Question about Necvox Car Audio & Video
I have just bought a car with an overhead tv i dont know how to get power to it
    Scholar:
  • 66 Answers
    Headrest TV
  1. Step 1 Disconnect the headrest from the car seat and remove its upholstery. Trace the outline of the TV's mounting frame onto the foam cushioning with a permanent marker.
  2. Step 2 Cut a hole into the foam using a razor knife for the frame to fit into. Using the frame as a guide, whittle into the hole until it is deep enough for the frame to fit into. Glue the frame into the hole with contact cement and poke another hole into the foam with a screwdriver where the frame's cable hole is.
  3. Step 3 Place the headrest's upholstery cover back on and cut the fabric away where it is over the frame.
  4. Step 4 Place the TV into the frame once the contact cement is dry and hard and run its cable through the other hole. Connect the TV to its tuner console with audio/video cables and store the tuner under the seat.
  5. Step 5 Connect the TV's power adapter cable and route it so it can plug into a cigarette lighter adapter. If it doesn't use one of these, it will have a three-way cable where one connects to the car starter, another to a constant 12-volt source and the last one to a good ground. Disconnect the negative battery cable before connecting any wires
  6. Overhead TV
  7. Step 1 Make sure there is a metal sheet installed in the ceiling below the headboard. This is needed to mount the overhead player onto.
  8. Step 2 Pull away the upholstery on the ceiling. This might require a solvent that will remove the upholstery's adhesive. Insert a plywood or metal sheet between the headboard and upholstery and glue it to the upholstery.
  9. Step 3 Mount the TV set to the ceiling, making sure the screws for the TV's mount are securely screwed into the sheet within the ceiling.
  10. Step 4 Route the wires to the engine compartment if the TV doesn't use an adapter plug for the cigarette lighter. With the negative battery cable unplugged, connect the TV's red wire to the starter's electrical connector, the yellow to the battery or other 12-volt source and the black to a metal ground like on the chassis.
  11. Dash TV
  12. Step 1 Unplug both battery cables from the car's battery, starting with the negative terminal.
  13. Step 2 Remove the stereo from the car. Pry away and remove any trim panels on the dash, then unscrew the mounting screws on the stereo and disconnect the electrical connectors. Some stereo units have an anti-theft mounting system requiring special tools that fit into holes on the stereo front to release its mounting clips.
  14. Step 3 Place the TV within an installation kit designed for your model cari have just bought a car with an overhead tv i - mag-glass_10x10.gif. Connect the antenna's cable to the TV and mount the antenna on the outside of the car; the trunk or the roof near the door frame are two possible locations. Route the cable along the weatherstripping or secure it to the side with cable ties.
  15. Step 4 Connect the TV to its tuner box with RCA video (composite) cables and store the tuner somewhere secure, like the glove box. Wire the TV to the radio antenna and stereo connectors with a wiring harness designed for your car, which can be purchased at a car audio supply store.
  16. Step 5 Mount the TV into the stereo's old spot within the dash, fasten all the mounting screws and replace the trim panels. Reconnect the battery cables once the set is mounted, starting with the positive terminal.
i hope this will help.you can send a message if you not satisfied
Posted on Sep 10, 2009
I have a R50 W46 and I power off and it will power on by its self and I hear voice for a Quick second. I think its in my power supply. Im looking for a new power supply do you know where I can get one. The...
Remove back on bottom of chassis on left hand SIDE THAT SHOULD BE THE Deflection Board it has FBT flyback Transfomer
Check CP150 2200uf 16v use 25v capacitor ,If this capacitor is swollen,vented or puffed up on Top it is Bad replace it and CP114 CP120 they are either 220uf 35v or 330uf 35v .
UED should have Parts for this Model 1-800-648-6657
Encompass Parts Distribution 1-800-638-3328
Zenith Parts/Moduels 1-800-632-6637
This may not be the chassis am thinking it is so all of the companys I have Listed should help you.
Sep 27, 2010 | Zenith R50W46 50" Rear Projection...
Jus bought a belson bs17500 it worked fine in the other oersons car hooked it up in mine and won't power up all the wiereing is correct and I noticed a blown fuse under my hood so I replaced still no luck...
I have a car dvd belson bs 3001 but without remote control, I would like to buy a remote control for my unit, please help me to find one, Thank you very much
Mannani
Jun 10, 2010 | MT&V Mobile TV MTV-AD7 7" TFT LCD Overhead...
Overhead DVD Player
http://www.poweracoustik.com/pa2006/manual%20and%20catalog/MD-1000CM.pdf
Jul 02, 2009 | Power Acoustik PMD100CM Car DVD Player
CAnt get front interior overhead lights in cabin to come on.
Check the dashboard dimmer dial next to the headlight switch. Sometimes if it's dialed all the way down, you'll have no interior lights. Try turning the dial up to just before the detent if you want them to go out when the doors are closed. If you want them on all the time, push it past the detent on the dimmer. Let me know if that works..
KEn
May 07, 2009 | Ford F-450 Cars & Trucks
Changing Spark Plugs
2.0L SOHC (single overhead cam) AGSF34EE plugs gap 0.054
2.0L DOHC (dual overhead cam) AZFS32FE plugs gap 0.050
The plug numbers are the motordraft numbers
Apr 02, 2009 | 2001 Ford Focus
Audiovox DVD overhead Monitor
the power supply amperes might be too low try using car batt as your power source
Nov 09, 2008 | Audiovox VOH8512 Overhead LCD Monitor Car...
Child lock
I also have a km0544 tv and the child lock is on however I lost the reote control for it some time ago when re-locating house. Do you have suggestions?.- Steve
Oct 18, 2008 | JC Whitney - Audiosonic 3-way Custom-fit...
Sony mv-900sds overhead dvd
probably you will need to disamble it and remove check button. But the way I need instructions to connect it, I dont have wiring harness to connect it , can you help me with this?
regards
carlos.
May 01, 2007 | Sony MV-900SDS Overhead DVD/ 9" LCD Car...
Car Audio & Video Logo
410 people viewed this question
Top Necvox Car Audio & Video Experts
xxxxxx xxx
Are you a Necvox Car Audio and Video Expert? Answer questions, earn points and help others
