Question about Refrigerators
I have a samsung fridge freezer mod; sr-s2028css gets to temp then wont come on again unless switched off and on ches
  • ches66 Sep 10, 2009
    thanks will see what i can do ches
  • Refrigerators Master
  • 19,396 Answers
If the fridge is cooling down, that means that compressor is working.
If the fridge cool down, then the compressor does not start again, then defective parts may be digital temperature control, or temperature sensor, also have a look at compressor capacitor.
If the fridge instead comes on, keep cooling for few days or weeks, then stop cooling, and you have to defrost to have it working again, then you have a faulty defrost system.
The defrost heating system is located behind fridge firewall, it is composed by heating element , fan and defrost thermostat. The heater is tested reading Ohms at its contacts.
To get a quote on repair and part prices you can ring Samsung at the number listed on the owner manual.
Posted on Sep 10, 2009
Samsung American fridge freezer SR-S2028CSS keeps beeping and randomly turning the fast freeze on and off.
quite possibly it needs some freon added to the system and only service people can do this
Jan 06, 2016 | Samsung Refrigerators
Hi. I own an older Samsung SR-S2028CSS fridge/freezer. The temperature control setting and ice mode selection buttons were ineffective and the fridge and freezer had increased in temperature, but...
blank display with segment flashing is a fault code samsung appliances use this method for displaying faults ...
samsung fridge freezer trouble shooting videos are available on youtube ..
have alook at this video and see if its the same segment that you have
Jan 20, 2011 | Samsung RS2534 Side by Side Refrigerator
Samsung side by side fridge freezer sr-s2028css. having seeked advice from refridgeration engineer was told compressor was not working, had a new compressor fitted by another engineer but still existing...
Did they change the start relay as well as the compressor? On Samsung refers the start relays do not come with the compressor. If they didn't its possible that the start relay is clicking.
Oct 07, 2010 | Samsung Refrigerators
Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Jun 28, 2009 | Refrigerators
Flashing freezer temp on Samsung SR S22
how to remove cover from twin cooler samsung sr-s20-s22
Mar 25, 2009 | Freezers
I have a Samsung SR-S2028CSS side by side Fridge Freezer with an icemaker water dispenser. The freezer is run at -23 degrees and the fridge at 2 degrees. Recently the ice, having been made in the icemaker,...
Are you sure about these temps C or F? At 2 deg on either scale, food would freeze! And -23 is unreachable.
Water running down the door sounds like a seal leak, check by putting a dollar bill between the seal and the frame. It should NOT pull out easily. Or there may be an air leak in the ice/water dispenser. Look at these parts closely. Or the "stile heater", a heater in the door frame to prevent condensation, may be broke. This is expensive to fix.
Apr 08, 2008 | Refrigerators
I am having problems with my samsung fridge model - SR-S2028CSS
does it freeze at all? you may have a problem with the coolent in the back of the fride which if so (depending on the cost of the fride) may be cheaper to replace, also the dial you use for selecting the freeze level could be faulty
Feb 19, 2008 | Refrigerators
Samsung SR-L39 fridge freezer switching off
replace the thermostat of the freezer
Sep 16, 2007 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
