Question about HP LaserJet 1100 Printer
A white ribbon cable was found lying inside of an HP 1120PS printer. Where does this ribbon cable plug into?
4 Suggested Answers
  • 7 Answers
SOURCE: HP DESKJET 5550 white ribbon cable.
it is easy to reconnect the cable just slot it in
cos
Posted on Jun 21, 2008
  • 1705 Answers
SOURCE: How do you replace the ribbon cable in a HP
The best place to try would be the HP website, follow links to "Contact us" and have a word with their technical staff.
Posted on Apr 09, 2010
  • 73 Answers
SOURCE: I have a 7280 HP
Hi There,
Please follow the below link :
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=en&cc=us&product=3204785#N850
Hope this solution resolves your issue...
Thanks
Enjoy and Cheers !!!!
Please vote for me if this solution fixes your issue ...... : )
Posted on Nov 02, 2010
I put 2 new printer cartridges in and got the effor Oxc18a0101. What should I do? My printer is an HP Photosmart D7160. I've looked at some solutions on line, but they refer to typing numbers,...
Hi Karen, This likely is either due to Bad/Expired Printhead or it could be defective printer ( hardware failure ). However you can give it a try. Follow the steps below and it should solve the problem, else we need to consider it could be defective Printhead or printer hardware failure.
The Photosmart D7160 does not has "*" and "#" because it is not a fax capable printer.
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
The error message 0xc18a0001 "Ink System has Failed" is now gone
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
May 17, 2011 | HP Photosmart D7160 InkJet Printer
I have a HP photosmart 3310. I'm getting the error:Oxc18a0101 message. I've tried a couple of suggested solutions ut neither has worked. Help!
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone
Try this and it works
Regards,
Ron
Mar 26, 2011 | HP Photosmart 3310 Printer
My prenter is showing ink system failure
Mar 03, 2011 | HP Office Equipment & Supplies
PHOTOSMART D7360 - INK SYSTEM FAILURE
8- the error message 0xc18a0001 "Ink System has Failed" is now gone.
Regards,
FixYa
*Please rate this solution with Thumbs Up
Nov 27, 2010 | HP Office Equipment & Supplies
The plastic strap inside my hp printer 3325 is being cut and removed...can it be replaced?
What does this strap do?
Are you certain it is NOT a ribbon cable that has come dis-attached?
If it is a ribbon cable, plug it back in. It can only go one way - slide it in gently - DONT PRESS SO HARD YOU BEND IT.
Thanks for using fixya.com
a
Oct 24, 2009 | HP DeskJet 3325 InkJet Printer
My HP Photosmart 3210 won't print
Try this:
4- Plug in power source and turn printer on. Wait till you get a error message and push "OK".
Oct 07, 2009 | HP Photosmart 3210 Printer
Printer will not print hp error messsage oxc19a0024 removed all cartridges pupluged as recommended
OKSolution 1:
  1. Turn off power and unplug from power source.
  2. Open right side of printer.
  3. Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
  4. Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
  5. Unplug power source.
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
  7. Plug in power source and turn printer on.
Solution 2:
  2. Open right side of printer (looking at the front).
  3. Disconect,by pulling gently, the flat ribbon cable off the main circuit board that is the smaller of the two.
  4. Plug in power source and turn printer on. Wait till you hear no more movement from inside from unit booting up.
  5. Press both cancel and power button at the same time.
  6. Message on printer screen will be, "Enter Special Key Combo".
  7. Push keys; Left-Ok-Right.
  8. When printer screen changes, scan through and look for "System Menu" and push "Ok"
  9. Scan agan and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan agan and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  11. Press "Cancel" 4 times
  12. Turn off power and unplug from power source. Wait for 2 minutes.
  13. Reconect the flat ribbon cable by aligning and carefully pushing into the conector on the main circuit board.
  14. Plug in power source,and turn on power.
  15. When printer boots up, answer the questions on the printer screen for your area.
  16. The printer will cycle the ink from the cartridges to the print head and back.
Pineworks
Oct 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error0xc19a0024 on a hp 6180 will not print
Follow the below 2 solutions :-
I
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the connectors on the main circuit board.
II
  9. Scan again and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan again and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  13. Reconnect the flat ribbon cable by aligning and carefully pushing into the connector on the main circuit board.
If problem persists, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 07, 2009 | HP Office Equipment & Supplies
Printing error oxc18a0101
Try resetting the printer:
7- Plug in power source and turn printer on.
Jul 19, 2009 | HP Photosmart C7180 All-In-One InkJet...
HP C5180 error messsage Oxc19a0024 will not print. what to do.
Ok this is a old postint but you may come back to see it or it may be handy for some one elles.
Solution 1:
Solution 2:
  17. All the best: Pineworks
Jun 18, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP LaserJet 1100 Printer Logo
Seeker5211
Seeker5211
