Question about Hitt HE-MP883G (1.5 GB) 2 GB Digital Media Player
After Firmware Upgrade, my device does not power on. Help Please.
I upgraded the firmware of my PMP with one of which i got from the cd it came with, everything was successful. After restarting the device it hasnt came back on since. HELP PLEASE
  • Anonymous May 02, 2008
    this updating is from which year ??
Someone let will place in the internet (rapshide..) and the thin line some of the new updating will pass
Posted on May 02, 2008
I have tried downloading from the samsung website lastest firmware update, which is an iso file when extracted it saves it to disc as a xuf file and the blu ray wont read this what am i doing wrong??
Read the Upgrade Guide (PDF) for instructions on how to do this. It says to burn a CD. The ZIP file extracts to ISO type. The guide tells you what format it needs.
READ the PDF file under Upgrade Guide. Make sure you designate the proper file type when burning CD. Check your burning software.
How to make a firmware update CD
Please follow the below procedures.
1 Download the new firmware file from
2 If the firmware file is compressed (*.zip), the file should be uncompressed to CD image file
3 Please burn the CD image file on a blank CD-R/RW disc
1) Recommended CD Burning Program is Nero Burning ROM.
2) Burning Options (in case of using Nero Burning ROM)
A. ‘Recorder’ menu ?? ‘Burn Image…’ ?? Select an uncompressed image file(*.iso)
B. Please check ‘Finalize CD (No further writhing possible!)’
C. Please refer to your own CD burning Program Manual if you want to use any other
CD burning program for burning ISO image file.
D. Make sure if the downloaded software is eligible for your BD-P1400.
E. The System Upgrade will not be executed if using the update CD made with NOT
following the upper procedures.
The following events may interrupt the upgrade process and MAY RESULT IN PERMANENT
1. Unplugging the power plug
2. Power outage
3. Dirt or scratches on the burned CD-R/RW disc
4. Closing or opening a disc tray during update processing
How to upgrade the BD-P1400
1. Press OPEN/CLOSE button to open the disc tray.
2. Insert the upgrade CD.
3. Press OPEN/CLOSE button to close the disc tray.
4. Please wait about 6 minutes while verifying.
Verifying Firmware Version.
5. When below message box comes up, please check the date of the Firmware version.
Do you want to update Firmware?
>Current Version : 070730.02_XAA
>New Version : 070903.01_XAA
Yes No
6. Press ‘Enter’ button to choose ‘Yes’ for upgrade and please remove the disc on the tray.
If you select ‘No’, BD-P1400 will be automatically powered off.
If you don’t see above message box, try another disc. Generally, this is caused by disc
quality or a disc creation problem.
7. Please wait for about 7 minutes.
Firmware Update.
Now, Processing…
Please, do not turn off the power.
8. When finished, the screen and the power will turn off automatically.
9. Turn on the unit again. The tray will close automatically. Below screen will show up. Please
select the language you want with a corresponding number button.
Press 1 for English
Pulsar 2 para Español
Touche 3 pour Français
Macrovision : BSS01
10. If you want to do System Upgrade through the network, please refer to ‘System Upgrade’
Article on the User’s Manual.
Aug 18, 2010 | Samsung BD-P1400 Blu-Ray Player
Have an iriver H10 - i turn it on and i get this message. " System files missing. To restore the system files, connect H10 to iriver plus" I did this and nothing worked? Can u help?
upgrade the firmware of your device follow this... How to upgrade firmware
1. Download the zipped file for your region.
2. Unzip the file and you will see *.exe file.
3. Connect your H10 to PC via provided USB cable and power on H10.
4. Once the device is ready, run the *.exe. It will automatically copy the firmware to your H10.
5. The progress bar copying firmware will be shown and your H10 device will give you 'Busy' message.
6. Once it's done, it will give you 'Upgrade Complete' message.
7. Please disconnect H10 with 'Safely Remove Hardware' option on your PC task bar.
8. Turn on the power of H10, go to 'Settings -> Extra ->Firmware Upgrade' and select 'Yes'.
9. Your H10 device will shut off automatically once the firmware upgrade is complete.
Jun 06, 2010 | iRiver H10 MP3 Player
Power led is blinking after I upgrade firmware
Something went wrong during the upgrade of your firmware. If you were upgrading the firmware from Linksys website you need to call their tech support and have them replace it for you. If you were trying to hack it with a 3rd party firmware you probably need to go buy another one and maybe consider using the firmware it comes with. You cannot restore the device because the flash killed the restore function. Your device is cooked. Put some BBQ sauce on it and serve it for dinner.
Jan 03, 2010 | Linksys WRT54G2 Wireless Router
Won't boot up and not recognised when connected to PC
During the upgrading of the firmware, if you turn off the power of M800, either by manually switching off the power or removal of the battery, the file system of M800 will be damaged, which will lead to booting failure problem. When this happens, you will not be able to turn on M800. Booting failure problem can be easily repaired by “manual firmware upgrade”. The procedures for manual firmware upgrade are as follows:
1. After firmware upgrade, only the blue LED under LCD is on, but LCD display is not turned on, please proceed manual firmware upgrade.
2. Remove the battery.
3. Put the battery back into the player again.
* Notice ! : Do not turn on the power.
4. Connect the player to your PC.
5. While pressing the volume down button, power on the player.
6. Now PC should recognize M800 as one of its hard disks.
7. Download the latest firmware file into the root folder of the player.
8. Disconnect the player from your PC.
9. The blue light LED under the LCD display will flicker.
10. Wait for about one minute, blue LED is off. Turn on the player.
The manual firmware upgrade is now completed.
