Question about Honeywell Air Purifiers
Test - Honeywell Air Purifiers
  • 55 Answers
Test worked
Posted on Sep 13, 2009
Does not produce ozone, I have replaced the fuse, it has been cleaned and the amber light is not on.
it's possible that the ozone generator inside has gone bad. The only way to really know is to remove it from the unit and then test it with a power supply w/correct voltage of coarse. You will smell the ozone immediately if it works upon testing. (clean fresh smell) If it does need replaced, it's an easy fix for anyone with electronics knowledge. You will need to match up the numbers to get the correct replacement. Many are available on Ebay. Always disconnect the power to the unit before taking it apart. Hope this helps, Dave
Nov 18, 2013 | Ecoquest Living Air Classic Air Purifier
Furnace stop working after cleaning the electronic air cleaner F50
Try this educational video: https://www.youtube.com/watch?v=erpnfKbqmoM It could be something as simple as a pressure switch.
I hope I helped you out!
Apr 01, 2017 | Honeywell (F50F1032) Air Purifier
Does not turn on
Fuses often fail without appearing to be bad. Test the continuity of the fuse by using an ohmeter.
If, after testing your fuse, you continue to have a problem, let us know and we will dig deeper.
I hope you find this to be very helpful as a jumping off point, moving forward.
Please leave a rating. :-)
May 14, 2010 | Ecoquest Fresh Air Air Purifier
How do i test that healthway filter is able to reduce bacteira and germ cioncentration in an HIV /AIDS FREE DRUGS CLINIC OF ABOUT 300 PEOPLE COUGHING
Strictly speaking, you would need to run culture tests in a sealed laboratory to conduct such a test. There is actually no way for the layman to verify that microorganisms are being killed by this device. Either you believe the company's claims, or you don't.
Apr 14, 2010 | Healthway EMF 20600-2 Air Purifier
Honeywell F50A does not clean well
sounds like it is working. You could replace the cells and prefilters with a disposable box filter that fits.
Sep 23, 2009 | Honeywell (F50F1073) Air Purifier
Fan motor changes speeds on its own.
The control component or the control circuit for the fan can be causing the speed variation, or the bearings on the thing can be wearing (or contaminated) with the same result. If you can make a test bench, look (feel with a test pad, really) for drive transistors that get hotter than they should or an inconstant power resistor or shunt.
Apr 04, 2008 | Alpine Air XL-15 Air Purifier
No power.
Check power outlet /test w/ multi tester the continuitybefore and after the switch , one line hook tester and other before the switch ,having continuity mean motor good.One line hook to plug test after the swirtch, let swtich on and off , the rester does not move the switch has the problem replace it.
Dec 27, 2007 | Sharper Image Ionic Breeze 3.0 Air...
Honeywell F300E not cleaning air.
A newly installed system should still be under the contractor's labor warranty. Call them and ask them to come out to check on the unit and explain what you wrote above. This should cost you nothing and is the best way to get to the bottom of the problem.
Nov 09, 2007 | Honeywell Enviracaire Elite F300E-1019 Air...
Air Purifiers Logo
106 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
