Question about Onkyo TX-SV373 Receiver
When I push the stand-by/on button - stand-by blinking
When I push the stand-by/on button the screen shows "multi channel input" for a second and the equipment goes to stand-by with stand-by light blinking.
WHEN I PUSH THE STAND BY BUTTON THE UNIT GETS ON AND IMMEDEYETLY GETS OFF(YAMAHA RXV-995 IF IUSE 500VA STABULISER THAT PROBLEM NOT COMING PLEASE SOLVE IT
Posted on Sep 10, 2009
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
How do I access the AV1/2 channels to view my DVD player''s signal?
Normally there is an INPUT button on the remote control or on the front of the TV itself.
Just push that until it shows VIDEO 1 or something to that effect on the TV screen.
Power up your DVD player and make sure it is hooked up to the correct input connectors on your TV and then play a disk in it.
You should see the video displayed on the screen, and if not just push the INPUT selector button repeatedly until you get to the correct input mode for your DVD player.
Good luck.
Apr 21, 2011 | Televison & Video
Wii help
Hello :
1:Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console.
2:
Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
Yellow = Video Input
White = Audio Input Left (or Mono)
Red = Audio Input Right
3:Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
I hope this will help .
Mar 23, 2010 | Nintendo Wii Console
TV turns on with sound but blank black screen
This solution from troylove solved my problem. troylove11
Rank:wizard_s.gif Wiz
Rating: 85%, 1164 votes
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Jan 07, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi ws-55515 light blinking
Sounds like the remote is not programed correctly or the input sources have been changed.
Call the cable company and complain that it worked before they came and shoud work afterwards.
Mar 24, 2008 | Mitsubishi WS-55515 55" Rear Projection...
Mitsubishi tv
I found this online somewhere and it cleared my problem.
(my problem was a blue screen that said my input was locked enter in your code using the 10 key pad. Both inputs were locked, I used the steps below and it cleared it. We are now watching a dvd for the first time in months!) Thank you Bob Waterman whoever you are!)
MITSUBISHI CS3114R
Parental Lock
This system can lock each channel or different channels on ANT A and ANT B
as well as locking each of the EXT inputs, so you should confirm what is
locked before trying to unlock.
1 On the remote, set the TV/VCR switch to the TV position
Or . Depending on which remote is being used
Press the TV mode button at the top.
2. Turn on the TV and using the SCAN buttons (or 10 KEY FAD) and the INPUT
buttons check each channel and input to establish which channels and inputs
are locked. The screen will tell you if the channel or input is locked.
3. Press the button labeled MENU. The screen will show the main TV menu.
4. Press the #5 button (channel lock option).
The screen will change to show the channel lock System Menu. This screen
will indicate that the lock system is either ON or OFF.
IF THE SCREEN INDICATES LOCK IS ON, GO TO STEP 5
OR:
IF THE SCREEN INDICATES THE LOCK IS OFF, GO TO STEP 5A
5. Press the #3 button. (SELECT CHANNELS TO LOCK option). The screen will
ask for the code number. Press the #9 and QV buttons at the same time.
Notes: The screen will change to show an information display that will show
the selected antenna and channel or input. The display is superimposed over
the picture. This display will indicate that the channel or input is either
locked or unlocked. In the lower middle will be instructions to use the
10-key pad or SCAN buttons to select the desired channels (or the INPUT
button to change antennas or select the EXT inputs). At the bottom of the
screen will be instructions on how to change the current LOCK status (if
unlocked use the ENTER button to lock, or if locked use the CANCEL button to
unlock).
NOW GO TO STEP #6.
5a. Press the #1 button (channel lock ON option). The screen will ask for a
code number. Use the 10-KEY PAD to enter a new code number (We suggest 1111)
and then press the ENTER button.
unlock).
NOW GO TO STEP #6.
6. Use the 10 KEY PAD or SCAN buttons to select the channels that are
locked, or, use the INPUT button to select the external inputs that are
locked.
7. At each locked channel or input press the CANCEL button.
The screen will indicate that the channel or input is either locked or
unlocked.
8. When all of the channels and/or inputs are unlocked, press the MENU
button again. TV main menu will be displayed.
9. Press the #5 button (CHANNEL LOCK option).
10. Press the #2 button (channel lock OFF option). The screen will now ask
for a code number again.
11. Press the #9 and QV buttons at the same time. The screen will return
to the CHANNEL LOCK MENU and indicate that the lock is OFF
12. Press the MENU button twice to return to normal viewing.
The parental lock is now entirely cancelled.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxxxxxxx
geminitv@xxxxxxx
www.geminicomputertvsecurityalarms.com
Nov 18, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Tv want show
Look at the back of your TV.  Make sure your cable is hooked up to connector on far right, NOT the far left. (For analog cable TV.)
Push "source" button on remote or side of TV to cycle through TV inputs.  Wait one second between pushes.  You want to stop just before the source that displays "AV" on TV screen.  It should show a number, for the current channel number.
If you are using an analog cable box, try setting the TV channel to 3 or 4.  If you use no cable box, try changing channels on TV to find an active one.  If no luck, make sure your cable service is active (subscription active).  Cable companies disconnect it between residents of an apartment/house.
Oct 19, 2007 | Akai LCT3285TA 32 in. LCD Television
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
AUX inputs
Turn the ignition key to on or accessory position, turn the stereo off, then hold the function key for a couple seconds, the stereo will turn on and you scroll through the menu with the left and right arrow buttons and change settings with the up and down buttons
Feb 25, 2007 | Pioneer DEH-P6800MP CD Player
Onkyo TX-SV373 Receiver Logo
373 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
