Prints gibberish when i try to print, instead of printing what i send the printer prints out pages of what looks to be computer code?
    President:
  • 1,653 Answers
Power off and on the printer. Make sure that you are sending the job to the correct printer as setup on your PC. This sounds as though you are printing to a default printer set on your PC and have a different printer type physically connected. Make sure that you have the correct printer driver installed and then set this as the default printer. Then all should be OK. If you have what you think is the correct printer installed and physically connected to the PC then uninstall it from the system Printers and reinstall it to the system Printers. Also make sure that the driver is the latest available from the manufacturers website support / download drivers section and is the right one for your operating system.
Posted on Sep 10, 2009
  • 19,396 Answers
First test a different USB cable. A faulty data cable can cause the problem.
Once you are sure the cable is OK, reinstall printer software. A corrupted or wrong printer driver software is common cause for this kind of problem.
You can reinstall software using printer disk, or download from manufacturer website.
Start software setup with printer USB not connected.
Testimonial: "thanks, problem sloved..."
How to stop printing
While your question is not quite clear, I will provide a couple of suggestions. Usually when you press the cancel button, it pauses the printer and then you must use the arrow keys to select cancel job and then press the checkmark. Also check any computers to make sure that they do not have a job in their print queue. If the printer does not send back a job complete command, sometimes the computer will keep resending the job. Failing all else, restart your computer and your printer. Are the pages that are printing gibberish or is it the correct print job? If gibberish, you might have a corrupted print driver or the file you are printing might be corrupted.
Jul 15, 2014 | HP LaserJet P4014n Printer
The printer prints a blank page with a line of gibberish in the upper left corner before it prints the real page.
Can you send me a "print to file" of the failing document.
At first blush it can be either of two things.
1) The preceding print job did not properly clean out the printer's memory.
2) The new print job, has data or a busted escape command in it that is being treated as printable data.
Send the print file to don.farr@hotmail.com and I'll read through the document header to see what's going on.
Don
Mar 02, 2010 | Dell 1720dn Laser Printer
My mom's hp officejet T45 printer now prints gibberish. It started after my sister installed a new ink cartridge for her. Because her documents were printing nothing but a solid black line then, my...
Gibberish sounds to me that ether one of two things is going on.
1. the printer was never allighned when the new cartridges where put in.
2. Depending on the gibberish its printing it could be a communication error with the driver on the computer.
Do not pitch the printer but get help for it like you are doing now! But I would have taken a chat from us to see what the gibberish is!
Dec 18, 2009 | Cameras
It prints gibberish before the print job.
I have had this happen before, this could be you need to change the drum kit on the printer itself, check the indicator light.
Jul 28, 2009 | Dell 1720dn Laser Printer
Prints gibberish when a multi-page color document is printed
This could be a driver issue. Without knowing exactly how your printer is connected to the network I'm making a rough guess here.
There is a Universal HP Printer driver that could be tried as well as the PCL5, PCL6 and Post Script drivers.
I've had issues with the PCL6 drivers before doing this and I usually install the PCL5 drivers instead.
Jun 21, 2009 | HP 4700N Color Q7492AABA Laser Printer
When printing from word 2007 on vista bold type is gibberish
Try re-installing the printer driver(s) first. If no luck, then un-install the printer completely, reinstall and try again. You may also have an issue with an incompatible driver with Office 2007. After reinstalling the drivers, try to print a test page and see what happens.
Apr 17, 2009 | Brother MFC3240 Multifunction InkJet...
Prints pages with no words but symbols
Print test page from the printer. This prints fine? Then anytime a printer prints gibberish versus what you were trying to print from the computer means you should try one of two things. Download the most recent drivers from the products support site, install these. Be sure to uninstall the old drivers first. Another item that can cause gibberish print is a bad cable. Swapping out with a known good could solve the whole problem.
Print test page from the printer. This does not print fine? Then you are looking at something wrong with the printer. The cable and drivers would not be the cause because the only piece of equipment involved at this point is the printer. First step I would try in solving this. Download and update the firmware from the support site. If this does not work, then you may have a defunct printer. If you are under warranty, contact Dell tech support.
Mar 12, 2009 | Dell 1600n All-In-One Laser Printer
Printing gibberish then feeding several lines, printing gibberish
If text did not line up as planned, your TOF ( top of forms adjustment ) isn't correct. Just correct it using the button on the panel. If after printing 1 page or so and then it begins to go out of place, most probably you hv set the page lenght incorrectly. To correct, enter the MENU on the panel and set the correct page length.
Lastly if printing garbage, most probably you have selected the wrong emulation on the MENU. Correct by entering MENU mode ( press ' SHIFT+MENU ' button together ) and select the correct emulation.
Hope this helps.
KM HOO
Mar 04, 2009 | OKI MICROLINE 590 Matrix Printer
Why is my HP Photosmart C6180 printing gibberish?
Yeah you need to buy a software for your HP that is apple compatible. The CD you installed is specifically defaulted for windows. It will install the software for you but because its coded differently, neither one of them will understand one another. Its like giving a blind person a book with no brile in it. He can pick it up and change the pages ok but he wont be able to read it. I think you can download the software for HP's website or google it.
Dec 09, 2008 | HP Photosmart C6180 All-In-One InkJet...
971 people viewed this question
k24674
jasbo
jasbo
