Question about Sony PlayStation 2 (PS2) Console
Can u put a lens clearner in a ps2 - Sony PlayStation 2 (PS2) Console
    President:
  • 2,185 Answers
Yes you can as the lens reading the disks or cds are just the same with the other cdroms.
It is also advisable that if after using a lens cleaner and your ps2 still cannot read, you can clean the lens inside with a soft cotton bud damped in an alcohol.
Posted on Sep 10, 2009
Ps2 freezing games
I was experiencing the same problem on my ps2 slim scph-90004. When I put a game in my ps2 it loads but after some time it just freezes at the same spot.I went to many shops but they dont recognize my problem.Then i open my ps2 slim (Warning:Opening of ps2 my void your warranty) and saw the lens which was not adjusted. SO,if you are experiencing the same problem then use the above method(For slim only).Look at the rod near the lens which has two small clips on it. Open the screws on the clips and take out your ps2 lens.Clean it with a cotton.Set the lens in some different position and load your games .
Apr 20, 2013 | Sony PlayStation 2 (PS2) Console
Tip
Problems with xbox reading disc?
Two options either buy your self some laser clearner
or buy your self a new laser lens it will probably end up cheaper to get a new laser lens, But if you cant fit the lens then you stuck with using the cleaner.
on Jan 12, 2009 | Microsoft Xbox Console
Gt4 doesn't work on my ps2
Your reading lens is probably weak or its dirty....first you should clean your PS2 lens.Here is a video that will help you in cleaning your PS2 lens....
Cleaning lens helps in most of the cases.Apart from cleaning lens here is a little trick for you, check it out it might work on your console too!
http://www.fixya.com/support/r3537760-try_play_dvd_movies_ps2_wont_play_dvd
Although its about plying DVD's but you can play heavy games like Grand Turismo 4 , God of war etc too by following the same procedure....!
Good luck! :)
Jan 23, 2010 | Sony PlayStation 2 (PS2) Console
When you put in the dics, and on the screen says not reading disc
Disc read errors are mainly due to weak or dirty lens you should try cleaning lens first.
When your PS2 lens is covered by dust it wont allow laser to read disc so its better to clean your PS2 lens first,if problem still exists then your PS2 lens is weak and you will have to take it to Sony repairer for service.I recommend all of PS2 owners to keep their PS2 at dust free environment.
Watch this video it will help you to learn how to clean your PS2,its easy you can do it at home.
Wish you good luck and hope cleaning lens will solve your problem. Thank you!
Dec 05, 2009 | Sony PlayStation 2 (PS2) Console
Cp wont read disk
replace the lens in the player. or first try to clean the lens using a lens clearner
Aug 09, 2009 | Computers & Internet
Goes to Startup Screen when I put a game!
try cleaning the lens. for a slimline PS2, try a Q-tip with a little bit of alcohol on it and lightly touch the lens. gently TWIRL the Q-tip. use the other end of the Q-tip to dry the lens, again, gently twirl the Q-tip. or you could use a laser lens cleaner (see below). for a fat PS2, either use a laser lens cleaner specifically for video game systems (Best Buy, etc.) or go here and go to the very end. www.powerfulguides.com/ps2 hope this helps :D
May 30, 2009 | Sony PlayStation 2 (PS2) Console
My PS2 won't run my games.
HI, you will need to preform a lens cleansing by using a cleaning disc. try to recover lens function be cleaning the lens with a good len cleaning disc. if the lens cleaner dose not fix this issue, this will confirm optical lens assembly failure and, you will need to replace the lens assembly in this case.
Just to make sure that this isn't a control fault, unplug the PS2 for 5 minutes. if the unit still freezes up or , the unit will not play the disc, replace the optical lens assembly.
May 26, 2009 | Sony PlayStation 2 (PS2) Console
Need to clean my ps2
To Clean you PS2 Here are the steps
1. Unscrew you PS2 bye the top
2. Get a duster air can to spray off the dust. (make sure you don't spray to much they might have gas in them.)
3. Take a two sided Q tip or one sided doesn't matter and dip the cotton sides into rubbing alcohol and careful clean of the lens do not scratch it or you ruin your PS2.
4. Take all peices that you might have moved and put the exactly in place.
5. Put cover on.
6. Screw the screws back in (P.S. do not use a electric powered screw driver use a hand held one.)
7. Turn on and test it if it has problems like heating up dust out the fan on the back.
8. Enjoy. <(^ . ^)>
And, if you have a small PS2 even thought they are junk just dust out the fan open the part that you put the disc in and dust arond the lens and inside and then just clean the lens with the Q tip and alcohol.
YOUR WELCOME
Apr 26, 2009 | Video Game Consoles & Games
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
