Question about HP Photosmart C5380 All-In-One Laser Printer
Cant find scanner - HP Photosmart C5380 All-In-One Laser Printer
  • gerand177 May 11, 2010
    Here is some great PRINTER solution by Some FIXYA EXPERT.
    Get any kinds of PRINTER solution from bellow.
    » Brother Printer Solution
    » Canon Printer Solution
    » Epson Printer Solution
    » HP Printer Solution
    » Lexmark Printer Solution
    » Xerox Printer Solution
    » Other Printer Solution
Cant get it to do anything cant tell what what buttons to push i need a book on this scanner bc92xlt handheld scanner
You can download and print your scanner manual, at no cost, here:
http://www.uniden.com/pdf/BC92XLTom.pdf
Bill B.
Listening in since the 60's
Apr 23, 2011 | Uniden BC92XLT Handheld Scanner
My computer (Toshiba Laptop) cant see connected scanner umax Astra 1220S. Pots are ok whith other connections.What could be the fault ?
Like me, so, you would need to go to the Adaptec.com website and find your computer or scanner and download for "Free", the latest SCSI Card driver, in order for you computer to recognise that you have a SCSI Card in your machine. Once you restart your machine, you will find that your scanner, should work perfectly.
Barbara Grey
Dec 27, 2009 | Umax Astra 1220S Flatbed Scanner
Please, how do I install my flatbed mercury scanner 1200cu+. I cant find my installations disk
I found an Windows XP driver here: http://www.mercury-pc.com/download_file.php?option=file&item_id=2870. The documentation for the Mercury KOB 1200cu+ scanner indicates support for Win 98se/Me/2000/XP. On a newer Windows OS, it may not work but you can try and see if a generic scanner driver installs when you plug it into the computer. If it is recognized, scan using Windows Fax and Scan (File, Import from Scanner) or Paint (Import from Camera or Scanner).
I hope this helps.
Dec 16, 2009 | Mustek Be@rPaw 1200CU+ Flatbed Scanner
Cant get scanner to work
follow the link and it will show how to use the scanner.
http://support.lexmark.com/perl/support/support.cgi
Mark
Apr 29, 2009 | Lexmark X2600 InkJet Printer
Cant get weather on hand held scanner
The 92 does not have a separate/dedicated weather band feature, but you can program individual NOAA frequencies into it. Weather broadcast frequencies are: 162.400 MHz : 162.425 MHz : 162.450 MHz : 162.475 MHz : 162.500 MHz : 162.525 MHz : 162.550 MHz.
Apr 10, 2009 | Uniden Nascar BC-92T Scanner
L/O is on all channels cant program with L/O on it
push manual then hold down lock 0ut button for several seconds this should unlock all
Feb 14, 2009 | Uniden BC60XLT Handheld Scanner
How do I Program my Uniden Bearcat BC60XLT
i am having trouble programing frequencies into my scanner i need help!!!!!!!!!!!!!!!!!!!
Aug 09, 2008 | Uniden BC60XLT-1 Handheld Scanner
Cant find reset button inside scanner
There is a lock/light key at bottom left hand corner of buttons hold that down until it beeps and the buttons should be unlocked
Jul 27, 2008 | Radio Shack Pro-82 Scanner
HP Photosmart C5380 All-In-One Laser Printer Logo
61 people viewed this question
Seeker5211
Seeker5211
