Question about HP Pavilion xt938 PC Desktop
NEED HELP TO GET MY COMP RUNNING WITHOUT LOSING MEMORY
My hp pavilion xt 938 will not re boot its self just keeps turning on and turning off
    Master:
    Sergeant:
  • 460 Answers
Your PC SMPS has been faulty .So pls replace it.
Posted on Sep 10, 2009
Hi, I have upgraded my HP Pavilion DV1000 RAM to 2G PC2700 DDR 333MHz, but after turning on it just makes 4 short beeps and screen is not turned on, please help me fix this error.
4 Short beeps would indicate during POST (Power on Self Test) there is a initialization issue with added hardware. The DIMM you added may not be compatible, or installed in the correct order.
1. Remove new memory completely, and see if machine starts
2. If you have original memory module still installed, remove it and try new one by itself.
3. If that works, put newer larger module in the 1st slot, and move original in second slot, and try again.
The system can automatically adjust memory settings (speed and timing) itself from the SPD module on every stick of RAM. However if the settings are drastically different, it can cause problems. Generally it will run as fast as the slowest module, but now always, sometimes causing the slower module to be attempted to run out of spec and cause boot issues or system instability.
Dec 06, 2013 | HP Pavilion dv1000 Notebook
My hp mini110 wont boot up how can i fix it
Turn OFF the Notebook and once its powered ON, keep Pressing F10 to load BIOS screen of the Notebook. In this screen under Diagnostics, run the test on hard drive and memory. Post back the results here.
Sep 11, 2012 | HP Pavilion 110-1030NR Notebook
Dear sir. my laptop hp pavilion dv5, its comming
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Aug 27, 2010 | HP Pavilion dv5000z Notebook
Hp pavilion a305w won't boot up all the way screen
hi, for select the boot option press F8 on your keyboard.. if your computer have a problem it will pause then it will restart mybe it might have a software or memory problem.. To fix the software problem you only put your recovery disk then start recover.. if the problem still their then you have the hardware problem to fix it you must remove your old memory in the computer then buy a new one...
regards...
Mar 04, 2010 | HP Pavilion a305w (DM181AR) PC Desktop
I started download for windows vista update, its gave me message its service pack didnt install so its reverting changes back to not turn off computer . that was 3 hours ago, computer keeps rebooting its...
Hold down the f8 key while booting up.This will put it in safe mode.
once there, try setting the restore point to last known good configuration.
This should bring you back to before the update.
Vista service pack 2 is very large and can take awhile to install.
Try updating the service pack again. After you get running.
Jan 11, 2010 | HP Pavilion dv6000z Notebook
Hp pavilion a1540n does not boot, fan turns on high, and beeps once every +/-5 seconds
Sounds like a memory fault, try removing 1 memory at a time, and restart. might help, try each memory by its self to indentify the bad card.
Dec 01, 2009 | HP Pavilion a1540n PC Desktop
Hp tx 1000 black screen please hel
Nov 28, 2009 | HP Pavilion Tablet Notebook
Unable to start laptop
I understand the urgency and also the importance of data stored in the laptop.
As the laptop is unable to start in normal mode let us try in safe mode.
Follow the steps below:
1. Turn the laptop off completely.
2. Press the power on button to turn it on and at the same time simultaneously keep tapping ' F8 ' key on key pad until you see a advanced boot options screen.
3. Select 'safe mode' and hit enter.
Thank you.
Nov 28, 2008 | HP Pavilion dv6000z Notebook
Stuck on logo screen
Hi sandy,
Can you please tap F8 while your laptop is powering ON then select Last Known Good Configuration when you see some options..
when was the last time you use this laptop? i mean, did you see this running before you got it?
Jun 23, 2008 | HP Pavilion a800n (PP163AA) PC Desktop
Stuck at hp logo
u dont have any option except running a recovery restart the comp and keep tapping F11 and then start the recovery.......i am sorry to say but all the data will be lost
Feb 07, 2008 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
