 “Slide show” allows you to create a slideshow to appear when your DVD is inserted into a player. You can add music and whatever pictures you want. You can also change the duration that each picture stays up on the screen. Click “Change Slide Show” to complete the changes you made or Don’t Change to reject them.
  13. Step 13 You should be back to the Ready to Burn Disc screen.
  14. Step 14 On the right hand side of the screen, you should see a list of “Menu Styles.” Select the one that you want but keep in mind that each Menu style has its own font and button shape.
  15. Step 15 Click “Burn” to begin the DVD burning process or Cancel to exit.
  16. Step 16 After the disc is finished, your computer will ask if you wish to make another copy of the disc. If you select “OK” you will then have to insert a new DVD and re-burn the movie. However, you will not have to start over completely. If you select “Cancel” or click the red “X” in the corner, you will return to the Ready to Burn Disc screen. If you click the red X again, you will be asked to save your project. Name the project whatever you wish. Your DVD is now burned and ready to use and you have a copy of the specifications you made. If you want to go back later on and re-burn this DVD, all you need to do is click the “Saved project file” and have a copy of the film on your hard drive.
  17. if the problem persist then you have a problem with your storage device.if not satisfied please contact me with any question you need to know
HELP! with Optiarc DVD +- RW AD-7700H I have a Sony vaio that operates with Windows 7 I have now upgreaded to Windows 8.1 and now i cant see my DVD drive i have tried everything.
There is no media player within the standard OS. Upgrade to Professional or download drivers and a system to play Video and Audio.
May 03, 2015 | Sony Computers & Internet
Forgot Sony Vaio password
I met the same difficulty for the previous period,and I know the easy an effive method that you can use Windows Password Reset to solve it by the Internet,while the use method is following.
Tip1:Download Windows Password Reset from http://www.windowspasswordreset.net and install it on other unlocked computer.
Tip2:Burn Windows Password Reset to CD/DVD or USB.
Tip3:Insert newly created CD/DVD or USB to your computer which you forgot its password and reboot it,and follow the instruction that follows.
I hope it can help you soon.
Jul 25, 2012 | Sony Computers & Internet
Whenever i try to burn a dvd it says "writing speed for dvd is not correct please insert another cd with correct writing speed ' what shud i do?? i m using sony vaio with windows 7
check if your DVD disks is compatible with the DVD drive
and then when you burn the DVD use the lowest speed to burn the dvd
Jan 31, 2011 | Balance Notebook
My computer does no see my dvd rom drive
CD/DVD Drive is missing from the Computer window and it's having an yellow exclamation mark in the Device Manager?
try these steps
May 03, 2010 | Sony VAIO VGN-N130G/W Notebook
I have a Sony Vaio desktop with XP. My DVD-CD
Have you tried burning a CD in the new drive? Because the drive is a DVD it will always be recognised as a DVD, but should work perfectly well with CDs both playing and recording.
Nov 07, 2009 | Sony VAIO Digital Studio PCV-RS220 PC...
Matshita DVD-Ram UJ870QJ
i have sony vaio vgncr353 L n my dvd r/w is not working properly.
my vaio have matshita dvd ram uj870qj ata device n read and write cds n reads burned dvds but cant burns blank dvds.. so pls solve my problem.. quickly
Jul 23, 2009 | Sony Computers & Internet
Cd dvd writer not working
Try to reload the operating system using disk/Alt+F10 first and try to burn again.
If this is still not working. it probably your dvd rom is bad.
Jan 27, 2008 | Acer Aspire 3680 Laptop
Sony Vaio pcg-frv37 dvd rom not working
you need a DVD burner in it to play and Burn DVD's
you have a CD Rom in it now.
Dec 17, 2007 | Sony VAIO FRV37 Notebook
Pioneer (DVR110D) DVD RW Dual Layer Burner Logo
184 people viewed this question
Top Pioneer Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
