Question about HP Laserjet M2727nf Multifunction Printer
Outgoing faxes are blocked
Each day i sent twenty faxes but somewhere in the middle he stop to do sending faxes
3 Suggested Answers
Inky
  • 691 Answers
SOURCE: Incorrect Fax Number showing on sent Faxes
Try This: To set the fax header To set or change the fax header information, complete the following steps. If you need help entering any information, see Enter text from the control panel. 1. On the control panel, press Menu. 2. Use the < or the > button to select Fax Setup, and then press (Tick) 3. Use the < or the > button to select Fax Header, and then press (Tick) 4. Use the alphanumeric buttons to enter your fax number, and then press (Tick) 5. Use the alphanumeric buttons to enter your company name, and then press (Tick) NOTE The maximum number of characters allowed in the fax number is 20. The maximum number of characters allowed in the company name is 40.
Posted on Oct 02, 2007
  • 167 Answers
the solution given is correct. happy faxing OMNIPRESENT
Does the Canon 3235i have a time stamp function for sending faxes?
Press> Additional functions > Communication Settings>TX fax settings
Feb 17, 2012 | Canon ImageRUNNER 3235i Black and White...
I'm having complants that my faxes are blured
Most common cause is going to be you need to have the scanner optics cleaned. Hopefully you have a local repair guy that can do this for you. However you can buy new basic fax machine like this now days for $75 to $80 which might be cheaper than servicing the old one.
Here is a tip for you tho. Make a copy using your fax machine. The quality of your copy is the same quality that you are sending out via the fax. So if your copy looks good then your outgoing faxes look fine. If you get a poor copy then that poor quality is what is being sent out. So copy quality = fax send quality.
Good Luck and Thank You for using Fixya.
Dec 01, 2010 | Sharp UX 108 Roll paper Thermal Fax
We went to a roll over system on our phone lines and now we cannot receive faxes. We can send them though.
Your roll over system is sending calls to the first line in the sequence and it does not differentiate between voice and fax. You will have to change the roll over so it does not send calls to your fax line. Your internal phone system may still use the fax line for outgoing faxes and voice calls but incoming fax calls have to be sent to the line the fax is on.
~Greg
Jul 13, 2010 | Brother IntelliFax-2820 Laser Fax
When I send a fax, the recepient cannot see the writing on the document, they can see the date and the address that i am sending the fax from, but they cannot see the content of the letter. When a fax is...
It'll be your outgoing fax resolution settings. Should be in your software somewhere. Move all settings, ie contrast, darkness etc to approx 50% .
I would have thought that there would also be a practice fax option, perhaps amongst the set up procedures.
Jun 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Faxes coming in print fine but outgoing faxes people are saying are coming out blank on their end
If outgoing faxes are turning up blank on the recipients end, you may be putting the paper to be faxed in backwards. Outgoing faxes should be sent face-down. If you are sending properly, either your scanner is failing (test it by copying a document) or the recipient is having fax issues on their end.
Jun 23, 2009 | HP 1020 Plain Paper Thermal transfer Fax
Can not send or receive fax.
Is the phone line plugged into the "line" jack and not the " phone or Ext " Jack?
Jun 09, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Wish to print outgoing fax log date/time/number
I don't think there's a log you can print but you can do the following. Not quite what you want, but better than nothing...
You need to set the fax confirmation option to log faxes before you send anything. The default option is off, so you won't be able to get a fax log for anything you've already sent unfortunately.
1. Press Setup
2. Press 2 then press 1. This displays the Print Report menu
3. Select Fax Confirmation
4. Press c00424037.gif to highlight one of the following, then press OK
Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
Canon MP830 - Outgoing fax dialing not connecting
Are you plugged into the LINE port of the fax machine?
Oct 21, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Sending fax error message "low memory"
Try reading these:
General fax problems
Issue Cause Solution The document stops feeding in the middle of faxing. The maximum length of a page that can be loaded is 381 mm (15 inches). Faxing of a longer page stops at 381 mm (15 inches). If no jam exists and less than one minute has elapsed, wait a moment before press Cancel . If a jam exists, remove the media. If the item is too small, it can jam inside the automatic document feeder (ADF).
