Question about Cooktops
Hi I am trying to locate cutout dimensions for a westinghouse sillouhette gas cooktop model no GHC10 WNG00 thankyou
    Novelist:
  • 222 Answers
Hi...much beter to actual measure the unit before make an cut out.
Posted on Sep 13, 2009
I have a Gaggenau cooktop, two VG223-802 and one center VR122-612, need countertop cutout dimensions for the three.
-Take measurement yourself and cut to any size you want.
It's sample
Good luck
Mai
Dec 27, 2017 | Gaggenau Cooktops
Do you know the BTUs for the five burners on this cooktop?
WEIGHTS & DIMENSIONS Approximate Shipping Weight 38 lb Cabinet Width 36 in Cutout Dimensions (Width x Depth) (In.) 33-7/8 x 19-1/16 Net Weight 33 lb Overall Depth 21 in Overall Height 3 1/16 in Overall Width 36 in Space Required Below Cooktop 0 7/16 in
  • POWER / RATINGS POWER / RATINGS Burner BTU Ratings (000's/BTU) - LP Gas (1) 9.4; (2) 7.0; (2) 4.0 Burner BTU Ratings (000's/BTU) - Natural Gas (1) 12.0; (2) 9.5; (2) 5.0 Volts/Hertz/Amps 120V; 60Hz; 5A
  • ACCESSORIES ACCESSORIES LP Conversion Kit Included
  • WARRANTY WARRANTY Parts Warranty Limited 1-year entire appliance Labor Warranty Limited 1-year entire appliance
  • GE 36 Built In Gas Cooktop JGP636WEDWW GE Appliances
    Oct 27, 2015 | GE Profile JGP636 Gas Cooktop
    How do I clean under the electric elements on my basic westinghouse stove
    Hello friend, thanks for your post!
    I understand that you would like to clean under the cooktop on your Frigidaire range. Could you provide me with your model number please? You can locate the serial tag (which lists your model number) on the storage drawer on the right hand side. With this information I can better assist you. -Matt
    Sep 16, 2014 | Electrolux White Westinghouse Stove Range...
    I have a Jenn air c221 cooktop in need of replacement what are the dimensions of this unit.
    Here are the dimensions for the Jenn air c221 cooktop. Hoping this will help.
    width 29 15/16th of an inch.
    depth 21 9/16th of an inch.
    cutout width is 28 7/8th of an inch.
    cutout depth is 20 15/16th of an inch.
    Feb 04, 2011 | Cooktops
    I just bought a 7904427 electric kenmore cooktop, which isnt installed flashed to the countertop, there is 2 mm gap between countertop and cooktop, cooktop sits on the 8 brackets instead of the flat...
    From my experience, most cooktop manufacturers give cutout dimensions that almost always need modifications to get the screws or nuts on the stove to fit the cutout. Have your granite fabricator come enlarge the opening by grinding specifically where there is interference. They should be able to tent off your granite and use a vacuum to minimize dust.
    Feel free to contact me with any questions. Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
    Jan 09, 2011 | Kenmore 30 in. 42701 / 42702 / 42709...
    I have a Tappan cooktop model 13-3381 that needs to be replaced. Can some give me the cutout dimensions for this cooktop? Thank you
    20 1/2" x 32 1/2" is the cutout. We have the Tappan model 13-3381. I need a new switch for the lft, bottom burner.
    Sep 30, 2010 | Cooktops
    Can i install bosch cooktop in a 26-1/2 by 19-1/2
    No you will not be able to put in that cut out. The reason why is you will have 2 inches on each side or 4 inches on one side.
    Apr 17, 2010 | Bosch PCK755UC 30 in. Gas Cooktop
    GE Cooktop drop-in model # jgp328bec2bb - how to take apart the cooktop,I need to replace the spark ignitor switch harness.
    Turn off the gas,unplug the power.
    Take the cooktop out of the cutout and support it on the countertop.
    Remove all grates and valve knobs.
    Remove all screws from the valves and the burners.
    Remove the burner base plates.
    You may have screw on the side holding the top to the base,if so,remove these too.
    The top will separate from the bottom exposing your parts.
    Feb 11, 2010 | GE 30 in. JGP328 Gas Cooktop
    I want to replace my Jenn-Air cooktop model 89890. What is the easiest replacement cooktop?
    Greetings!
    I tried to look up your cooktop and only found it mentioned in several places, and thus did not get a complete description of your unit. What I got leads me to believe that yours is a downdraft model. Whether or not this is correct, you'll need to measure the underside (cutout) measurements of the cooktop and the physical dimensions of your unit within the cutout. Armed with this information, you should be able to make an informed decision. I recently replaced a Jenn-air (downdraft, with switchable cooking modules) and selected a GE profile modle JP 989SK1SS (stainless steel). We also considered Frigidare, Jenn-air and some of the higher enders as well. Our preference boiled down to features, keeping all of the appliances (mostly) in the same brand, and reliability. Ours swapped out very close deminsionally, and the installation was easy and neat. Decide on a brand. Most dealers have a brochure that list all of the critical dimensions of their appliances, and you should be able to decide what's best for you.
    Hope this was of some small help. Regards, and good hunting!
    --W/D--
    Jul 17, 2009 | Cooktops
    Poor gas flow to GE cooktop
    Try a bigger inlet pipe sounds like pipe too small for load .
    Apr 11, 2017 | GE 36 in.JGP970 Gas Cooktop
    Cooktops Logo
    173 people viewed this question
    Top Cooktops Experts
    Paul Carew
    Are you a Cooktop Expert? Answer questions, earn points and help others