Jan 04, 2009 | Audio Players & Recorders
You have given me some advice on my yp-t10 bluetooth menu missing features please help me agian as i dont understand
Upgrade Methods
 If the product does not power on and shows any of the following symptoms, you may try the upgrade methods
in this chapter without having to disassemble the product:
- The product does not turn on when the power switch is pressed.
- The product powers on normally but no USB connection can be made.
- The product’s icons appear garbled or malfunction.
- Files are corrupted, or the product shows as a “removable storage” in Windows but cannot be accessed.
Firmware Upgrade Method
1. Download the firmware upgrade file to a folder and decompress it.
2. Check the contents of the folder that was decompressed.
3. Connect the YP-T10 to the PC.
4. Open the Removable Disk folder of the YP-T10.
5. Select the installation file in the folder that was decompressed,
and then copy the upgrade files to the Removable Disk folder
of the YP-T10.
6. Perform “Safely Remove Hardware”, and then disconnect the
device from the PC.
7. When power on YP-T10, power off after
“Image Upgrading...”, “AUI Upgrading...”
8. Power on again. After “Font Upgrading...”,
“Image Upgrading...”, “AUI Upgrading...” set will be power
9. After the upgrade, go to “Menu” → “ettings”→ “ystem”→
“Firmware” and check the version.
 If the battery power is low, the upgrade will not start. In this
case, you need to connect a USB or charging cord for the
upgrade to start.
Dec 08, 2008 | Samsung YP-T10 Digital Media Player
Firmware Upgrade Failed
Firmware upgrade is a simple but a delicate procedure. Make sure you are loading the correct firmware. You should get your firmware from the website of your router. Installing a THIRD PARTY firmware to your router voids the warranty of your router. Here is a tip for a successful firmware upgrade. BEFORE FIRMWARE UPGRADE(push the reset button of the router for 30 seconds then unplug the power of the router for 10 seconds). Upgrade the firmware. After the upgrade push the reset button again for 30seconds, unplug power for 10 seconds.
Mar 10, 2008 | Linksys Wireless-G Broadband Router
Firmware upgrade
Firmware Upgrade Instructions:
Please download and unzip the firmware file to computer's local hard drive and then follow the instructions in the "readme.txt" file to upgrade the firmware.
Warning : -
Firmware upgrade failure may permanently damage the unit and causing it not to function. If the issues in the "Release Note" do not address the problem you are experiencing, please do not upgrade the firmware. Never upgrade the firmware using a wireless connection. Firmware upgrade will reset the Router to factory default state (all current settings will be replaced by default settings). When necessary, please write down the Router's current settings before performing the firmware upgrade. Please do not load the previously saved Router "configuration file" to the new firmware.
If you need assistance performing the firmware upgrade or if you have any questions, please contact our Techsupport Team
Feb 16, 2008 | Trendware TEW-452BRP Wireless Router...
XA HD500 not recognized
visit at
Feb 11, 2008 | Computers & Internet
I do not feel comfortable performing the installation the Optional Enhancement Upgrade for DiMAGE 7, can I have the camera upgraded professionally?
If customers do not feel comfortable upgrading the DiMAGE 7 firmware themselves, they can send the camera in to the NJ repair facility with a note stating "Please Upgrade Firmware". Their camera will be upgraded, and they will be charged $49.95 (plus tax and shipping). They will receive back their upgraded camera, and a DiMAGE Viewer Ver 1.2 Upgrade CD-Rom*. (They will not receive the firmware upgrade on CD-Rom or the new DiMAGE Viewer) There is a 2-3 week turn around time once payment has been authorized. * images captured with an upgraded camera cannot be opened using previous versions of the DiMAGE Image Viewer Utility 1.11 or earlier. A DiMAGE Viewer Ver 1.2 upgrade CD-rom has been bundled with the DiMAGE 7 Optional Enhancement UPGRADE Firmware. The previous version of DiMAGE Image Viewer Utility must be installed before the DiMAGE Viewer (Ver 1.2) update can be loaded. If customers do not feel comfortable upgrading the DiMAGE 7 firmware themselves, but they want the DiMAGE 7 Optional Enhancement UPGRADE and the New DiMAGE Viewer 2.0, they should purchase the kit through our on-line store, then send the camera in to the NJ repair facility with the Firmware UPGRADE CD-Rom that they purchased. As long as the firmware CD-Rom is sent with the camera, and the camera does not show damage that may void the warranty or cause the firmware to not install properly, there will be no charge for the camera to be upgraded. There is a 2-3 week turn around time once the camera has be received. If customers attempt to install the firmware upgrade on their camera and experience a problem, or the upgrade does not complete, they should send the camera in to our NJ repair facility with the Firmware UPGRADE CD-Rom and a description of the problem. As long as the firmware CD-Rom is sent with the camera, and the camera does not show damage that may void the warranty or cause the firmware to not install properly, there will be no charge for the camera to be upgraded. There is a 2-3 week turn around time once the camera has be received.
Sep 15, 2005 | Konica Minolta DiMAGE 7 Digital Camera
Hitt HE-MP883G (1.5 GB) 2 GB Digital Media Player Logo
177 people viewed this question
Top Hitt Audio Players & Recorders Experts
Are you a Hitt Audio Player and Recorder Expert? Answer questions, earn points and help others
