Question about Compaq Presario R3000 Notebook
Display faint (dropped)
After a drop the display is very faint happened once before under warranty they said they replaced touch pad. how do i know this is the same problem?
    Scholar:
  • 151 Answers
You wouldn't actually know, since it was dropped, you might have voided your warranty. Theres possibly a loose connection on your LCD panel than needs checking... Have it serviced or repaired...
Posted on Dec 10, 2007
Microwave was beeping a single beep once in awhile now nothing happens but the clock still works
A lot of the time when that happens the touch pad is bad and may have a colappsed air pocket on a pad. ( it makes the unit think you are pushing a pad ) The only way to fix it is to replace it (the touch panel) . Did you see any numbers coming up in the display. Like if the 3 pad was bad and making it beep it may have been showing a 3 in the display,. Always possible it could be a bad main board. But most commonly I have found it to be the touch panel. Try to unplug it and then plug it back in and try to set the clock. when you do, try each number pad and see if they all work. See if any feel different.
Oct 17, 2017 | In Microwave Ovens
My touch screen on my nokia lumia wont work
Cell Phone Replacement Parts for Nokia Lumia 710 eBay
If you are going to do this yourself, screens can be purchased online, but it may require some skill.
Often there are while you wait screen repair services in large shopping malls in the United States. Unsure where you can find a service to repair the screen.
Feb 13, 2018 | Nokia Lumia 710
Cracked screen on my Trio tablet, can see the display but it won't respond to touch. It's not under warranty. Can I fix it myself?
Yes touch screens are very sensetive.Because of the cracks on the screen ,the board can't read the command.The screen can be replaced only if you know what you doing however it can cost upto and around between $250 and $350 mark to repair by a professional.to get better ideas of what your up for research on Utube .
Jan 06, 2014 | Samsung Galaxy Tab 3 10.1" Dual Core...
My over-the-range LG microwave stopped working yesterday. At first the display said "set time", but nothing happened when I touch the key pads. Now the display is jut the colon between the hour and minutes...
LG would still fix it if you are ready to pay for their service. Again, if the oven is JUST out of warranty, they may fix it for free. But it hugely depends on the pressure you exert on them and the number of calls you make.
Oct 23, 2010 | LG Microwave Ovens
My motorola RAZR V8 has no display
unfortunately this happens frequently with the razr
(sometimes as a result of dropping, sometimes not)
if it is under warranty you can take it to a store to have it replaced
Nov 05, 2009 | Motorola Mobility RAZR V3
Ipod touch backlight doesn't work
Is your brightness all the way up? Settings>General>Brightness (or Settings>Brightness) If that doesn't help you might need a replacement.
Sep 27, 2009 | Apple iPod touch
How to repair the left click button on HP Pavilion ZT1135
Hey,
I had the same problem. It is pretty easy to fix. You have one of two options to follow.
1) Push down moderately hard on the left mouse button. After 2 mins or so, and the cap should back on to the button on the bottom
2) if number 1 doesn't work get a needle or pin and lift the left mouse button off. Then just apply very little, not even a drop, maybe half of a drop to the button and apply the cap back on and push down.
Sep 25, 2009 | HP Pavilion zt1135 Notebook
Cell phone is automatically application are
i dont know if this is any help but have you dropped any liquid in the phone or have you changed the casing as this can happen when a cheap (dont mean you) alternative to motorola casings are used as there arwe sometimes edged parts which can be touching the touch pad by mistake if none of the above then has it been dropped as this also causes the cicuit board to malfunction
Sep 03, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
Sharp microwave model R-395F(S) bought in NZ. 1100W about 30litre. Problem from new, display weak but main problem as some buttons work some don't work and you have to push stop a few times before it...
Hi Lindsay
Sound like you need a new key pad if you have some handy man around you you can replace it, It require dismantle the front key pad remove electronic part and clean then reinstall properly the key pad itself about $40.00 Aus
Let me know if you need part number for that key pad
Cheers
Dec 02, 2008 | Microwave Ovens
I have a Garmin Nuvi 660 and the suction cup fell off the inside of the windshield and broke the screen on the GPS. I believe it is only the touch screen portion because the picture looks and acts fine. ...
If the unit is under warranty, then send it back to the manufacturer. I had one customer that had the same thing happen and the manufacture offered to replace her unit free of charge.
If the unit is out of warranty, the manufacturer will not sell you a replacement screen. You can find them on eBay, but unless you know how to take the Nuvi apart, you face damaging the unit further.
If the touch screen is bad, the Nuvi will not recognize any presses on the screen. Having worked on many of these units, there is really nothing to go bad on a touch screen unless its physically damaged or has become disconnected from being dropped. If it appears that the glass is cracked, then it is the LCD display that is bad. The touch screen is a clear film layer that lays over the LCD display.
I would strongly suggest that you purchase a Garmin friction mount and no longer use the window mount. With a friction mount, your Nuvi will not fall and the friction mount is legal in all 50 states, whereas a window mount may not be.
- Jim
Sep 29, 2008 | Garmin GPS
Compaq Presario R3000 Notebook Logo
26 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
