Question about Motorola Mobility RAZR V3i Cellular Phone
Boot problem I forgot my unlock code and security code, so i try to flash and modding my v3i after using Rsdlite, after that it cnannot start now, when i press power button light comeup for short time and trun off. Any help.
    Problem Solver:
  • 8 Answers
U need to flash if using smartmoto
Posted on Dec 15, 2007
My motorola rokr e6 is having security code which is forgot by me ? i want to restore factory setting ,give me a better way pls help me
There is a way but you will lose all save items in your phone (messages / phone book entries.Download drivers for motorokr e6,firmware and RSDLITE v.3.4. Install them and using your cable connect your phone and open RSDLITE, your phone will be detected. Find your phone's firmware and press START and it will format and update your phone with the chosen fimware. Default sec codes 1234 or 000000
Jun 26, 2011 | Motorola Mobility ROKR E6 Smartphone
I have forgot my locked code? please help me
flash your rokr e6 . and your code is be default ....
for flash help go to this link..http://www.gsmindia.in/forum/p2k-series/11437-flash-your-motorokr-e6-at-home.html
or try this step..
Go to your Dial Pad and dial: WWW008W. To make the W hit the menu button while in the dial pad, then hit insert->insert wait to make the W .
You should see something like:
R533_G_11.12.08P
BP: R533_G_11.12.08PB
PFlex: GSZMCAUT678SW016
DSP: 63343400 TECHNOLOGY
Look at the numbers at the end of the first line for the version. The version shown here is .08P.
The Following are all Generic Firmware
R533_G_11.12.02P
R533_G_11.12.06P
R533_G_11.12.08P
Change Log - Nothing has changed until 08p which includes an EQ for Real player & Screen 3.
1. Download the file Motorola_USB_Driver_32_v2.7.6 to your PC and unrar it to your desktop so you can easily find it.
2. Install a program called "RSDLite" on your PC. To Download RSD lite Click thread for the file. For trouble free installation, if you are running Windows XP, you should have Service Pack 2 installed.
3. Download the firmware file that you want to flash to and unrar it to your desktop.
4. Start up RSDLite on your PC. You may be asked to install a number of drivers (5 or 6) to your PC. Point it in the direction to the motpcsdrivers folder you unrared.
5. Put the phone in Bootloader Mode - MBM mode by turning on phone while also holding down the Camera Button and the On/off button (These need to be all be held down together). The phone should start up with a red screen and say its in MBM mode.
6. Plug phone in using usb cable.
7. RSDLite should list the phone (this may take a minute or so. If it does not close down RSDLite and restart it). Start the flash process, by clicking the button on the top with the ??? and select the firmware file to install then click ?Start?. The process will take several minutes so be patient, the screen on you phone will turn off, but RSDLite will still show progress.
8. When the "Found New Hardware" screen pops up, select ?NO? for ?Can Windows connect to Windows Update?? then select ?Y? for ?Install Software from a specific location? and point it to the motpcsdrivers folder you unrared. Once the driver has installed, click on ?Finish? on the ?Found New Hardware wizard? to continue the process.
9. You will need to install quite a few drivers ? so just keep repeating. It may ask you to manually restart the phone ? if so, unplug the cable from PC, remove the battery for 5 seconds (make sure unplugged first!), put battery back in then turn phone back on.
10. Once its fully on, go to Setup --> USB Mode and change mode from "Mass Storage" to "Modem".
11. Plug phone back into the PC using the cable. RSDLite should say "complete" or ?PASS?
12. Unplug the phone again, turn it off and on. All should be complete.
You can now restore all your contacts, calendar and tasks back to your phone using MPT. (Be sure to remove the SIM card before doing this as the recovery function from MPT deletes any contact on SIM for some reason!)
Try This This Helps
by....ASHISH KUMAR
Jan 29, 2011 | Motorola Mobility MOTOROKR E6
My phone is locked
hi
follow these procedure to unlock your phone
first download drivers for motorokr e6,firmware and RSDLITE v.3.4.
install drivers and connect Ur phone through cable and open RSDLITE as it will detect your phone.After that browse firmware and press START and it will format your phone with brand new software and security codes will be default 1234 and 000000 but be aware that your messages,phone book and everything will be lost.
if you still having any problem contact your service provider..
thank you
Dec 22, 2010 | Motorola Mobility MOTOROKR E6
Forget security unlock code for motorokr e6 help
install drivers and connect ur fone through cable and open RSDLITE as it will detect ur fone.After that browse firmware and press START and it will format ur fone with brand new software and security codes will be default 1234 and 000000 but be aware that ur msgs,fonebook and everything will be lost.
Jul 31, 2009 | Motorola Mobility ROKR E6 Smartphone
V3a stuck on bootloader usb init screen'
flash your phone thru RSDlite and it be ok.
download rsdlite here:1.http://www.motorolafans.com/forums/a1200-applications/13457-rsdlite-download-here.html
download firmware here:2.http://rapidshare.com/files/62231936/MPC_V3A_01.1F.01R_PRInn22217_MONSTER_01.rar.html
after download complete install rsdlite to your computer.run rsdlite and plug your phone while in bootloader mode.if phone ask a driver,go to program files,rsdlite,p2k driver.after installing driver,flash your phone...
Jul 19, 2009 | Motorola Mobility RAZR V3a Cellular Phone
Start up problem
whenever ask for code ...click menu and enter 000000,
and reset ur new password
Dec 12, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Security code
i have forgot my security code of slvr L7.. plz tell me how to unlock..
Sep 15, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