(HP LaserJet 3015 all-in-one) The minimum paper size for the ADF is 74 x 105 mm (2.9 x 4 inches).
(HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one) The minimum page size for the ADF is 127 x 127 mm (5 x 5 inches). If a jam exists, remove the media. The fax activity logs or fax call reports are printing at inappropriate times. The fax activity log or fax call reports settings are not correct. Print a configuration report and check when the reports print. Set the appropriate log or report printing times through the control panel or the HP Toolbox. The volume for sounds that the device emits is too loud or too soft. The volume setting needs to be adjusted. Set the appropriate sound volume settings through the control panel. Fax send troubleshooting Use the information in the following table to solve problems that might occur when sending faxes: Issue Cause Solution Faxes stop during sending. The fax machine to which the fax is being sent might be malfunctioning. Try sending to another fax machine. The telephone might not be working. Do one of the following:
  • Turn up the volume on the device, and then press Fax/Send on the control panel. If a dial tone is heard, the telephone line is working.
  • Disconnect the device from the jack in the wall, and then connect a telephone to the jack. Try to make a telephone call to make sure that the telephone line is working.
A communication error might be interrupting the fax job. Change the redial-on-communication-error setting to On.
See the electronic User Guide on the CD-ROM that shipped with the product. The device is receiving faxes but is not sending them. If the device is on a PBX system, the PBX system might be generating a dial tone that the device cannot detect. Disable the detect-dial-tone setting.
See the electronic User Guide on the CD-ROM that shipped with the product. A poor telephone connection might exist. Try again later. The fax machine to which the unit is sending to might be malfunctioning. Try sending to another fax machine. The telephone line might not be working. Do one of the following:
Outgoing fax calls continue to be dialed. The device automatically redials a fax number if the redial options are set to On. Press Cancel to stop the redials while the device is dialing.
To cancel a pending fax job, see "Canceling a fax job" in the electronic Users' Guide on the product CD-ROM.
See "Changing the redial settings" in the electronic Users' Guide on the product CD-ROM. Faxes that are sent are not arriving at the receiving fax machine. The receiving fax machine might be off or might have an error condition, such as being out of paper. Call the recipient to make sure that the fax machine is on and ready to receive faxes. The originals might be incorrectly loaded. Make sure that the original documents are correctly loaded into the automatic document feeder (ADF) input tray or flatbed scanner (not available with the HP LaserJet 3015 all-in-one). A fax might be in memory because it is waiting to redial a busy number, other jobs that are ahead of it are waiting to be sent, or the fax is set up for a delayed send. If a fax job is in memory for any of these reasons, an entry for the job appears in the fax log. Print a fax activity log and check the Status column for jobs that show a Pending designation. All of the numbers of a long fax number cannot be dialed. The maximum number of digits of characters that can be entered into a fax number is 50. Try manually dialing the fax number. Faxes that are sent include a block of gray shading at the end of each page. The original may be on the flatbed scanner (HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one only), with the glass-fax size set incorrectly. Make sure the setting is correct. See "Changing the default glass-size setting" in the electronic Users' Guide on the product CD-ROM. Faxes that are sent have data missing from the end of each page. The original may be on the flatbed scanner (HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one only), with the glass-fax size set incorrectly. Make sure the setting is correct. See "Changing the default glass-size setting" in the electronic Users' Guide on the product CD-ROM.
Jul 16, 2008 | HP LaserJet 3030 All-In-One Printer
Canon Pixma MP780 Fax Problem (horizontal line)
Solution is here: http://www.fixya.com/support/t136826-printer_problem
Mar 05, 2007 | Canon PIXMA MP780 All-In-One InkJet...
HP Laserjet M2727nf Multifunction Printer Logo
42 people viewed this question
Seeker5211
Seeker5211
