Question about Kenwood KAC-629S Car Audio Amplifier
Watt size fuse do i use to connect a 350 watt stereo/bridgable amp using a 4 gauge power cord
    Guru:
  • 1,326 Answers
You use the same amp fuse as on your amp, nothing larger. The fuse just keeps the wire from overheating/shorting and causing a fire.. IF you amp has a 30 amp fuse then you use a 30amp fuse off the battery
Posted on Sep 14, 2009
I have a 2000 w volfenhag amp and a 15 in cadence 350/600 rms watt sub, what gauge wire should i use?
I would use a 4 gauge wire for the power supply to the amp and a 4 gauge neg of the amp
Jun 25, 2016 | Volfenhag Car Audio & Video
Is a Adcom GFA-7500 5 channel power amplifier bridgable?
no this AMP is not bridgable to get more power out of this amp you need 4 ohm speakers.
Power rating
1 - 150 watts into 8 ohm speakers
1 - 225 watts into 4 ohm speakers
Feb 23, 2011 | Adcom GFA-7500 5-Channel Amplifier
We have a power back generator 5050 watt we are trying to install the cord to plug into our house, what size cord do we need
If you are wanting to connect using the 120/240 outlet, I would use a #12 gauge 4 wire cable. If over 25 feet, then I would use a #10 gauge. The wire size will make a difference, so that is why I am offering the two sizes. Please make sure that you have a transfer switch if you are connecting to the panel. This will prevent someone from getting seriously hurt or killed.
thanks Joe
Jan 10, 2011 | Coleman Powermate Powermate 5000W...
Cannot get pyle driver 413 bridgable mosfet1000 watt amp to work with 800 watt subwoofer . followed instructions all the lights are lit but no sound need help
just wondering how you connected the amp . you should do the following steps
1 battery cable with right size fuse at battery
2 remote wire from radio
3 rca cable from audio out from radio
4 ground the amp to a good clean piece of metal
then make connection on the amp
1 battery or power cable to the 12volt connector on the amp
2 remote wire to b+ or rem on the amp
3 rca cabel should be pluged in the channels are using cause you tell me that the amp is 4 channel
from the model numbers
4 clean and scrape off paint on the metal surface you are going to install the ground cable from the amp . make sure your ground is no more than 12 inch max. and is the same gauge as the power cable
5 . run your speaker wires to the amp and make sure your ohm load for the subwoofer is 2 ohms or 4 ohms to make the amp work proper .
if need help on anything email me @ caraduioquestion@gmail.com
Oct 29, 2010 | Pyle Car Audio & Video
How to hook up a kenwood amp.kac-5204
All amps are basicly the same. It should be plain as day where the speakers connect to.
The 12V screw connects to the main power from battery, be sure to fuse that wire and use a proper size wire, thicker is better,I suggest at least 8gauge with 40amp fuse. The GND is ground and should connect to car metal, file paint for soild connection. The REM is remote and connects to the remote of headunit or if you have a stock deck to the acc of car found in wire harness of headunit. Plug in the RCA's to head unit, or get a converter to plug into speaker wires from car if you have a stock headunit.
Mar 22, 2010 | Kenwood KAC-5204 350 Watt Max Power Stereo...
How many watts are in the kicker comp zr600 amp? i was told that it was a 1000 watt amp. i just want to make sure that it is a 1000 watt amp and not a 600 watt amp. i am powering two 15'' kicker comp subs...
  • Amplifier Type: Dual Channel
  • Bridgable: Bridgable
  • RMS Power at 4 Ohms: 150 W x 2
  • RMS Power at 2 Ohms: 300 W x 2
heres a link to a stats page for the zr600>
http://www4.shopping.com/xPO-Kicker-ZR600#keyFeaturesArea
Feb 05, 2010 | Kicker ZR600 Car Audio Amplifier
WHATS THE WATTS ON THIS AMP
Feb 04, 2010 | Kicker ZR600 Car Audio Amplifier
I got a 4 gauge power wire w a 20 amp fuse hooked up to a kenwood stereo/bridgeable amp 350 watts max power model #kac~6295 it just dnt sound rite any sugestions?
make sure you run your power and ground wires opposite of the rca/speaker wires. you tend to pick up alternator noise when all wires are bunched up together. Also, make sure you have a good chasis ground to the amp, and the stereo has also a good ground. good luck
Sep 04, 2009 | Car Audio & Video
I have aused 1500 watt inverter no cables. what size cables do i used and what size fuse do i need at the battery?
i would not go with less than a 4 gauge cable for the + and - . atleast run a 50 amp as if you were running a big stereo system. but, you might want to consider a circuit breaker.
Sep 22, 2008 | Chevrolet C3500 Cars & Trucks
Subwoofers
This will depend on the amplifiers capabilities.
I will give 2 different scenarios.
#1 Stereo configuration
If the amplifier supports an RMS power output close to the RMS input power of the subwoofers then run the amplifier in stereo mode. For example 150 watts RMS X 4 channels driven at 20-20khz. (If you can provide a model # for the subs and the amp your looking at I can help you further with this decision.
Wiring for this is easy and simply involves matching the connectors for 2 of the channels (Front or Rear) to each of the subwoofers.
#2 Mono Bridged mode.
If the amplifier is lower power but mono bridgable you can bridge two Pairs of channels and power each of the subwoofers this way.
Generally speaking a 2 channel bridgable amplifier will be able to at least combine the wattage of each channel into a single monural channel and in many cases its actually higher.
So you would bridge the front 2 channels into a single bridged mode for one subwoofer. and then you could bridge the read 2 channels into another bridged mono channel for your other sub woofer.
For example if you had bridgable amplifier thats 50 watts RMS X 4 you coudl very likely (Generalization based on quality of amplifier) send 150 watts RMS to each subwoofer.
Again I would need to know what amp you're refering to to provide specific wiring instructions. Many Bridging amplifiers either have a single switch that will send them to bridged mode or you would use the positive + terminal from one channel and the negative - terminal from the other channel or a combination of both.
Sep 17, 2008 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Kenwood KAC-629S Car Audio Amplifier Logo
388 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
