Question about Microsoft Windows XP Home Edition
Error code 19 my cd dvd drive doesnt work - Microsoft Windows XP Home Edition
    Scholar:
  • 146 Answers
It appears that your cd/dvd drive drivers have been corrupted. Remove the drivers and reinstall them.
Click "start", select control panel,click on the system icon,click on the tab "hardware", then click on device manager, click on DVD-CD drives and finally click on your dvd/cd drive it will open a window that will allow you to uninstall the driver. You can re-install your drive by using an install disk, rebooting your computer and lettign XP detect it or re-install via the add new hardware icon in control panel.
Posted on Sep 10, 2009
    President:
  • 2,185 Answers
Your upper and lower filter needs clearing.
Click on Start --> Run --> and type in 'regedit'.
Upon entering, expand the "HKEY_LOCAL_MACHINE" >> System >> CurrentControlSet >> Control >> Class
Do you see:
{4D36E965-E325-11CE-BFC1-08002BE10318}
click this and it will show you the contents on the right.
Do you see: "UpperFilters" and "LowerFilters" ?
Delete them. Right click and choose"delete"
Exit the registry. Reboot your computer
  • 979 Answers
Good day sir, the error 19 is caused by missing system files and system registry, there are several ways to fix it, but the most reliable one is to reinstall your XP, just make sure that the CD, CD/DVD drive, Hard Drive and your memory is in good order.
  • 497 Answers
Check the link given below:
http://support.microsoft.com/kb/314060
Good Luck!!!!!!!!!!!!!!!
Tsstcorp cddvdw ts l633p error code 19
Code 19 means there is a driver conflict such as two devices trying to use the same resources.
Try this - Control Panel - Device Manager - CD/DVD - double click the device - Driver's Tab - click
Update Drivers (this will likely do nothing) - then RIGHT CLICK the drive - UNINSTALL - REBOOT
this will refresh the default driver stack.
Normally the above will fix that issue if not work your way down through these even if you have done
them before.
Your CD drive or DVD drive is missing or is not recognized by Windows or other programs
http://support.microsoft.com/kb/314060 - a Mr Fixit
The CD drive or the DVD drive does not work as expected on a computer that you upgraded to Windows Vista
http://support.microsoft.com/kb/929461
When you insert a CD or a DVD, Windows Vista may not recognize the disc
http://support.microsoft.com/kb/939052
Your CD or DVD drive cannot read or write media - A Mr Fixit
http://support.microsoft.com/gp/cd_dvd_drive_problems
CD/DVD drive does not appear in Windows Vista, or you receive this error during Windows Vista setup after booting from the DVD (AHCI)
http://support.microsoft.com/kb/952951
CD-R drive or CD-RW drive is not recognized as a recordable device
http://support.microsoft.com/kb/316529/
Hope these help.
Jun 14, 2012 | Computers & Internet
I have an Acer Aspire 5332 and the CD-Rom/DVD Drive (Optiarc DVD RW AD-7580S ATA Device) is not working properly...every time I put a disk of any kind (i.e CD/DVD/Game) it doesnt recognize it and load
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Mar 22, 2012 | Acer Computers & Internet
Code 19- philips cdrw/cvd scb5265 ata device how do i fix it
Do you receive the following error message?
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you can first try running a Troubleshooting Wizard. If that does not work, you should uninstall and then reinstall the hardware device. (Code 19)
Code 19 is a common error message, your computer sends because NERO, Roxio, and similar CD/DVD recording software and also and update for Windows VISTA (KB938194) is causing issues. It can create problems with your sound as well.
Even if you uninstall these it will not resolve the issue, because these programs leave the problem inside your registry.
What is happening to your computer?
Device Manager sees the drive, but you get the yellow exclamation mark and it indicates "Your registry might be corrupted. (Code 19)"
How most people try to fix this error – and you are probably doing the same - without any luck…
If you try to uninstall the device and the driver and read new hardware - no change.
You can try to update the driver and the wizard will say there is no better driver found for the hardware.
You can try to run the install CD (copied it to a flash card and ran it from a flash card reader since you can't run it on the DVD drive) - same problem will occur.
You can't do a repair install of Windows since it is on CD and it won't boot properly from the drive.
You can try to use an external DVD writer (HP dc5000) through the USB port and it will get the same code19 error.
Even if you try manually copy the drivers listed in driver details for the device - no luck
Jun 14, 2010 | Samsung Philips CD-RW Kit 4x4x32 ( CDRW...
My presario Cq60 cd/dvd drive not working. Driver is latest update. Message in general within device property is-configuratio in the registry is in complete or damaged code 19
From your description I understand that the DVD drive is not working and you have code 19 error in device manager.
Do not worry, run the following fix on the pc and then restart the notebook.
http://www.techiesspot.com/filez/cddvdfix.reg
Dec 22, 2009 | HP Compaq Presario CQ60-249US Notebook
CD drive wont work - code 19 showing - Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
Hello
Ok, i had the same error a couple of months ago, i dowloaded this tool from the link below and it works perfectly.
http://microsoft.pcerror.info/errorcode/code%2019.html?gclid=CPLh-vrVwZ4CFYIA4wodvCy5nw
Just click on the link above and you will be directed to the page where you can downoad the tool.
Kind regards
Andrea
Dec 06, 2009 | LG GSA 4163B DVD±RW Dual Layer Burner
Norton 360 install has replaced/overridden DVD drive
Hi, I can certainly understand how you feel and hope I can help.
error 19 isnt necesarily a corrupt driver, it can be 2 drivers trying to use the same resource (as in norton's backup drive and your cd drive, for example)
Try this - Click the start button, right click on "Computer", select "Properties", then click "Device Manager" in the upper left hand corner.
Open the bit that says "CD/DVD Drives" and try right clicking on the drives there and selecting "Update Driver Software". This will probably do nothing. Don't worry, I didnt really expect it to. Now right click on the drives, and select "Delete" and then reboot. This will reset the drivers for ya.
This fix usually DOES work. Most of the time. If it doesnt work, try the ones below.
Hardware devices not detected or not working - A Mr Fixit
http://support.microsoft.com/gp/hardware_device_problems
Hope these help.
Dec 05, 2009 | Gateway GT5435E Refurbished AMD Desktop...
Error Code 19
Replace the drive if it has not become unplugged.
Jun 26, 2017 | Computers & Internet
How to solve the code 19 errors
Error Code 19 means that the registry is corrupted. Try the following fix:
  1. Click Start and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters. On the Edit menu, click Delete.
  5. When you are prompted to confirm the deletion, click Yes.
  6. In the right pane, click LowerFilters. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. Exit Registry Editor.
  9. Restart the computer.
If this does not work, try uninstalling and reinstalling the computer by:
  1. Click Start and then click Control Panel.
  2. Click System and Maintenance, click System, and then click Device Manager.
    In Device Manager, expand DVD/CD-ROM drives, right-click the CD and DVD devices, and then click Uninstall.
  3. When you are prompted to confirm that you want to remove the device, click OK.
  4. Restart the computer.
Nov 22, 2008 | Sony (2450455) CD-ROM Drive
Dvd drive
Hi Sandy
I recommend that you uninstall all CD or DVD recording writing programs, if still it doesnt work we have to delete some register entries...
Please take a moment to assign a Fixya rating if you found this solution helpful.
Jun 02, 2008 | NEC Computers & Internet
Microsoft Windows XP Home Edition Logo
71 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
