Question about Necchi 3101 Mechanical Sewing Machine
Problem in Motor as well as Mechanical Cam System
I have this Nechhi Mechanical Sewing Machine for the last many years. The Motor got burnt and the Mechanical Cam System has completely stopped working. We cannot make any designs due to this. Kindly let us know what to do. In case I can get both parts New, kindly let me know the price as well as freight charges for Chandigarh/India.
Thanks.
(s.s. grover)
email address: grover_sjs@yahoo.co.in
    Problem Solver:
  • 15 Answers
  • 1 more comment
  • norman medalle
    norman medalle Dec 10, 2007
  • norman medalle
    open embed video above from youtube , you will have all the advantages when you get myrepairmaster, it's better than doing yourself repair, it saves a lot of time and money. trust me i have one.
  • norman medalle
    but if you want fast production unit , hustle free, very easy to use, convenient and very enjoyable working...... TRY TO OPEN LINK DONGGUAN above
Is a sewing machine vintage at 20 years or at 40 years old
That is probably a personal definition. To me, a vintage machine would be one that is more mechanical than computerized. .Some (below) seem to think it would be a heavy metal mechanical machine. But, to throw a monkey wrench into the discussion, what differentiates vintage from antique?
8 Great Reasons to Own Vintage Sewing Machine
Tips for Buying Vintage Sewing Machine
Best 25 Vintage sewing machines ideas on Pinterest Vintage sewing Antique...
Mar 03, 2018 | Sewing Machines
Will not zigzag or decorative stitches. New to these newer plastic style machines Always used older steel machines. This was given to me my by my sister who used it very little. Could cam be broken?
Hmm, I'm wondering if it has been cleaned and oiled recently. Older mechanicals require frequent TLC. Consult your owner's manual for cleaning and maintenance instructions:
Is your sewing machine mechanical (ie, not computerized)??? CAUTION--if your machine is computerized, do NOT proceed with the following suggestions.
If it is mechanical, have you cleaned and oiled your machine recently? Most mechanical sewing machine failures are because they have not been adequately and routinely oiled, the old oil has solidified and frozen the mechanics. I recommend Bernina oil or liquid Tri-Flow Synthetic Lube (or similar good quality sewing machine oil) for mechanical machines--do NOT use 3-in-1, cooking oil, WD-40, or the sewing machine oil from your grandmother's sewing basket. (I am not associated with any Bernina dealer.)
If it is in fact frozen, pick up a bottle of liquid Tri-Flow Synthetic Oil at the hardware store. Oil one or two drops in every oil hole (see your manual) and also every place where metal rubs on metal. But DO NOT oil any plastic gears, rubber, or belts. If it is still stiff or frozen, direct a hot handheld hair dryer into the top and bottom mechanism of your machine. See if that loosens it up. You may have to repeat.
Once your machine is working again, place a drop or two of good sewing machine oil as directed above. Be sure to use a small brush to clean the lint and dirt out of your machine, especially around the feed dogs and bobbin area. (Caution: Compressed air will sometimes force the dirt and lint into areas that cannot be cleaned.) And continue to use good quality sewing machine oil to keep it running. Recommendation: every time you change a bobbin, after 8 hours of sewing, or every six months if it is not in regular use.
Dec 30, 2015 | Singer 6038 Mechanical Sewing Machine
I used a single cam in my Elna Carina and I can't remove it. help!
ELNA Carina Instruction Manual
Perhaps the spindle where the cam sets needs a drop of good quality sewing machine oil, like Tri-Flow Synthetic Lube. Be sure the stitch length & width are set to Zero.
Elna Carina Electronic SU Duplex Review
How to remove can from an elna Carina Its stuck and can remove it My...
Dec 19, 2017 | Elna 2007 Mechanical Sewing Machine
The machine needle broke and I'm not sure what needle I need for my Brother LS-2220 sewing machine
Wow, talk about rambling solutions to a simple question ...
Brooklyn35, go to a place that sells sewing machine needles and buy some, period, end of story. All home sewing machines for the last 50 years (not sergers) take the same needles, the best quality needles are Schmetz brand, they are stronger, sew better, and last longer than cheap ones.
Oct 31, 2010 | Brother LS-2220 Mechanical Sewing Machine
Baby Lock bl 5280ED runs and gets slower and slower. Replaced motor and foot control and oiled throughly. The problem persists. I can see no visible cause for the motor laboring after running less than...
The problem is likely the stitch length adjustment cam. You will need to remove the cam. The cam is located on the left side of the machine (there is a screw under the plastic arrow cap) also remove the cam sleeve (looks like a steel bubble wand) resurface the sleeve until the cam turns freely, oil with sewing machine oil (NOT WD40!) or lithium grease. reassemble machine and adjust timing.
Jul 03, 2010 | Sewing Machines
Power is going into the machine light working but no power to moter not working. Was a smell of burning rubber Machine still working when I stopped sewing
May be one of three things:
A) foot pedal may have burnt out (this is common-is this perhaps where the smell was coming from?)
B)The belt inside the machine may have worn out
C)You may have actually worn out he motor, depending on how long you have had the machine.
Suggestion for all three-take it to your reputable sewing machine repair person. It will likely cost about $100. I take my machine in every 6 months for a 'tune'up', and it has proven to be a wise move, since I use my overlock frequently.
Mar 16, 2010 | Janome MyLock 634D Mechanical Sewing...
My Nechhi Royal Series Sewing Machine Has stopped working
Make sure the stop motion wheel is tight, make sure you do not have any thread stuck in the raceway area if you get a buzzing sound from the motor
Feb 17, 2010 | Sewing Machines
Need manual for nechhi sewing maching #4575 code150t
http://userguides.50webs.com/
They carry manuals for almost every sewing machine ever made.
If they don't have it, they usually will tell you where you could get it.
Jun 15, 2009 | Necchi 4575 Mechanical Sewing Machine
Elna machanical sewing machine
50 year old elnas made stitches by cams. look to see if the machine has a cam in it. you can see this by opening lid on top of machine. cams are black with red or white showing the pattern of the cam. could also have broken cam stack gear. That would require technician with elna experience
Jul 05, 2008 | Elna 2007 Mechanical Sewing Machine
Necchi 3101 Mechanical Sewing Machine Logo
129 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
