How to install Fax printer in local PC and what are the requirements
    Master:
    Sergeant:
  • 460 Answers
Connect the printer with PC & installed the printer driver.
Posted on Sep 10, 2009
Sorry I was wrong about the number on the computer but the question is the same how come I can't print or fax ?
Do you receive any type of error message? It seems for some reason your wireless printer is not communicating with the PC/laptop. Also, printing and faxing each require different forms of communication. In printing, you PC is just telling the printer to print what is on the screen; faxing requires the use of a phone line that needs to be set-up properly. Although the wireless setup btw the printer and PC must be working first.
Try uninstalling and reinstalling the software with the printer not plugged into the PC until the software is installed. Also, reread your manual carefully for insights about your issue.
Mar 25, 2015 | Dell All-In-One Wireless Printer V515w -...
I need help how to connect my fax
1. Connect the fax line provided by the telecom provider..
2. And install the required software provided to you in the CD along with the printer.
Mar 24, 2013 | Dell 966 All-In-One InkJet Printer
Installed hp officejet 4110 but cant fax
We can able to send the faxes with out PC.Driver support required when we chooses PC faxing only. Driver CD or down loaded full feature drivers required to install, Browse below link,select OS down load full feature drivers, install....http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=90792&lc=en&cc=us&dlc=en&lang=en&cc=us
Jan 01, 2012 | HP Officejet 4110 All-In-One InkJet...
Want receive a fax
To receive a fax, first check to see if your telephone line has the capacity to send and receive faxes, a "conventional modem" sometimes is necessary, that may have changed with VOIP . Make sure to configure printer for faxing and that the Fax icon appears in the Printer/Fax window.. Follow all the basic set up steps to configure Fax, making sure all options are set correctly to enable where required. You might call your local phone company and ask them what you need to hook up a fax capable printer...or ask the manufacturer for the specifics of configuration for faxing.
Jul 29, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
Optional Fax Kit FK-503 Installation
yes there is a manual, but it required certified technician by konica to install this for you or authorized dealer.
Jun 10, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
I have a canon fax-l350 and I want to use it as printer too. so how can I adjest it with my pc and the required materials and softwares
To set up the L350 as a local printer (I'm assuming that you are not putting it on a network) you will need the Canon FAX-L350 CD-Rom which contains the Fax suite (I have version 3.11). You will also need a parallel printer cable as the fax machine only has a parallel printer port on the rear (the other side to the power cable.
When loading up the CD-Rom (which should have been supplied with your machine - if not you may have to buy one off the web), first make sure you read chapter 2 in the manuals folder on screen then install the driver from the 'program setup.exe' file.
After loading the CD-Rom onto your PC (and before making any physical connections between the PC and the Fax) make sure that the fax is switched off at the mains and also logout and switch off your PC. Next, connect up the cable (Canon recommend a cable that complies with IEEE1284). Centronics supply these cables, but if you do not have a parallel (8 bit ) port on your PC you can get a converter cable (Centronics 36) which will connect the parallel cable to a USB port on the rear of your PC. After checking the connections you can switch your fax back on and also power up your PC. Hope this helps.
Dec 23, 2008 | Canon FAX-L350 Plain Paper Laser
MFC-8660DN
HI,
Click HERE to download the user's manual.Please refer the troubleshooting steps.
Click HERE to download setup guide.
Goodluck,
Please don't forget to rate the solution.
Mar 28, 2008 | Brother MFC-8660DN 5-in-1 Laser...
Incoming faxes are not received
1. Make sure you have paper in the feeder tray.2. Make sure that Fax Forwarding is not selected: Use the up/down arrow buttons to scroll through the menuoptions until you see the option required, and press the "check mark" button to select:
Select "Fax" on the device main menu. Select "Fax Setup" from the Fax submenu, Select "Ringing and Answering" from the Fax Setup submenu Now find the "Fax Forward" option. Once you see this option, press the left or right arrow buttons until you see "Off". Now press the "Enter" button to save.
Let me know if this doesn't solve your problem, and include further detail to the problem if available.
Jan 21, 2008 | Lexmark X9350 All-In-One InkJet Printer
Fax device I/O error
installed samsung scx-4521f multi function printer. can't fax from smarThru program. get message : Fax device I/O error
Jan 11, 2008 | Samsung CLX 3160fn All-In-One Printer
k24674
jasbo
jasbo
