Question about OKI C5400 Laser Printer
Getting service error 182 and clunking roller noise
Front end clunking noise
Usual cause is roller bearings. Try to oil them they are probably rusty at worst you will have to replace roller. But this is as very good machine. Good luck
Jul 06, 2014 | Precor Exercise & Fitness
Landice executive L8 treadmill makes clunking noise when I run on it
You need to get someone out to look at it. Noise issues are rarely able to be diagnosed remotely.
Mar 21, 2013 | Landice L8 80 LTD Executive Trainer...
I have an Error 2 that happens when trying to scan a document. It makes a clunking noise. How do I fix this? Thanks in advance!
E2 error means is a paper jam.
Solution 1
Turn the printer off, then on again. Sometimes, when Pinter turned on, the position of the wheel is not correct, causing the error E2. By turning off the printer and then turn back, the position of the wheel will return to normal. This way I've ever done and it worked.
Solution 2
You turn the sensor vertically, as opposed to clockwise. By rotating the sensor vertically, roller wheel position to be shifted, so it will return to normal position. Rotate the sensor vertically, until you hear the sound (clak) of the wheel roller.
Nov 13, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Songs und Bilder auf CD brennen nicht mehr möglich. Fehlerbeschreibung: Keine Verbindung zu Windows IMAP 12 CD Engine möglich.
Songs und Bilder auf CD brennen nicht mehr mã¶glich. Fehlerbeschreibung: Keine Verbindung zu Windows IMAP 12 CD Engine mã¶glich.
Above Question in English:
Songs and pictures onto a CD no longer mã ¶ possible. Error Description: Unable to connect to Windows 12 CD IMAP Engine mã ¶ possible.
Answer:
Your quesion is not clear and full.
I think:
you have problem when burning cd with Media Player 12.
Go to services in Control Panel > Administrative Tools or type and press enter services.msc at command prompt.
Enable the following service to Automatic mode and press start button:
IMAPI CD-Burning COM Service
Now log off / restart.
See the problem solved or not ?
If the problem is not solved then - fully describe your issue here.
Thanks for using Fixya.
bcdalai
Aug 03, 2010 | Computers & Internet
The rear roller appears to be making noise as if bearings are going bad. Is there anything to replace or grease?????
Pretty much the bearings have flatten if you are getting a clunking sound these are normally sealed bearings and it is better to replace the roller. Call Icon Fitness @ 1-800-999-3756
Apr 09, 2010 | Reebok 8700 ES Treadmill - Silver Service...
A clunking noise when running and the dryer still dries
The noise you hear is from a worn bearing that is centered in the belts roller bearing for the be;t tensioner. Sears can get you the replacement parts since they sell these models. they will come as a kit with a belt and the roller assembly with the bearing
Mar 27, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer has developed a noise (clunk) as it turns
the clunk is from a worn bearing on the belt tensioner that the drums belt goes through. If the bearing freezes up the rubber layered roller will get out of round and sound like a drummer beating on a drum
Feb 08, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer squeaking & Clunking noise
Your particular unit has quite a few things that could be making a real loud noise.....The idler pulley, blower wheel, rear drum rollers, front drum glides. Bottomline is you have to get in there and take the unit apart..vacuuming while there and if the unit is making such a noise, it will be obvious where the problem is.....If I can help further, I am here.......
Eric Campion
Mar 04, 2009 | Dryers
OKI C5400 Laser Printer Logo
291 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
